--- ray/src/rt/ray.h 2018/11/13 19:58:33 2.39 +++ ray/src/rt/ray.h 2024/08/12 18:57:00 2.55 @@ -1,4 +1,4 @@ -/* RCSid $Id: ray.h,v 2.39 2018/11/13 19:58:33 greg Exp $ */ +/* RCSid $Id: ray.h,v 2.55 2024/08/12 18:57:00 greg Exp $ */ /* * ray.h - header file for routines using rays. */ @@ -16,22 +16,28 @@ extern "C" { #endif #ifndef RNUMBER -#define RNUMBER unsigned long /* ray counter (>= sizeof pointer) */ +#define RNUMBER size_t /* ray counter (>= sizeof pointer) */ #endif -#define MAXDIM 32 /* maximum number of dimensions */ +#define MAXDIM 32 /* maximum number of sampling dimensions */ /* ray type flags */ #define PRIMARY 01 /* original ray */ -#define SHADOW 02 /* ray to light source */ +#define RSHADOW 02 /* reflected ray to light source */ #define REFLECTED 04 /* reflected ray */ #define REFRACTED 010 /* refracted (bent) ray */ #define TRANS 020 /* transmitted/transferred ray */ -#define AMBIENT 040 /* ray scattered for interreflection */ -#define SPECULAR 0100 /* ray scattered for specular */ +#define RAMBIENT 040 /* reflected diffuse interreflection */ +#define RSPECULAR 0100 /* reflected specular */ +#define TSHADOW 0200 /* transmitted shadow */ +#define TAMBIENT 0400 /* transmitted ambient */ +#define TSPECULAR 01000 /* transmitted specular */ +#define SHADOW (RSHADOW|TSHADOW) +#define AMBIENT (RAMBIENT|TAMBIENT) +#define SPECULAR (RSPECULAR|TSPECULAR) /* reflected ray types */ -#define RAYREFL (SHADOW|REFLECTED|AMBIENT|SPECULAR) +#define RAYREFL (RSHADOW|REFLECTED|RAMBIENT|RSPECULAR) /* Arrange so double's come first for optimal alignment */ /* Pointers and long's come second for 64-bit mode */ @@ -57,28 +63,34 @@ typedef struct ray { FULLXF *rox; /* object transformation */ int *slights; /* list of lights to test for scattering */ RNUMBER rno; /* unique ray number */ - int rlvl; /* number of reflections for this ray */ + OBJECT robj; /* intersected object number */ int rsrc; /* source we're aiming for */ float rweight; /* cumulative weight (for termination) */ - COLOR rcoef; /* contribution coefficient w.r.t. parent */ - COLOR pcol; /* pattern color */ - COLOR mcol; /* mirrored color contribution */ - COLOR rcol; /* returned radiance value */ + float gecc; /* scattering eccentricity coefficient */ + SCOLOR rcoef; /* contribution coefficient w.r.t. parent */ + SCOLOR pcol; /* pattern color */ + SCOLOR mcol; /* mirrored color contribution */ + SCOLOR rcol; /* returned radiance value */ COLOR cext; /* medium extinction coefficient */ COLOR albedo; /* medium scattering albedo */ - float gecc; /* scattering eccentricity coefficient */ - OBJECT robj; /* intersected object number */ + short rflips; /* surface orientation has been reversed */ + short rlvl; /* number of reflections for this ray */ short rtype; /* ray type */ short crtype; /* cumulative ray type */ } RAY; #define rayvalue(r) (*(r)->revf)(r) -#define raydistance(r) (bright((r)->mcol) > 0.5*bright((r)->rcol) ? \ +#define thrudir(r,v) ((r)->rod > 0 ^ DOT((r)->ron,v) > 0) + +#define raydistance(r) (pbright((r)->mcol) > 0.5*pbright((r)->rcol) ? \ (r)->rmt : (r)->rxt) -extern char VersionID[]; /* Radiance version ID string */ +#define rayreorient(r) if ((r)->rflips & 1) flipsurface(r); else +extern char VersionID[]; /* Radiance version ID string */ +extern char RFeatureList[]; /* newline-separated feature list */ + extern CUBE thescene; /* our scene */ extern OBJECT nsceneobjs; /* number of objects in our scene */ @@ -88,14 +100,12 @@ extern RNUMBER nrays; /* total rays traced so far */ extern OBJREC Lamb; /* a Lambertian surface */ extern OBJREC Aftplane; /* aft clipping object */ -extern void (*trace)(); /* global trace reporting callback */ +extern void (*trace)(RAY*); /* global trace reporting callback */ extern int dimlist[]; /* dimension list for distribution */ extern int ndims; /* number of dimensions so far */ extern int samplendx; /* index for this sample */ -extern int ray_savesiz; /* size of parameter save buffer */ - extern int do_irrad; /* compute irradiance? */ extern int rand_samp; /* pure Monte Carlo sampling? */ @@ -183,7 +193,7 @@ extern void headclean(void); extern void openheader(void); extern void dupheader(void); /* defined in persist.c */ -extern void persistfile(char *pfn); +extern void persistfile(char *pfn); extern void pfdetach(void); extern void pfclean(void); extern void pflock(int lf); @@ -215,34 +225,37 @@ extern int (*ray_fifo_out)(RAY *r); extern int ray_fifo_in(RAY *r); extern int ray_fifo_flush(void); /* defined in raytrace.c */ -extern int rayorigin(RAY *r, int rt, const RAY *ro, const COLOR rc); +extern int rayorigin(RAY *r, int rt, const RAY *ro, const SCOLOR rc); extern void rayclear(RAY *r); extern void raytrace(RAY *r); +extern int rayreject(OBJREC *o, RAY *r, double t, double rod); extern void rayhit(OBJECT *oset, RAY *r); extern void raycont(RAY *r); extern void raytrans(RAY *r); +extern int raytirrad(OBJREC *m, RAY *r); extern int rayshade(RAY *r, int mod); extern void rayparticipate(RAY *r); extern void raytexture(RAY *r, OBJECT mod); extern int raymixture(RAY *r, OBJECT fore, OBJECT back, double coef); -extern void raycontrib(RREAL rc[3], const RAY *r, int flags); +extern void raycontrib(SCOLOR rc, const RAY *r, int flags); extern double raydist(const RAY *r, int flags); extern double raynormal(FVECT norm, RAY *r); extern void newrayxf(RAY *r); extern void flipsurface(RAY *r); extern int localhit(RAY *r, CUBE *scene); /* defined in renderopts.c */ +extern int feature_status(int ac, char *av[]); extern int getrenderopt(int ac, char *av[]); extern void print_rdefaults(void); /* defined in srcdraw.c */ -extern void drawsources(COLOR *pic[], float *zbf[], +extern void init_drawsources(int rad); +extern void drawsources(COLORV *pic[], RGBPRIMP primp, float *zbf[], int x0, int xsiz, int y0, int ysiz); -extern void init_drawsources(int rad); /* defined in rt/initotypes.c */ -extern void initotypes(void); +extern void initotypes(void); /* module main procedures */ extern void rtrace(char *fname, int nproc); -extern char *formstr(int f); +extern const char *formstr(int f); extern void rview(void); extern void rpict(int seq, char *pout, char *zout, char *prvr);
