Making gcc -Wall happy
Improved output efficiency by reducing number of calls to fwrite()
Bug fix in l+ option of mkillum under Windows
Final fix to problem of queue overflow (I hope)
Fixed bugs in black glass transmission and source weight computation
Created proper prototypes for function pointers and included missing headers
Instrumented headers against multiple inclusion and for use from C++. Moved includes in headers out of "C" scope.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Instrumented headers against multiple inclusion and for use from C++. Removed NOPROTO sections.
Added missing prototype for raytexture()
Modified new ray hit interface to check whole sets at a time
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
comment change
added intersected object number for tracking instances
moved MAXSLIST macro to m_mist.c routine
fixed declaration of raydist()
added raydist() function
added specular sampling
added revf member to ray structure for dynamic evaluation
added MAXDIM
added rt field for effective ray length
added forward object transform
