root/radiance/ray/src/rt/ray.h
Thu Mar 16 00:25:24 2023 UTC (14 months, 4 weeks ago) by greg
Diff to previous 2.49 , to selected 2.37
feat: Added test for which side of flat surface is seen in case of coincident surfaces
Mon Feb 6 22:40:21 2023 UTC (16 months ago) by greg
Diff to previous 2.48 , to selected 2.37
Tue Nov 22 02:28:03 2022 UTC (18 months, 3 weeks ago) by greg
Diff to previous 2.47 , to selected 2.37
fix: Changed RNUMBER to size_t to be more portable across systems
Wed Oct 19 21:25:20 2022 UTC (19 months, 3 weeks ago) by greg
Changes since 2.46: +4 -2 lines
Diff to previous 2.46 , to selected 2.37
Fri Sep 23 21:53:34 2022 UTC (20 months, 2 weeks ago) by greg
Changes since 2.45: +4 -6 lines
Diff to previous 2.45 , to selected 2.37
refactor: removed unreferenced external symbol
Sun Jan 31 18:08:04 2021 UTC (3 years, 4 months ago) by greg
Diff to previous 2.44 , to selected 2.37
feat: added consistent handling of coincident surfaces, thanks to Peter A-B
Tue Jun 16 17:58:11 2020 UTC (3 years, 11 months ago) by greg
Changes since 2.43: +1 -2 lines
Diff to previous 2.43 , to selected 2.37
Backed out last change, which actually made things worse
Mon Jun 15 15:44:03 2020 UTC (3 years, 11 months ago) by greg
Changes since 2.42: +2 -1 lines
Diff to previous 2.42 , to selected 2.37
Optimize rtrace for throughput, especially with ambient cache
Wed Feb 26 17:58:06 2020 UTC (4 years, 3 months ago) by greg
Changes since 2.41: +5 -5 lines
Diff to previous 2.41 , to selected 2.37
Struct member ordering
Thu Jul 25 16:50:54 2019 UTC (4 years, 10 months ago) by greg
Changes since 2.40: +5 -2 lines
Diff to previous 2.40 , to selected 2.37
Keep track of ray flips so rayreorient() can put it back as it was
Wed Dec 5 02:12:23 2018 UTC (5 years, 6 months ago) by greg
Changes since 2.39: +2 -1 lines
Diff to previous 2.39 , to selected 2.37
Created raytirrad() call to take care of irradiance hack
Tue Nov 13 19:58:33 2018 UTC (5 years, 7 months ago) by greg
Changes since 2.38: +7 -2 lines
Diff to previous 2.38 , to selected 2.37
Tue Feb 24 19:39:27 2015 UTC (9 years, 3 months ago) by greg
Changes since 2.37: +5 -1 lines
Diff to previous 2.37
Revision 2.37 - (view) (download) (annotate) - [selected]
Wed Jun 29 13:41:26 2011 UTC (12 years, 11 months ago) by greg
Changes since 2.36: +3 -3 lines
Diff to previous 2.36
Making gcc -Wall happy
Wed Apr 6 00:14:26 2011 UTC (13 years, 2 months ago) by greg
Diff to previous 2.35 , to selected 2.37
Improved output efficiency by reducing number of calls to fwrite()
Tue Oct 26 03:45:35 2010 UTC (13 years, 7 months ago) by greg
Diff to previous 2.34 , to selected 2.37
Bug fix in l+ option of mkillum under Windows
Sun Sep 26 15:51:15 2010 UTC (13 years, 8 months ago) by greg
Changes since 2.33: +6 -1 lines
Diff to previous 2.33 , to selected 2.37
Tue Dec 15 18:21:53 2009 UTC (14 years, 6 months ago) by greg
Diff to previous 2.32 , to selected 2.37
Final fix to problem of queue overflow (I hope)
Sun Dec 13 19:13:04 2009 UTC (14 years, 6 months ago) by greg
Diff to previous 2.31 , to selected 2.37
Sat Dec 12 05:20:10 2009 UTC (14 years, 6 months ago) by greg
Changes since 2.30: +5 -1 lines
Diff to previous 2.30 , to selected 2.37
Sat Dec 12 00:03:42 2009 UTC (14 years, 6 months ago) by greg
Changes since 2.29: +6 -2 lines
Diff to previous 2.29 , to selected 2.37
Fri Sep 23 19:04:53 2005 UTC (18 years, 8 months ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 2.28: +22 -19 lines
Diff to previous 2.28 , to selected 2.37
Tue Jun 21 15:06:50 2005 UTC (18 years, 11 months ago) by greg
Diff to previous 2.27 , to selected 2.37
Fixed bugs in black glass transmission and source weight computation
Mon Jun 13 20:07:56 2005 UTC (19 years ago) by greg
Changes since 2.26: +4 -1 lines
Diff to previous 2.26 , to selected 2.37
Thu May 26 06:55:22 2005 UTC (19 years ago) by greg
Changes since 2.25: +5 -2 lines
Diff to previous 2.25 , to selected 2.37
Changes since 2.24: +7 -5 lines
Diff to previous 2.24 , to selected 2.37
Fri Apr 15 04:44:51 2005 UTC (19 years, 2 months ago) by greg
Changes since 2.23: +3 -6 lines
Diff to previous 2.23 , to selected 2.37
Fri Nov 5 17:36:55 2004 UTC (19 years, 7 months ago) by greg
Changes since 2.22: +5 -3 lines
Diff to previous 2.22 , to selected 2.37
Changes since 2.21: +7 -1 lines
Diff to previous 2.21 , to selected 2.37
Thu Aug 28 03:22:16 2003 UTC (20 years, 9 months ago) by greg
Diff to previous 2.20 , to selected 2.37
Created proper prototypes for function pointers and included missing headers
Mon Jul 14 22:24:00 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.19: +5 -7 lines
Diff to previous 2.19 , to selected 2.37
Fri Jun 27 06:53:22 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.18: +1 -4 lines
Diff to previous 2.18 , to selected 2.37
Diff to previous 2.17 , to selected 2.37
Sat Jun 7 00:54:58 2003 UTC (21 years ago) by schorsch
Changes since 2.16: +12 -51 lines
Diff to previous 2.16 , to selected 2.37
Removed NOPROTO sections.
Fri May 9 22:18:03 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.15: +2 -0 lines
Diff to previous 2.15 , to selected 2.37
Added missing prototype for raytexture()
Tue Mar 11 17:08:55 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.14: +1 -0 lines
Diff to previous 2.14 , to selected 2.37
Tue Mar 4 19:02:22 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.13: +3 -0 lines
Diff to previous 2.13 , to selected 2.37
Modified new ray hit interface to check whole sets at a time
Changes since 2.12: +2 -57 lines
Diff to previous 2.12 , to selected 2.37
Changes since 2.11: +279 -37 lines
Diff to previous 2.11 , to selected 2.37
Fri Mar 7 16:53:02 1997 UTC (27 years, 3 months ago) by greg
Diff to previous 2.10 , to selected 2.37
comment change
Fri Mar 7 16:42:54 1997 UTC (27 years, 3 months ago) by greg
Diff to previous 2.9 , to selected 2.37
added intersected object number for tracking instances
Wed Jun 5 11:27:30 1996 UTC (28 years ago) by greg
Changes since 2.8: +0 -2 lines
Diff to previous 2.8 , to selected 2.37
moved MAXSLIST macro to m_mist.c routine
Wed Apr 17 14:01:51 1996 UTC (28 years, 2 months ago) by greg
Diff to previous 2.7 , to selected 2.37
Wed Mar 27 12:17:10 1996 UTC (28 years, 2 months ago) by greg
Diff to previous 2.6 , to selected 2.37
fixed declaration of raydist()
Sat Dec 9 09:35:00 1995 UTC (28 years, 6 months ago) by greg
Diff to previous 2.5 , to selected 2.37
Thu Nov 2 17:38:07 1995 UTC (28 years, 7 months ago) by greg
Diff to previous 2.4 , to selected 2.37
added raydist() function
Tue Dec 20 20:18:20 1994 UTC (29 years, 5 months ago) by greg
Diff to previous 2.3 , to selected 2.37
Tue May 25 10:30:14 1993 UTC (31 years ago) by greg
Diff to previous 2.2 , to selected 2.37
Sat Jan 4 19:53:55 1992 UTC (32 years, 5 months ago) by greg
Changes since 2.1: +4 -3 lines
Diff to previous 2.1 , to selected 2.37
added specular sampling
Tue Nov 12 17:10:16 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.6 , to selected 2.37
Thu Jun 20 13:29:31 1991 UTC (33 years ago) by greg
Diff to previous 1.5 , to selected 2.37
added revf member to ray structure for dynamic evaluation
Thu May 23 08:12:57 1991 UTC (33 years ago) by greg
Changes since 1.4: +6 -0 lines
Diff to previous 1.4 , to selected 2.37
added MAXDIM
Sat Dec 15 16:41:44 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.3: +2 -5 lines
Diff to previous 1.3 , to selected 2.37
Thu Mar 22 20:07:01 1990 UTC (34 years, 3 months ago) by greg
Diff to previous 1.2 , to selected 2.37
added rt field for effective ray length
Tue Apr 11 13:16:43 1989 UTC (35 years, 2 months ago) by greg
Changes since 1.1: +4 -1 lines
Diff to previous 1.1 , to selected 2.37
added forward object transform
Thu Feb 2 10:41:14 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.37
