| 1 |
/* RCSid $Id: ray.h,v 2.20 2003/07/14 22:24:00 schorsch Exp $ */
| 2 |
| 3 |
* ray.h - header file for routines using rays.
| 4 |
| 5 |
#ifndef _RAD_RAY_H_
| 6 |
#define _RAD_RAY_H_
| 7 |
| 8 |
#include "standard.h"
| 9 |
#include "octree.h"
| 10 |
#include "object.h"
| 11 |
#include "color.h"
| 12 |
| 13 |
#ifdef __cplusplus
| 14 |
extern "C" {
| 15 |
#endif
| 16 |
| 17 |
#define MAXDIM 32 /* maximum number of dimensions */
| 18 |
| 19 |
/* ray type flags */
| 20 |
#define PRIMARY 01 /* original ray */
| 21 |
#define SHADOW 02 /* ray to light source */
| 22 |
#define REFLECTED 04 /* reflected ray */
| 23 |
#define REFRACTED 010 /* refracted (bent) ray */
| 24 |
#define TRANS 020 /* transmitted/transferred ray */
| 25 |
#define AMBIENT 040 /* ray scattered for interreflection */
| 26 |
#define SPECULAR 0100 /* ray scattered for specular */
| 27 |
| 28 |
/* reflected ray types */
| 29 |
#define RAYREFL (SHADOW|REFLECTED|AMBIENT|SPECULAR)
| 30 |
| 31 |
typedef struct ray {
| 32 |
unsigned long rno; /* unique ray number */
| 33 |
int rlvl; /* number of reflections for this ray */
| 34 |
float rweight; /* cumulative weight of this ray */
| 35 |
short rtype; /* ray type */
| 36 |
short crtype; /* cumulative ray type */
| 37 |
struct ray *parent; /* ray this originated from */
| 38 |
FVECT rorg; /* origin of ray */
| 39 |
FVECT rdir; /* normalized direction of ray */
| 40 |
double rmax; /* maximum distance (aft clipping plane) */
| 41 |
int rsrc; /* source we're aiming for */
| 42 |
OBJECT *clipset; /* set of objects currently clipped */
| 43 |
OBJECT *newcset; /* next clipset, used for transmission */
| 44 |
void (*revf)(struct ray *); /* evaluation function for this ray */
| 45 |
void (*hitf)(OBJECT *, struct ray *); /* custom hit test */
| 46 |
OBJECT robj; /* intersected object number */
| 47 |
OBJREC *ro; /* intersected object (one with material) */
| 48 |
double rot; /* distance to object */
| 49 |
FVECT rop; /* intersection point */
| 50 |
FVECT ron; /* intersection surface normal */
| 51 |
double rod; /* -DOT(rdir, ron) */
| 52 |
FULLXF *rox; /* object transformation */
| 53 |
RREAL uv[2]; /* local coordinates */
| 54 |
FVECT pert; /* surface normal perturbation */
| 55 |
COLOR pcol; /* pattern color */
| 56 |
COLOR rcol; /* returned ray value */
| 57 |
double rt; /* returned effective ray length */
| 58 |
COLOR cext; /* medium extinction coefficient */
| 59 |
COLOR albedo; /* medium scattering albedo */
| 60 |
float gecc; /* scattering eccentricity coefficient */
| 61 |
int *slights; /* list of lights to test for scattering */
| 62 |
} RAY;
| 63 |
| 64 |
#define rayvalue(r) (*(r)->revf)(r)
| 65 |
| 66 |
extern char VersionID[]; /* Radiance version ID string */
| 67 |
| 68 |
extern CUBE thescene; /* our scene */
| 69 |
extern OBJECT nsceneobjs; /* number of objects in our scene */
| 70 |
| 71 |
extern unsigned long raynum; /* next ray ID */
| 72 |
extern unsigned long nrays; /* total rays traced so far */
| 73 |
| 74 |
extern OBJREC Lamb; /* a Lambertian surface */
| 75 |
extern OBJREC Aftplane; /* aft clipping object */
| 76 |
| 77 |
extern void (*trace)(); /* global trace reporting callback */
| 78 |
| 79 |
extern int dimlist[]; /* dimension list for distribution */
| 80 |
extern int ndims; /* number of dimensions so far */
| 81 |
extern int samplendx; /* index for this sample */
| 82 |
| 83 |
extern int ray_savesiz; /* size of parameter save buffer */
| 84 |
| 85 |
extern int do_irrad; /* compute irradiance? */
| 86 |
| 87 |
extern double dstrsrc; /* square source distribution */
| 88 |
extern double shadthresh; /* shadow threshold */
| 89 |
extern double shadcert; /* shadow testing certainty */
| 90 |
extern int directrelay; /* number of source relays */
| 91 |
extern int vspretest; /* virtual source pretest density */
| 92 |
extern int directvis; /* light sources visible to eye? */
| 93 |
extern double srcsizerat; /* maximum source size/dist. ratio */
| 94 |
| 95 |
extern double specthresh; /* specular sampling threshold */
| 96 |
extern double specjitter; /* specular sampling jitter */
| 97 |
| 98 |
extern COLOR cextinction; /* global extinction coefficient */
| 99 |
extern COLOR salbedo; /* global scattering albedo */
| 100 |
extern double seccg; /* global scattering eccentricity */
| 101 |
extern double ssampdist; /* scatter sampling distance */
| 102 |
| 103 |
extern int backvis; /* back face visibility */
| 104 |
| 105 |
extern int maxdepth; /* maximum recursion depth */
| 106 |
extern double minweight; /* minimum ray weight */
| 107 |
| 108 |
extern char *ambfile; /* ambient file name */
| 109 |
extern COLOR ambval; /* ambient value */
| 110 |
extern int ambvwt; /* initial weight for ambient value */
| 111 |
extern double ambacc; /* ambient accuracy */
| 112 |
extern int ambres; /* ambient resolution */
| 113 |
extern int ambdiv; /* ambient divisions */
| 114 |
extern int ambssamp; /* ambient super-samples */
| 115 |
extern int ambounce; /* ambient bounces */
| 116 |
extern char *amblist[]; /* ambient include/exclude list */
| 117 |
extern int ambincl; /* include == 1, exclude == 0 */
| 118 |
| 119 |
extern int ray_pnprocs; /* number of child processes */
| 120 |
extern int ray_pnidle; /* number of idle processes */
| 121 |
| 122 |
#define AMBLLEN 128 /* max. ambient list length */
| 123 |
#define AMBWORD 8 /* average word length */
| 124 |
| 125 |
typedef struct { /* rendering parameter holder */
| 126 |
int do_irrad;
| 127 |
double dstrsrc;
| 128 |
double shadthresh;
| 129 |
double shadcert;
| 130 |
int directrelay;
| 131 |
int vspretest;
| 132 |
int directvis;
| 133 |
double srcsizerat;
| 134 |
COLOR cextinction;
| 135 |
COLOR salbedo;
| 136 |
double seccg;
| 137 |
double ssampdist;
| 138 |
double specthresh;
| 139 |
double specjitter;
| 140 |
int backvis;
| 141 |
int maxdepth;
| 142 |
double minweight;
| 143 |
char ambfile[512];
| 144 |
COLOR ambval;
| 145 |
int ambvwt;
| 146 |
double ambacc;
| 147 |
int ambres;
| 148 |
int ambdiv;
| 149 |
int ambssamp;
| 150 |
int ambounce;
| 151 |
int ambincl;
| 152 |
short amblndx[AMBLLEN+1];
| 153 |
char amblval[AMBLLEN*AMBWORD];
| 154 |
} RAYPARAMS;
| 155 |
| 156 |
#define rpambmod(p,i) ( (i)>=AMBLLEN||(p)->amblndx[i]<0 ? \
| 157 |
(char *)NULL : (p)->amblval+(p)->amblndx[i] )
| 158 |
| 159 |
/* defined in duphead.c */
| 160 |
extern void headclean(void);
| 161 |
extern void openheader(void);
| 162 |
extern void dupheader(void);
| 163 |
extern void pfdetach(void);
| 164 |
extern void pfclean(void);
| 165 |
extern void pflock(int lf);
| 166 |
extern void pfhold(void);
| 167 |
extern void io_process(void);
| 168 |
/* defined in freeobjmem.c */
| 169 |
extern int free_objs(OBJECT on, OBJECT no);
| 170 |
extern void free_objmem(void);
| 171 |
/* defined in preload.c */
| 172 |
extern int load_os(OBJREC *op);
| 173 |
extern void preload_objs(void);
| 174 |
/* defined in raycalls.c */
| 175 |
extern void ray_init(char *otnm);
| 176 |
extern void ray_trace(RAY *r);
| 177 |
extern void ray_done(int freall);
| 178 |
extern void ray_save(RAYPARAMS *rp);
| 179 |
extern void ray_restore(RAYPARAMS *rp);
| 180 |
extern void ray_defaults(RAYPARAMS *rp);
| 181 |
/* defined in raypcalls.c */
| 182 |
extern void ray_pinit(char *otnm, int nproc);
| 183 |
extern void ray_psend(RAY *r);
| 184 |
extern int ray_pqueue(RAY *r);
| 185 |
extern int ray_presult(RAY *r, int poll);
| 186 |
extern void ray_pdone(int freall);
| 187 |
extern void ray_popen(int nadd);
| 188 |
extern void ray_pclose(int nsub);
| 189 |
/* defined in raytrace.c */
| 190 |
extern int rayorigin(RAY *r, RAY *ro, int rt, double rw);
| 191 |
extern void rayclear(RAY *r);
| 192 |
extern void raytrace(RAY *r);
| 193 |
extern void rayhit(OBJECT *oset, RAY *r);
| 194 |
extern void raycont(RAY *r);
| 195 |
extern void raytrans(RAY *r);
| 196 |
extern int rayshade(RAY *r, int mod);
| 197 |
extern void rayparticipate(RAY *r);
| 198 |
extern void raytexture(RAY *r, OBJECT mod);
| 199 |
extern int raymixture(RAY *r, OBJECT fore, OBJECT back, double coef);
| 200 |
extern double raydist(RAY *r, int flags);
| 201 |
extern double raynormal(FVECT norm, RAY *r);
| 202 |
extern void newrayxf(RAY *r);
| 203 |
extern void flipsurface(RAY *r);
| 204 |
extern int localhit(RAY *r, CUBE *scene);
| 205 |
/* defined in renderopts.c */
| 206 |
extern int getrenderopt(int ac, char *av[]);
| 207 |
extern void print_rdefaults(void);
| 208 |
/* defined in srcdraw.c */
| 209 |
extern void drawsources(COLOR *pic[], float *zbf[],
| 210 |
int x0, int xsiz, int y0, int ysiz);
| 211 |
/* module main procedures */
| 212 |
extern void rtrace(char *fname);
| 213 |
extern void rview(void);
| 214 |
extern void rpict(int seq, char *pout, char *zout, char *prvr);
| 215 |
| 216 |
| 217 |
#ifdef __cplusplus
| 218 |
| 219 |
#endif
| 220 |
#endif /* _RAD_RAY_H_ */
| 221 |
