root/Development/ray/src/rt/ray.h
Revision: 2.2
Committed: Sat Jan 4 19:53:55 1992 UTC (34 years ago) by greg
Changes since 2.1: +4 -3 lines
added specular sampling
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * ray.h - header file for routines using rays.
7 *
8 * 8/7/85
9 */
10
11 #include "standard.h"
12
13 #include "object.h"
14
15 #include "color.h"
16
17 /* ray type flags */
18 #define PRIMARY 01 /* original ray */
19 #define SHADOW 02 /* ray to light source */
20 #define REFLECTED 04 /* reflected ray */
21 #define REFRACTED 010 /* refracted (bent) ray */
22 #define TRANS 020 /* transmitted/transferred ray */
23 #define AMBIENT 040 /* ray scattered for interreflection */
24 #define SPECULAR 0100 /* ray scattered for specular */
25
26 /* reflected ray types */
27 #define RAYREFL (SHADOW|REFLECTED|AMBIENT|SPECULAR)
28
29 typedef struct ray {
30 long rno; /* unique ray number */
31 int rlvl; /* number of reflections for this ray */
32 float rweight; /* cumulative weight of this ray */
33 short rtype; /* ray type */
34 short crtype; /* cumulative ray type */
35 struct ray *parent; /* ray this originated from */
36 FVECT rorg; /* origin of ray */
37 FVECT rdir; /* normalized direction of ray */
38 int rsrc; /* source we're aiming for */
39 OBJECT *clipset; /* set of objects currently clipped */
40 OBJECT *newcset; /* next clipset, used for transmission */
41 int (*revf)(); /* evaluation function for this ray */
42 OBJREC *ro; /* intersected object */
43 double rot; /* distance to object */
44 FVECT rop; /* intersection point */
45 FVECT ron; /* intersection surface normal */
46 double rod; /* -DOT(rdir, ron) */
47 FULLXF *rox; /* object transformation */
48 FVECT pert; /* surface normal perturbation */
49 COLOR pcol; /* pattern color */
50 COLOR rcol; /* returned ray value */
51 double rt; /* returned effective ray length */
52 } RAY;
53
54 extern int raytrace();
55
56 extern double raynormal();
57
58 extern int dimlist[]; /* dimension list for distribution */
59 extern int ndims; /* number of dimensions so far */
60 extern int samplendx; /* index for this sample */
61
62 #define MAXDIM 32 /* maximum number of dimensions */
63
64 #define rayvalue(r) (*(r)->revf)(r)
