root/radiance/ray/src/rt/ray.h
Changes since 2.21: +7 -1 lines
Diff to previous 2.21 , to selected 2.7
Thu Aug 28 03:22:16 2003 UTC (20 years, 8 months ago) by greg
Diff to previous 2.20 , to selected 2.7
Created proper prototypes for function pointers and included missing headers
Changes since 2.19: +5 -7 lines
Diff to previous 2.19 , to selected 2.7
Changes since 2.18: +1 -4 lines
Diff to previous 2.18 , to selected 2.7
Diff to previous 2.17 , to selected 2.7
Sat Jun 7 00:54:58 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.16: +12 -51 lines
Diff to previous 2.16 , to selected 2.7
Removed NOPROTO sections.
Fri May 9 22:18:03 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.15: +2 -0 lines
Diff to previous 2.15 , to selected 2.7
Added missing prototype for raytexture()
Tue Mar 11 17:08:55 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.14: +1 -0 lines
Diff to previous 2.14 , to selected 2.7
Tue Mar 4 19:02:22 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.13: +3 -0 lines
Modified new ray hit interface to check whole sets at a time
Changes since 2.12: +2 -57 lines
Changes since 2.11: +279 -37 lines
Fri Mar 7 16:53:02 1997 UTC (27 years, 2 months ago) by greg
comment change
Fri Mar 7 16:42:54 1997 UTC (27 years, 2 months ago) by greg
added intersected object number for tracking instances
Wed Jun 5 11:27:30 1996 UTC (27 years, 11 months ago) by greg
Changes since 2.8: +0 -2 lines
moved MAXSLIST macro to m_mist.c routine
Wed Apr 17 14:01:51 1996 UTC (28 years ago) by greg
Wed Mar 27 12:17:10 1996 UTC (28 years, 1 month ago) by greg
fixed declaration of raydist()
Sat Dec 9 09:35:00 1995 UTC (28 years, 4 months ago) by greg
Thu Nov 2 17:38:07 1995 UTC (28 years, 6 months ago) by greg
added raydist() function
Tue Dec 20 20:18:20 1994 UTC (29 years, 4 months ago) by greg
Tue May 25 10:30:14 1993 UTC (30 years, 11 months ago) by greg
Sat Jan 4 19:53:55 1992 UTC (32 years, 4 months ago) by greg
Changes since 2.1: +4 -3 lines
added specular sampling
Tue Nov 12 17:10:16 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.6 , to selected 2.7
Thu Jun 20 13:29:31 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.5 , to selected 2.7
added revf member to ray structure for dynamic evaluation
Thu May 23 08:12:57 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.4: +6 -0 lines
Diff to previous 1.4 , to selected 2.7
added MAXDIM
Sat Dec 15 16:41:44 1990 UTC (33 years, 4 months ago) by greg
Changes since 1.3: +2 -5 lines
Diff to previous 1.3 , to selected 2.7
Thu Mar 22 20:07:01 1990 UTC (34 years, 1 month ago) by greg
added rt field for effective ray length
Tue Apr 11 13:16:43 1989 UTC (35 years ago) by greg
Changes since 1.1: +4 -1 lines
added forward object transform
Thu Feb 2 10:41:14 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.7
