--- ray/src/rt/ray.h 2005/04/15 04:44:51 2.24 +++ ray/src/rt/ray.h 2023/11/15 18:02:53 2.51 @@ -1,4 +1,4 @@ -/* RCSid $Id: ray.h,v 2.24 2005/04/15 04:44:51 greg Exp $ */ +/* RCSid $Id: ray.h,v 2.51 2023/11/15 18:02:53 greg Exp $ */ /* * ray.h - header file for routines using rays. */ @@ -9,13 +9,18 @@ #include "octree.h" #include "object.h" #include "color.h" +#include "pmapparm.h" #ifdef __cplusplus extern "C" { #endif -#define MAXDIM 32 /* maximum number of dimensions */ +#ifndef RNUMBER +#define RNUMBER size_t /* ray counter (>= sizeof pointer) */ +#endif +#define MAXDIM 32 /* maximum number of sampling dimensions */ + /* ray type flags */ #define PRIMARY 01 /* original ray */ #define SHADOW 02 /* ray to light source */ @@ -28,59 +33,75 @@ extern "C" { /* reflected ray types */ #define RAYREFL (SHADOW|REFLECTED|AMBIENT|SPECULAR) +/* Arrange so double's come first for optimal alignment */ +/* Pointers and long's come second for 64-bit mode */ +/* Int's next (unknown length), then floats, followed by short's & char's */ typedef struct ray { - unsigned long rno; /* unique ray number */ - int rlvl; /* number of reflections for this ray */ - float rweight; /* cumulative weight of this ray */ - short rtype; /* ray type */ - short crtype; /* cumulative ray type */ - struct ray *parent; /* ray this originated from */ FVECT rorg; /* origin of ray */ FVECT rdir; /* normalized direction of ray */ - double rmax; /* maximum distance (aft clipping plane) */ - int rsrc; /* source we're aiming for */ + RREAL rmax; /* maximum distance (aft clipping plane) */ + RREAL rot; /* distance to object */ + FVECT rop; /* intersection point */ + FVECT ron; /* intersection surface normal */ + RREAL rod; /* -DOT(rdir, ron) */ + RREAL uv[2]; /* local coordinates */ + FVECT pert; /* surface normal perturbation */ + RREAL rmt; /* returned mirrored ray length */ + RREAL rxt; /* returned unmirrored ray length */ + const struct ray *parent; /* ray this originated from */ OBJECT *clipset; /* set of objects currently clipped */ OBJECT *newcset; /* next clipset, used for transmission */ + void (*revf)(struct ray *); /* ray evaluation function */ void (*hitf)(OBJECT *, struct ray *); /* custom hit test */ - OBJECT robj; /* intersected object number */ OBJREC *ro; /* intersected object (one with material) */ - double rot; /* distance to object */ - FVECT rop; /* intersection point */ - FVECT ron; /* intersection surface normal */ - double rod; /* -DOT(rdir, ron) */ FULLXF *rox; /* object transformation */ - RREAL uv[2]; /* local coordinates */ - FVECT pert; /* surface normal perturbation */ - COLOR pcol; /* pattern color */ - COLOR rcol; /* returned radiance value */ - double rt; /* returned effective ray length */ + int *slights; /* list of lights to test for scattering */ + RNUMBER rno; /* unique ray number */ + OBJECT robj; /* intersected object number */ + int rsrc; /* source we're aiming for */ + float rweight; /* cumulative weight (for termination) */ + float gecc; /* scattering eccentricity coefficient */ + SCOLOR rcoef; /* contribution coefficient w.r.t. parent */ + SCOLOR pcol; /* pattern color */ + SCOLOR mcol; /* mirrored color contribution */ + SCOLOR rcol; /* returned radiance value */ COLOR cext; /* medium extinction coefficient */ COLOR albedo; /* medium scattering albedo */ - float gecc; /* scattering eccentricity coefficient */ - int *slights; /* list of lights to test for scattering */ + short rflips; /* surface orientation has been reversed */ + short rlvl; /* number of reflections for this ray */ + short rtype; /* ray type */ + short crtype; /* cumulative ray type */ } RAY; -extern char VersionID[]; /* Radiance version ID string */ +#define rayvalue(r) (*(r)->revf)(r) +#define raydistance(r) (pbright((r)->mcol) > 0.5*pbright((r)->rcol) ? \ + (r)->rmt : (r)->rxt) + +#define rayreorient(r) if ((r)->rflips & 1) flipsurface(r); else + +extern char VersionID[]; /* Radiance version ID string */ +extern char RFeatureList[]; /* newline-separated feature list */ + extern CUBE thescene; /* our scene */ extern OBJECT nsceneobjs; /* number of objects in our scene */ -extern unsigned long raynum; /* next ray ID */ -extern unsigned long nrays; /* total rays traced so far */ +extern RNUMBER raynum; /* next ray ID */ +extern RNUMBER nrays; /* total rays traced so far */ extern OBJREC Lamb; /* a Lambertian surface */ extern OBJREC Aftplane; /* aft clipping object */ -extern void (*trace)(); /* global trace reporting callback */ +extern void (*trace)(RAY*); /* global trace reporting callback */ extern int dimlist[]; /* dimension list for distribution */ extern int ndims; /* number of dimensions so far */ extern int samplendx; /* index for this sample */ -extern int ray_savesiz; /* size of parameter save buffer */ - extern int do_irrad; /* compute irradiance? */ +extern int rand_samp; /* pure Monte Carlo sampling? */ + extern double dstrsrc; /* square source distribution */ extern double shadthresh; /* shadow threshold */ extern double shadcert; /* shadow testing certainty */ @@ -123,6 +144,7 @@ extern int ray_pnidle; /* number of idle processes */ typedef struct { /* rendering parameter holder */ int do_irrad; + int rand_samp; double dstrsrc; double shadthresh; double shadcert; @@ -150,6 +172,9 @@ typedef struct { /* rendering parameter holder */ int ambincl; short amblndx[AMBLLEN+1]; char amblval[AMBLLEN*AMBWORD]; + + /* PMAP: photon mapping parameters */ + PhotonMapParams pmapParams [NUM_PMAP_TYPES]; } RAYPARAMS; #define rpambmod(p,i) ( (i)>=AMBLLEN||(p)->amblndx[i]<0 ? \ @@ -160,7 +185,7 @@ extern void headclean(void); extern void openheader(void); extern void dupheader(void); /* defined in persist.c */ -extern void persistfile(char *pfn); +extern void persistfile(char *pfn); extern void pfdetach(void); extern void pfclean(void); extern void pflock(int lf); @@ -181,43 +206,56 @@ extern void ray_restore(RAYPARAMS *rp); extern void ray_defaults(RAYPARAMS *rp); /* defined in raypcalls.c */ extern void ray_pinit(char *otnm, int nproc); -extern void ray_psend(RAY *r); +extern int ray_psend(RAY *r); extern int ray_pqueue(RAY *r); extern int ray_presult(RAY *r, int poll); extern void ray_pdone(int freall); extern void ray_popen(int nadd); extern void ray_pclose(int nsub); + /* defined in ray_fifo.c */ +extern int (*ray_fifo_out)(RAY *r); +extern int ray_fifo_in(RAY *r); +extern int ray_fifo_flush(void); /* defined in raytrace.c */ -extern int rayorigin(RAY *r, RAY *ro, int rt, double rw); +extern int rayorigin(RAY *r, int rt, const RAY *ro, const SCOLOR rc); extern void rayclear(RAY *r); -extern void rayvalue(RAY *r); +extern void raytrace(RAY *r); +extern int rayreject(OBJREC *o, RAY *r, double t, double rod); extern void rayhit(OBJECT *oset, RAY *r); extern void raycont(RAY *r); extern void raytrans(RAY *r); +extern int raytirrad(OBJREC *m, RAY *r); extern int rayshade(RAY *r, int mod); extern void rayparticipate(RAY *r); extern void raytexture(RAY *r, OBJECT mod); extern int raymixture(RAY *r, OBJECT fore, OBJECT back, double coef); -extern double raydist(RAY *r, int flags); +extern void raycontrib(SCOLOR rc, const RAY *r, int flags); +extern double raydist(const RAY *r, int flags); extern double raynormal(FVECT norm, RAY *r); extern void newrayxf(RAY *r); extern void flipsurface(RAY *r); extern int localhit(RAY *r, CUBE *scene); /* defined in renderopts.c */ +extern int feature_status(int ac, char *av[]); extern int getrenderopt(int ac, char *av[]); extern void print_rdefaults(void); /* defined in srcdraw.c */ extern void drawsources(COLOR *pic[], float *zbf[], int x0, int xsiz, int y0, int ysiz); -extern void init_drawsources(int rad); +extern void init_drawsources(int rad); /* defined in rt/initotypes.c */ -extern void initotypes(void); +extern void initotypes(void); /* module main procedures */ -extern void rtrace(char *fname); -extern char * formstr(int f); +extern void rtrace(char *fname, int nproc); +extern const char *formstr(int f); extern void rview(void); extern void rpict(int seq, char *pout, char *zout, char *prvr); +#ifdef __FAST_MATH__ +#define checknorm(vn) (void)normalize(vn) +#else +#define checknorm(vn) +#endif #ifdef __cplusplus }
