| 1 |
/* Copyright (c) 1994 Regents of the University of California */
| 2 |
| 3 |
/* SCCSid "$SunId$ LBL" */
| 4 |
| 5 |
| 6 |
* ray.h - header file for routines using rays.
| 7 |
| 8 |
* 8/7/85
| 9 |
| 10 |
| 11 |
#include "standard.h"
| 12 |
| 13 |
#include "object.h"
| 14 |
| 15 |
#include "color.h"
| 16 |
| 17 |
/* ray type flags */
| 18 |
#define PRIMARY 01 /* original ray */
| 19 |
#define SHADOW 02 /* ray to light source */
| 20 |
#define REFLECTED 04 /* reflected ray */
| 21 |
#define REFRACTED 010 /* refracted (bent) ray */
| 22 |
#define TRANS 020 /* transmitted/transferred ray */
| 23 |
#define AMBIENT 040 /* ray scattered for interreflection */
| 24 |
#define SPECULAR 0100 /* ray scattered for specular */
| 25 |
| 26 |
/* reflected ray types */
| 27 |
#define RAYREFL (SHADOW|REFLECTED|AMBIENT|SPECULAR)
| 28 |
| 29 |
typedef struct ray {
| 30 |
unsigned long rno; /* unique ray number */
| 31 |
int rlvl; /* number of reflections for this ray */
| 32 |
float rweight; /* cumulative weight of this ray */
| 33 |
short rtype; /* ray type */
| 34 |
short crtype; /* cumulative ray type */
| 35 |
struct ray *parent; /* ray this originated from */
| 36 |
FVECT rorg; /* origin of ray */
| 37 |
FVECT rdir; /* normalized direction of ray */
| 38 |
double rmax; /* maximum distance (aft clipping plane) */
| 39 |
int rsrc; /* source we're aiming for */
| 40 |
OBJECT *clipset; /* set of objects currently clipped */
| 41 |
OBJECT *newcset; /* next clipset, used for transmission */
| 42 |
int (*revf)(); /* evaluation function for this ray */
| 43 |
OBJREC *ro; /* intersected object */
| 44 |
double rot; /* distance to object */
| 45 |
FVECT rop; /* intersection point */
| 46 |
FVECT ron; /* intersection surface normal */
| 47 |
double rod; /* -DOT(rdir, ron) */
| 48 |
FULLXF *rox; /* object transformation */
| 49 |
FVECT pert; /* surface normal perturbation */
| 50 |
COLOR pcol; /* pattern color */
| 51 |
COLOR rcol; /* returned ray value */
| 52 |
double rt; /* returned effective ray length */
| 53 |
} RAY;
| 54 |
| 55 |
extern int raytrace();
| 56 |
| 57 |
extern double raynormal();
| 58 |
| 59 |
extern int dimlist[]; /* dimension list for distribution */
| 60 |
extern int ndims; /* number of dimensions so far */
| 61 |
extern int samplendx; /* index for this sample */
| 62 |
| 63 |
#define MAXDIM 32 /* maximum number of dimensions */
| 64 |
| 65 |
#define rayvalue(r) (*(r)->revf)(r)
