root/radiance/ray/src/rt/ray.h
Revision: 2.28
Committed: Tue Jun 21 15:06:50 2005 UTC (18 years, 10 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1
Fixed bugs in black glass transmission and source weight computation
1 /* RCSid $Id: ray.h,v 2.27 2005/06/13 20:07:56 greg Exp $ */
2 /*
3 * ray.h - header file for routines using rays.
4 */
5 #ifndef _RAD_RAY_H_
6 #define _RAD_RAY_H_
7
8 #include "standard.h"
9 #include "octree.h"
10 #include "object.h"
11 #include "color.h"
12
13 #ifdef __cplusplus
14 extern "C" {
15 #endif
16
17 #define MAXDIM 32 /* maximum number of dimensions */
18
19 /* ray type flags */
20 #define PRIMARY 01 /* original ray */
21 #define SHADOW 02 /* ray to light source */
22 #define REFLECTED 04 /* reflected ray */
23 #define REFRACTED 010 /* refracted (bent) ray */
24 #define TRANS 020 /* transmitted/transferred ray */
25 #define AMBIENT 040 /* ray scattered for interreflection */
26 #define SPECULAR 0100 /* ray scattered for specular */
27
28 /* reflected ray types */
29 #define RAYREFL (SHADOW|REFLECTED|AMBIENT|SPECULAR)
30
31 typedef struct ray {
32 unsigned long rno; /* unique ray number */
33 int rlvl; /* number of reflections for this ray */
34 float rweight; /* cumulative weight (for termination) */
35 COLOR rcoef; /* contribution coefficient w.r.t. parent */
36 short rtype; /* ray type */
37 short crtype; /* cumulative ray type */
38 const struct ray *parent; /* ray this originated from */
39 FVECT rorg; /* origin of ray */
40 FVECT rdir; /* normalized direction of ray */
41 double rmax; /* maximum distance (aft clipping plane) */
42 int rsrc; /* source we're aiming for */
43 OBJECT *clipset; /* set of objects currently clipped */
44 OBJECT *newcset; /* next clipset, used for transmission */
45 void (*revf)(struct ray *); /* ray evaluation function */
46 void (*hitf)(OBJECT *, struct ray *); /* custom hit test */
47 OBJECT robj; /* intersected object number */
48 OBJREC *ro; /* intersected object (one with material) */
49 double rot; /* distance to object */
50 FVECT rop; /* intersection point */
51 FVECT ron; /* intersection surface normal */
52 double rod; /* -DOT(rdir, ron) */
53 FULLXF *rox; /* object transformation */
54 RREAL uv[2]; /* local coordinates */
55 FVECT pert; /* surface normal perturbation */
56 COLOR pcol; /* pattern color */
57 COLOR rcol; /* returned radiance value */
58 double rt; /* returned effective ray length */
59 COLOR cext; /* medium extinction coefficient */
60 COLOR albedo; /* medium scattering albedo */
61 float gecc; /* scattering eccentricity coefficient */
62 int *slights; /* list of lights to test for scattering */
63 } RAY;
64
65 #define rayvalue(r) (*(r)->revf)(r)
66
67 extern char VersionID[]; /* Radiance version ID string */
68
69 extern CUBE thescene; /* our scene */
70 extern OBJECT nsceneobjs; /* number of objects in our scene */
71
72 extern unsigned long raynum; /* next ray ID */
73 extern unsigned long nrays; /* total rays traced so far */
74
75 extern OBJREC Lamb; /* a Lambertian surface */
76 extern OBJREC Aftplane; /* aft clipping object */
77
78 extern void (*trace)(); /* global trace reporting callback */
79
80 extern int dimlist[]; /* dimension list for distribution */
81 extern int ndims; /* number of dimensions so far */
82 extern int samplendx; /* index for this sample */
83
84 extern int ray_savesiz; /* size of parameter save buffer */
85
86 extern int do_irrad; /* compute irradiance? */
87
88 extern int rand_samp; /* pure Monte Carlo sampling? */
89
90 extern double dstrsrc; /* square source distribution */
91 extern double shadthresh; /* shadow threshold */
92 extern double shadcert; /* shadow testing certainty */
93 extern int directrelay; /* number of source relays */
94 extern int vspretest; /* virtual source pretest density */
95 extern int directvis; /* light sources visible to eye? */
96 extern double srcsizerat; /* maximum source size/dist. ratio */
97
98 extern double specthresh; /* specular sampling threshold */
99 extern double specjitter; /* specular sampling jitter */
100
101 extern COLOR cextinction; /* global extinction coefficient */
102 extern COLOR salbedo; /* global scattering albedo */
103 extern double seccg; /* global scattering eccentricity */
104 extern double ssampdist; /* scatter sampling distance */
105
106 extern int backvis; /* back face visibility */
107
108 extern int maxdepth; /* maximum recursion depth */
109 extern double minweight; /* minimum ray weight */
110
111 extern char *ambfile; /* ambient file name */
112 extern COLOR ambval; /* ambient value */
113 extern int ambvwt; /* initial weight for ambient value */
114 extern double ambacc; /* ambient accuracy */
115 extern int ambres; /* ambient resolution */
116 extern int ambdiv; /* ambient divisions */
117 extern int ambssamp; /* ambient super-samples */
118 extern int ambounce; /* ambient bounces */
119 extern char *amblist[]; /* ambient include/exclude list */
120 extern int ambincl; /* include == 1, exclude == 0 */
121
122 extern int ray_pnprocs; /* number of child processes */
123 extern int ray_pnidle; /* number of idle processes */
124
125 #ifndef AMBLLEN
126 #define AMBLLEN 512 /* max. ambient list length */
127 #endif
128 #define AMBWORD 12 /* average word length */
129
130 typedef struct { /* rendering parameter holder */
131 int do_irrad;
132 int rand_samp;
133 double dstrsrc;
134 double shadthresh;
135 double shadcert;
136 int directrelay;
137 int vspretest;
138 int directvis;
139 double srcsizerat;
140 COLOR cextinction;
141 COLOR salbedo;
142 double seccg;
143 double ssampdist;
144 double specthresh;
145 double specjitter;
146 int backvis;
147 int maxdepth;
148 double minweight;
149 char ambfile[512];
150 COLOR ambval;
151 int ambvwt;
152 double ambacc;
153 int ambres;
154 int ambdiv;
155 int ambssamp;
156 int ambounce;
157 int ambincl;
158 short amblndx[AMBLLEN+1];
159 char amblval[AMBLLEN*AMBWORD];
160 } RAYPARAMS;
161
162 #define rpambmod(p,i) ( (i)>=AMBLLEN||(p)->amblndx[i]<0 ? \
163 (char *)NULL : (p)->amblval+(p)->amblndx[i] )
164
165 /* defined in duphead.c */
166 extern void headclean(void);
167 extern void openheader(void);
168 extern void dupheader(void);
169 /* defined in persist.c */
170 extern void persistfile(char *pfn);
171 extern void pfdetach(void);
172 extern void pfclean(void);
173 extern void pflock(int lf);
174 extern void pfhold(void);
175 extern void io_process(void);
176 /* defined in freeobjmem.c */
177 extern int free_objs(OBJECT on, OBJECT no);
178 extern void free_objmem(void);
179 /* defined in preload.c */
180 extern int load_os(OBJREC *op);
181 extern void preload_objs(void);
182 /* defined in raycalls.c */
183 extern void ray_init(char *otnm);
184 extern void ray_trace(RAY *r);
185 extern void ray_done(int freall);
186 extern void ray_save(RAYPARAMS *rp);
187 extern void ray_restore(RAYPARAMS *rp);
188 extern void ray_defaults(RAYPARAMS *rp);
189 /* defined in raypcalls.c */
190 extern void ray_pinit(char *otnm, int nproc);
191 extern void ray_psend(RAY *r);
192 extern int ray_pqueue(RAY *r);
193 extern int ray_presult(RAY *r, int poll);
194 extern void ray_pdone(int freall);
195 extern void ray_popen(int nadd);
196 extern void ray_pclose(int nsub);
197 /* defined in raytrace.c */
198 extern int rayorigin(RAY *r, int rt, const RAY *ro, const COLOR rc);
199 extern void rayclear(RAY *r);
200 extern void raytrace(RAY *r);
201 extern void rayhit(OBJECT *oset, RAY *r);
202 extern void raycont(RAY *r);
203 extern void raytrans(RAY *r);
204 extern int rayshade(RAY *r, int mod);
205 extern void rayparticipate(RAY *r);
206 extern void raytexture(RAY *r, OBJECT mod);
207 extern int raymixture(RAY *r, OBJECT fore, OBJECT back, double coef);
208 extern void raycontrib(double rc[3], const RAY *r, int flags);
209 extern double raydist(const RAY *r, int flags);
210 extern double raynormal(FVECT norm, RAY *r);
211 extern void newrayxf(RAY *r);
212 extern void flipsurface(RAY *r);
213 extern int localhit(RAY *r, CUBE *scene);
214 /* defined in renderopts.c */
215 extern int getrenderopt(int ac, char *av[]);
216 extern void print_rdefaults(void);
217 /* defined in srcdraw.c */
218 extern void drawsources(COLOR *pic[], float *zbf[],
219 int x0, int xsiz, int y0, int ysiz);
220 extern void init_drawsources(int rad);
221 /* defined in rt/initotypes.c */
222 extern void initotypes(void);
223 /* module main procedures */
224 extern void rtrace(char *fname);
225 extern char * formstr(int f);
226 extern void rview(void);
227 extern void rpict(int seq, char *pout, char *zout, char *prvr);
228
229
230 #ifdef __cplusplus
231 }
232 #endif
233 #endif /* _RAD_RAY_H_ */
234
