| 1 |
/* RCSid: $Id$ */
| 2 |
| 3 |
* ray.h - header file for routines using rays.
| 4 |
| 5 |
| 6 |
| 7 |
* The Radiance Software License, Version 1.0
| 8 |
| 9 |
* Copyright (c) 1990 - 2002 The Regents of the University of California,
| 10 |
* through Lawrence Berkeley National Laboratory. All rights reserved.
| 11 |
| 12 |
* Redistribution and use in source and binary forms, with or without
| 13 |
* modification, are permitted provided that the following conditions
| 14 |
* are met:
| 15 |
| 16 |
* 1. Redistributions of source code must retain the above copyright
| 17 |
* notice, this list of conditions and the following disclaimer.
| 18 |
| 19 |
* 2. Redistributions in binary form must reproduce the above copyright
| 20 |
* notice, this list of conditions and the following disclaimer in
| 21 |
* the documentation and/or other materials provided with the
| 22 |
* distribution.
| 23 |
| 24 |
* 3. The end-user documentation included with the redistribution,
| 25 |
* if any, must include the following acknowledgment:
| 26 |
* "This product includes Radiance software
| 27 |
* (http://radsite.lbl.gov/)
| 28 |
* developed by the Lawrence Berkeley National Laboratory
| 29 |
* (http://www.lbl.gov/)."
| 30 |
* Alternately, this acknowledgment may appear in the software itself,
| 31 |
* if and wherever such third-party acknowledgments normally appear.
| 32 |
| 33 |
* 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
| 34 |
* and "The Regents of the University of California" must
| 35 |
* not be used to endorse or promote products derived from this
| 36 |
* software without prior written permission. For written
| 37 |
* permission, please contact [email protected].
| 38 |
| 39 |
* 5. Products derived from this software may not be called "Radiance",
| 40 |
* nor may "Radiance" appear in their name, without prior written
| 41 |
* permission of Lawrence Berkeley National Laboratory.
| 42 |
| 43 |
* THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
| 44 |
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
| 45 |
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
| 46 |
* DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
| 47 |
* ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
| 48 |
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
| 49 |
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
| 50 |
* USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
| 51 |
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
| 52 |
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
| 53 |
* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
| 54 |
* SUCH DAMAGE.
| 55 |
| 56 |
| 57 |
* This software consists of voluntary contributions made by many
| 58 |
* individuals on behalf of Lawrence Berkeley National Laboratory. For more
| 59 |
* information on Lawrence Berkeley National Laboratory, please see
| 60 |
* <http://www.lbl.gov/>.
| 61 |
| 62 |
| 63 |
#include "standard.h"
| 64 |
| 65 |
#include "octree.h"
| 66 |
| 67 |
#include "object.h"
| 68 |
| 69 |
#include "color.h"
| 70 |
| 71 |
#define MAXDIM 32 /* maximum number of dimensions */
| 72 |
| 73 |
/* ray type flags */
| 74 |
#define PRIMARY 01 /* original ray */
| 75 |
#define SHADOW 02 /* ray to light source */
| 76 |
#define REFLECTED 04 /* reflected ray */
| 77 |
#define REFRACTED 010 /* refracted (bent) ray */
| 78 |
#define TRANS 020 /* transmitted/transferred ray */
| 79 |
#define AMBIENT 040 /* ray scattered for interreflection */
| 80 |
#define SPECULAR 0100 /* ray scattered for specular */
| 81 |
| 82 |
/* reflected ray types */
| 83 |
#define RAYREFL (SHADOW|REFLECTED|AMBIENT|SPECULAR)
| 84 |
| 85 |
typedef struct ray {
| 86 |
unsigned long rno; /* unique ray number */
| 87 |
int rlvl; /* number of reflections for this ray */
| 88 |
float rweight; /* cumulative weight of this ray */
| 89 |
short rtype; /* ray type */
| 90 |
short crtype; /* cumulative ray type */
| 91 |
struct ray *parent; /* ray this originated from */
| 92 |
FVECT rorg; /* origin of ray */
| 93 |
FVECT rdir; /* normalized direction of ray */
| 94 |
double rmax; /* maximum distance (aft clipping plane) */
| 95 |
int rsrc; /* source we're aiming for */
| 96 |
OBJECT *clipset; /* set of objects currently clipped */
| 97 |
OBJECT *newcset; /* next clipset, used for transmission */
| 98 |
void (*revf)(); /* evaluation function for this ray */
| 99 |
OBJECT robj; /* intersected object number */
| 100 |
OBJREC *ro; /* intersected object (one with material) */
| 101 |
double rot; /* distance to object */
| 102 |
FVECT rop; /* intersection point */
| 103 |
FVECT ron; /* intersection surface normal */
| 104 |
double rod; /* -DOT(rdir, ron) */
| 105 |
FULLXF *rox; /* object transformation */
| 106 |
FVECT pert; /* surface normal perturbation */
| 107 |
COLOR pcol; /* pattern color */
| 108 |
COLOR rcol; /* returned ray value */
| 109 |
double rt; /* returned effective ray length */
| 110 |
COLOR cext; /* medium extinction coefficient */
| 111 |
COLOR albedo; /* medium scattering albedo */
| 112 |
float gecc; /* scattering eccentricity coefficient */
| 113 |
int *slights; /* list of lights to test for scattering */
| 114 |
} RAY;
| 115 |
| 116 |
#define rayvalue(r) (*(r)->revf)(r)
| 117 |
| 118 |
extern char VersionID[]; /* Radiance version ID string */
| 119 |
| 120 |
extern CUBE thescene; /* our scene */
| 121 |
extern OBJECT nsceneobjs; /* number of objects in our scene */
| 122 |
| 123 |
extern unsigned long raynum; /* next ray ID */
| 124 |
extern unsigned long nrays; /* total rays traced so far */
| 125 |
| 126 |
extern OBJREC Lamb; /* a Lambertian surface */
| 127 |
extern OBJREC Aftplane; /* aft clipping object */
| 128 |
| 129 |
extern void (*trace)(); /* global trace reporting callback */
| 130 |
| 131 |
extern int dimlist[]; /* dimension list for distribution */
| 132 |
extern int ndims; /* number of dimensions so far */
| 133 |
extern int samplendx; /* index for this sample */
| 134 |
| 135 |
extern int ray_savesiz; /* size of parameter save buffer */
| 136 |
| 137 |
extern int do_irrad; /* compute irradiance? */
| 138 |
| 139 |
extern double dstrsrc; /* square source distribution */
| 140 |
extern double shadthresh; /* shadow threshold */
| 141 |
extern double shadcert; /* shadow testing certainty */
| 142 |
extern int directrelay; /* number of source relays */
| 143 |
extern int vspretest; /* virtual source pretest density */
| 144 |
extern int directvis; /* light sources visible to eye? */
| 145 |
extern double srcsizerat; /* maximum source size/dist. ratio */
| 146 |
| 147 |
extern double specthresh; /* specular sampling threshold */
| 148 |
extern double specjitter; /* specular sampling jitter */
| 149 |
| 150 |
extern COLOR cextinction; /* global extinction coefficient */
| 151 |
extern COLOR salbedo; /* global scattering albedo */
| 152 |
extern double seccg; /* global scattering eccentricity */
| 153 |
extern double ssampdist; /* scatter sampling distance */
| 154 |
| 155 |
extern int backvis; /* back face visibility */
| 156 |
| 157 |
extern int maxdepth; /* maximum recursion depth */
| 158 |
extern double minweight; /* minimum ray weight */
| 159 |
| 160 |
extern char *ambfile; /* ambient file name */
| 161 |
extern COLOR ambval; /* ambient value */
| 162 |
extern int ambvwt; /* initial weight for ambient value */
| 163 |
extern double ambacc; /* ambient accuracy */
| 164 |
extern int ambres; /* ambient resolution */
| 165 |
extern int ambdiv; /* ambient divisions */
| 166 |
extern int ambssamp; /* ambient super-samples */
| 167 |
extern int ambounce; /* ambient bounces */
| 168 |
extern char *amblist[]; /* ambient include/exclude list */
| 169 |
extern int ambincl; /* include == 1, exclude == 0 */
| 170 |
| 171 |
extern int ray_pnprocs; /* number of child processes */
| 172 |
extern int ray_pnidle; /* number of idle processes */
| 173 |
| 174 |
#define AMBLLEN 128 /* max. ambient list length */
| 175 |
#define AMBWORD 8 /* average word length */
| 176 |
| 177 |
typedef struct { /* rendering parameter holder */
| 178 |
int do_irrad;
| 179 |
double dstrsrc;
| 180 |
double shadthresh;
| 181 |
double shadcert;
| 182 |
int directrelay;
| 183 |
int vspretest;
| 184 |
int directvis;
| 185 |
double srcsizerat;
| 186 |
COLOR cextinction;
| 187 |
COLOR salbedo;
| 188 |
double seccg;
| 189 |
double ssampdist;
| 190 |
double specthresh;
| 191 |
double specjitter;
| 192 |
int backvis;
| 193 |
int maxdepth;
| 194 |
double minweight;
| 195 |
char ambfile[512];
| 196 |
COLOR ambval;
| 197 |
int ambvwt;
| 198 |
double ambacc;
| 199 |
int ambres;
| 200 |
int ambdiv;
| 201 |
int ambssamp;
| 202 |
int ambounce;
| 203 |
int ambincl;
| 204 |
short amblndx[AMBLLEN+1];
| 205 |
char amblval[AMBLLEN*AMBWORD];
| 206 |
} RAYPARAMS;
| 207 |
| 208 |
#define rpambmod(p,i) ( (i)>=AMBLLEN||(p)->amblndx[i]<0 ? \
| 209 |
(char *)NULL : (p)->amblval+(p)->amblndx[i] )
| 210 |
| 211 |
#ifdef NOPROTO
| 212 |
| 213 |
extern void headclean();
| 214 |
extern void openheader();
| 215 |
extern void dupheader();
| 216 |
extern void pfdetach();
| 217 |
extern void pfclean();
| 218 |
extern void pflock();
| 219 |
extern void pfhold();
| 220 |
extern void io_process();
| 221 |
extern int free_objs();
| 222 |
extern void free_objmem();
| 223 |
extern int load_os();
| 224 |
extern void preload_objs();
| 225 |
extern void ray_init();
| 226 |
extern void ray_trace();
| 227 |
extern void ray_done();
| 228 |
extern void ray_save();
| 229 |
extern void ray_restore();
| 230 |
extern void ray_defaults();
| 231 |
extern void ray_pinit();
| 232 |
extern void ray_psend();
| 233 |
extern int ray_pqueue();
| 234 |
extern int ray_presult();
| 235 |
extern void ray_pdone();
| 236 |
extern void ray_popen();
| 237 |
extern void ray_pclose();
| 238 |
extern int rayorigin();
| 239 |
extern void rayclear();
| 240 |
extern void raytrace();
| 241 |
extern void raycont();
| 242 |
extern void raytrans();
| 243 |
extern int rayshade();
| 244 |
extern void rayparticipate();
| 245 |
extern int raymixture();
| 246 |
extern double raydist();
| 247 |
extern double raynormal();
| 248 |
extern void newrayxf();
| 249 |
extern void flipsurface();
| 250 |
extern int localhit();
| 251 |
extern int getrenderopt();
| 252 |
extern void print_rdefaults();
| 253 |
extern void drawsources();
| 254 |
extern void rtrace();
| 255 |
extern void rview();
| 256 |
extern void rpict();
| 257 |
| 258 |
#else
| 259 |
/* defined in duphead.c */
| 260 |
extern void headclean(void);
| 261 |
extern void openheader(void);
| 262 |
extern void dupheader(void);
| 263 |
extern void pfdetach(void);
| 264 |
extern void pfclean(void);
| 265 |
extern void pflock(int lf);
| 266 |
extern void pfhold(void);
| 267 |
extern void io_process(void);
| 268 |
/* defined in freeobjmem.c */
| 269 |
extern int free_objs(OBJECT on, OBJECT no);
| 270 |
extern void free_objmem(void);
| 271 |
/* defined in preload.c */
| 272 |
extern int load_os(OBJREC *op);
| 273 |
extern void preload_objs(void);
| 274 |
/* defined in raycalls.c */
| 275 |
extern void ray_init(char *otnm);
| 276 |
extern void ray_trace(RAY *r);
| 277 |
extern void ray_done(int freall);
| 278 |
extern void ray_save(RAYPARAMS *rp);
| 279 |
extern void ray_restore(RAYPARAMS *rp);
| 280 |
extern void ray_defaults(RAYPARAMS *rp);
| 281 |
/* defined in raypcalls.c */
| 282 |
extern void ray_pinit(char *otnm, int nproc);
| 283 |
extern void ray_psend(RAY *r);
| 284 |
extern int ray_pqueue(RAY *r);
| 285 |
extern int ray_presult(RAY *r, int poll);
| 286 |
extern void ray_pdone(int freall);
| 287 |
extern void ray_popen(int nadd);
| 288 |
extern void ray_pclose(int nsub);
| 289 |
/* defined in raytrace.c */
| 290 |
extern int rayorigin(RAY *r, RAY *ro, int rt, double rw);
| 291 |
extern void rayclear(RAY *r);
| 292 |
extern void raytrace(RAY *r);
| 293 |
extern void raycont(RAY *r);
| 294 |
extern void raytrans(RAY *r);
| 295 |
extern int rayshade(RAY *r, int mod);
| 296 |
extern void rayparticipate(RAY *r);
| 297 |
extern int raymixture(RAY *r, OBJECT fore, OBJECT back, double coef);
| 298 |
extern double raydist(RAY *r, int flags);
| 299 |
extern double raynormal(FVECT norm, RAY *r);
| 300 |
extern void newrayxf(RAY *r);
| 301 |
extern void flipsurface(RAY *r);
| 302 |
extern int localhit(RAY *r, CUBE *scene);
| 303 |
/* defined in renderopts.c */
| 304 |
extern int getrenderopt(int ac, char *av[]);
| 305 |
extern void print_rdefaults(void);
| 306 |
/* defined in srcdraw.c */
| 307 |
extern void drawsources(COLOR *pic[], float *zbf[],
| 308 |
int x0, int xsiz, int y0, int ysiz);
| 309 |
/* module main procedures */
| 310 |
extern void rtrace(char *fname);
| 311 |
extern void rview(void);
| 312 |
extern void rpict(int seq, char *pout, char *zout, char *prvr);
| 313 |
| 314 |
#endif
