root/Development/ray/src/rt/ray.h
Revision 2.62 - (view) (download) (annotate) - [selected]
Fri Jun 20 18:05:30 2025 UTC (6 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.61: +3 -3 lines
Diff to previous 2.61
refactor: Changed macros to function type for clarity
Fri Jun 20 16:48:39 2025 UTC (6 months, 2 weeks ago) by greg
Changes since 2.60: +2 -1 lines
Diff to previous 2.60 , to selected 2.62
fix: Last change would have caused array underrun
Fri Jun 20 16:34:23 2025 UTC (6 months, 2 weeks ago) by greg
Changes since 2.59: +4 -2 lines
Diff to previous 2.59 , to selected 2.62
fix: Avoid array bounds errors in dimlist[] in deep ray trees
Fri Jun 20 03:43:17 2025 UTC (6 months, 2 weeks ago) by greg
Changes since 2.58: +4 -2 lines
Diff to previous 2.58 , to selected 2.62
fix(rvu): Issue with live reset of -u boolean and consistency improvements
Sat Jan 18 03:49:00 2025 UTC (11 months, 2 weeks ago) by greg
Changes since 2.57: +1 -4 lines
Diff to previous 2.57 , to selected 2.62
refactor: Removed experimental SRCSKIPOPT code
Fri Nov 15 20:47:42 2024 UTC (13 months, 2 weeks ago) by greg
Changes since 2.56: +5 -2 lines
Diff to previous 2.56 , to selected 2.62
Wed Aug 21 20:42:20 2024 UTC (16 months, 1 week ago) by greg
Changes since 2.55: +4 -1 lines
Diff to previous 2.55 , to selected 2.62
refactor: moved memory sharing routines to preload.c with common call interface
Mon Aug 12 18:57:00 2024 UTC (16 months, 3 weeks ago) by greg
Changes since 2.54: +3 -3 lines
Diff to previous 2.54 , to selected 2.62
fix(rpict): Fixed light source drawing in non-RGB color spaces
Wed Jul 31 22:21:28 2024 UTC (17 months ago) by greg
Diff to previous 2.53 , to selected 2.62
fix(rpict): Fixed multi-spectral source drawing bug recently introduced
Tue Jul 2 23:54:16 2024 UTC (18 months ago) by greg
Changes since 2.52: +2 -2 lines
Diff to previous 2.52 , to selected 2.62
feat(rpict): Made drawsources() compatible with spectral scanlines
Fri Apr 5 01:10:26 2024 UTC (20 months, 4 weeks ago) by greg
Changes since 2.51: +13 -5 lines
Diff to previous 2.51 , to selected 2.62
fix: Improved tracking of reflected vs. transmitted rays for antimatter
Wed Nov 15 18:02:53 2023 UTC (2 years, 1 month ago) by greg
Changes since 2.50: +9 -9 lines
Diff to previous 2.50 , to selected 2.62
Thu Mar 16 00:25:24 2023 UTC (2 years, 9 months ago) by greg
Diff to previous 2.49 , to selected 2.62
feat: Added test for which side of flat surface is seen in case of coincident surfaces
Mon Feb 6 22:40:21 2023 UTC (2 years, 10 months ago) by greg
Diff to previous 2.48 , to selected 2.62
Tue Nov 22 02:28:03 2022 UTC (3 years, 1 month ago) by greg
Diff to previous 2.47 , to selected 2.62
fix: Changed RNUMBER to size_t to be more portable across systems
Wed Oct 19 21:25:20 2022 UTC (3 years, 2 months ago) by greg
Changes since 2.46: +4 -2 lines
Diff to previous 2.46 , to selected 2.62
Fri Sep 23 21:53:34 2022 UTC (3 years, 3 months ago) by greg
Changes since 2.45: +4 -6 lines
Diff to previous 2.45 , to selected 2.62
refactor: removed unreferenced external symbol
Sun Jan 31 18:08:04 2021 UTC (4 years, 11 months ago) by greg
Diff to previous 2.44 , to selected 2.62
feat: added consistent handling of coincident surfaces, thanks to Peter A-B
Tue Jun 16 17:58:11 2020 UTC (5 years, 6 months ago) by greg
Changes since 2.43: +1 -2 lines
Diff to previous 2.43 , to selected 2.62
Backed out last change, which actually made things worse
Mon Jun 15 15:44:03 2020 UTC (5 years, 6 months ago) by greg
Changes since 2.42: +2 -1 lines
Diff to previous 2.42 , to selected 2.62
Optimize rtrace for throughput, especially with ambient cache
Wed Feb 26 17:58:06 2020 UTC (5 years, 10 months ago) by greg
Changes since 2.41: +5 -5 lines
Diff to previous 2.41 , to selected 2.62
Struct member ordering
Thu Jul 25 16:50:54 2019 UTC (6 years, 5 months ago) by greg
Changes since 2.40: +5 -2 lines
Diff to previous 2.40 , to selected 2.62
Keep track of ray flips so rayreorient() can put it back as it was
Wed Dec 5 02:12:23 2018 UTC (7 years, 1 month ago) by greg
Changes since 2.39: +2 -1 lines
Diff to previous 2.39 , to selected 2.62
Created raytirrad() call to take care of irradiance hack
Tue Nov 13 19:58:33 2018 UTC (7 years, 1 month ago) by greg
Changes since 2.38: +7 -2 lines
Diff to previous 2.38 , to selected 2.62
Tue Feb 24 19:39:27 2015 UTC (10 years, 10 months ago) by greg
Changes since 2.37: +5 -1 lines
Diff to previous 2.37 , to selected 2.62
Wed Jun 29 13:41:26 2011 UTC (14 years, 6 months ago) by greg
Changes since 2.36: +3 -3 lines
Diff to previous 2.36 , to selected 2.62
Making gcc -Wall happy
Wed Apr 6 00:14:26 2011 UTC (14 years, 9 months ago) by greg
Diff to previous 2.35 , to selected 2.62
Improved output efficiency by reducing number of calls to fwrite()
Tue Oct 26 03:45:35 2010 UTC (15 years, 2 months ago) by greg
Diff to previous 2.34 , to selected 2.62
Bug fix in l+ option of mkillum under Windows
Sun Sep 26 15:51:15 2010 UTC (15 years, 3 months ago) by greg
Changes since 2.33: +6 -1 lines
Diff to previous 2.33 , to selected 2.62
Tue Dec 15 18:21:53 2009 UTC (16 years ago) by greg
Diff to previous 2.32 , to selected 2.62
Final fix to problem of queue overflow (I hope)
Sun Dec 13 19:13:04 2009 UTC (16 years ago) by greg
Diff to previous 2.31 , to selected 2.62
Sat Dec 12 05:20:10 2009 UTC (16 years ago) by greg
Changes since 2.30: +5 -1 lines
Diff to previous 2.30 , to selected 2.62
Sat Dec 12 00:03:42 2009 UTC (16 years ago) by greg
Changes since 2.29: +6 -2 lines
Diff to previous 2.29 , to selected 2.62
Fri Sep 23 19:04:53 2005 UTC (20 years, 3 months ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 2.28: +22 -19 lines
Diff to previous 2.28 , to selected 2.62
Tue Jun 21 15:06:50 2005 UTC (20 years, 6 months ago) by greg
Diff to previous 2.27 , to selected 2.62
Fixed bugs in black glass transmission and source weight computation
Mon Jun 13 20:07:56 2005 UTC (20 years, 6 months ago) by greg
Changes since 2.26: +4 -1 lines
Diff to previous 2.26 , to selected 2.62
Thu May 26 06:55:22 2005 UTC (20 years, 7 months ago) by greg
Changes since 2.25: +5 -2 lines
Diff to previous 2.25 , to selected 2.62
Tue Apr 19 01:15:06 2005 UTC (20 years, 8 months ago) by greg
Changes since 2.24: +7 -5 lines
Diff to previous 2.24 , to selected 2.62
Fri Apr 15 04:44:51 2005 UTC (20 years, 8 months ago) by greg
Changes since 2.23: +3 -6 lines
Diff to previous 2.23 , to selected 2.62
Fri Nov 5 17:36:55 2004 UTC (21 years, 2 months ago) by greg
Changes since 2.22: +5 -3 lines
Diff to previous 2.22 , to selected 2.62
Tue Mar 30 16:13:01 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 2.21: +7 -1 lines
Diff to previous 2.21 , to selected 2.62
Thu Aug 28 03:22:16 2003 UTC (22 years, 4 months ago) by greg
Diff to previous 2.20 , to selected 2.62
Created proper prototypes for function pointers and included missing headers
Mon Jul 14 22:24:00 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 2.19: +5 -7 lines
Diff to previous 2.19 , to selected 2.62
Fri Jun 27 06:53:22 2003 UTC (22 years, 6 months ago) by greg
Changes since 2.18: +1 -4 lines
Diff to previous 2.18 , to selected 2.62
Thu Jun 26 00:58:10 2003 UTC (22 years, 6 months ago) by schorsch
Diff to previous 2.17 , to selected 2.62
Sat Jun 7 00:54:58 2003 UTC (22 years, 7 months ago) by schorsch
Changes since 2.16: +12 -51 lines
Diff to previous 2.16 , to selected 2.62
Removed NOPROTO sections.
Fri May 9 22:18:03 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.15: +2 -0 lines
Diff to previous 2.15 , to selected 2.62
Added missing prototype for raytexture()
Tue Mar 11 17:08:55 2003 UTC (22 years, 9 months ago) by greg
Changes since 2.14: +1 -0 lines
Diff to previous 2.14 , to selected 2.62
Tue Mar 4 19:02:22 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.13: +3 -0 lines
Diff to previous 2.13 , to selected 2.62
Modified new ray hit interface to check whole sets at a time
Tue Feb 25 02:47:23 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.12: +2 -57 lines
Diff to previous 2.12 , to selected 2.62
Sat Feb 22 02:07:29 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.11: +279 -37 lines
Diff to previous 2.11 , to selected 2.62
Fri Mar 7 16:53:02 1997 UTC (28 years, 10 months ago) by greg
Diff to previous 2.10 , to selected 2.62
comment change
Fri Mar 7 16:42:54 1997 UTC (28 years, 10 months ago) by greg
Diff to previous 2.9 , to selected 2.62
added intersected object number for tracking instances
Wed Jun 5 11:27:30 1996 UTC (29 years, 7 months ago) by greg
Changes since 2.8: +0 -2 lines
Diff to previous 2.8 , to selected 2.62
moved MAXSLIST macro to m_mist.c routine
Wed Apr 17 14:01:51 1996 UTC (29 years, 8 months ago) by greg
Diff to previous 2.7 , to selected 2.62
Wed Mar 27 12:17:10 1996 UTC (29 years, 9 months ago) by greg
Diff to previous 2.6 , to selected 2.62
fixed declaration of raydist()
Sat Dec 9 09:35:00 1995 UTC (30 years, 1 month ago) by greg
Diff to previous 2.5 , to selected 2.62
Thu Nov 2 17:38:07 1995 UTC (30 years, 2 months ago) by greg
Diff to previous 2.4 , to selected 2.62
added raydist() function
Tue Dec 20 20:18:20 1994 UTC (31 years ago) by greg
Diff to previous 2.3 , to selected 2.62
Tue May 25 10:30:14 1993 UTC (32 years, 7 months ago) by greg
Diff to previous 2.2 , to selected 2.62
Sat Jan 4 19:53:55 1992 UTC (34 years ago) by greg
Changes since 2.1: +4 -3 lines
Diff to previous 2.1 , to selected 2.62
added specular sampling
Tue Nov 12 17:10:16 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.6 , to selected 2.62
Thu Jun 20 13:29:31 1991 UTC (34 years, 6 months ago) by greg
Diff to previous 1.5 , to selected 2.62
added revf member to ray structure for dynamic evaluation
Thu May 23 08:12:57 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.4: +6 -0 lines
Diff to previous 1.4 , to selected 2.62
added MAXDIM
Sat Dec 15 16:41:44 1990 UTC (35 years ago) by greg
Changes since 1.3: +2 -5 lines
Diff to previous 1.3 , to selected 2.62
Thu Mar 22 20:07:01 1990 UTC (35 years, 9 months ago) by greg
Diff to previous 1.2 , to selected 2.62
added rt field for effective ray length
Tue Apr 11 13:16:43 1989 UTC (36 years, 9 months ago) by greg
Changes since 1.1: +4 -1 lines
Diff to previous 1.1 , to selected 2.62
added forward object transform
Thu Feb 2 10:41:14 1989 UTC (36 years, 11 months ago) by greg
Diff to selected 2.62
