--- ray/src/rt/ray.h 2003/07/14 22:24:00 2.20 +++ ray/src/rt/ray.h 2004/03/30 16:13:01 2.22 @@ -1,4 +1,4 @@ -/* RCSid $Id: ray.h,v 2.20 2003/07/14 22:24:00 schorsch Exp $ */ +/* RCSid $Id: ray.h,v 2.22 2004/03/30 16:13:01 schorsch Exp $ */ /* * ray.h - header file for routines using rays. */ @@ -41,8 +41,8 @@ typedef struct ray { int rsrc; /* source we're aiming for */ OBJECT *clipset; /* set of objects currently clipped */ OBJECT *newcset; /* next clipset, used for transmission */ - void (*revf)(); /* evaluation function for this ray */ - void (*hitf)(); /* custom hit test for this traversal */ + void (*revf)(struct ray *); /* evaluation function for this ray */ + void (*hitf)(OBJECT *, struct ray *); /* custom hit test */ OBJECT robj; /* intersected object number */ OBJREC *ro; /* intersected object (one with material) */ double rot; /* distance to object */ @@ -160,6 +160,8 @@ typedef struct { /* rendering parameter holder */ extern void headclean(void); extern void openheader(void); extern void dupheader(void); + /* defined in persist.c */ +extern void persistfile(char *pfn); extern void pfdetach(void); extern void pfclean(void); extern void pflock(int lf); @@ -208,8 +210,12 @@ extern void print_rdefaults(void); /* defined in srcdraw.c */ extern void drawsources(COLOR *pic[], float *zbf[], int x0, int xsiz, int y0, int ysiz); +extern void init_drawsources(int rad); + /* defined in rt/initotypes.c */ +extern void initotypes(void); /* module main procedures */ extern void rtrace(char *fname); +extern char * formstr(int f); extern void rview(void); extern void rpict(int seq, char *pout, char *zout, char *prvr);
