--- ray/src/rt/ray.h 2003/05/09 22:18:03 2.16 +++ ray/src/rt/ray.h 2003/08/28 03:22:16 2.21 @@ -1,18 +1,19 @@ -/* RCSid $Id: ray.h,v 2.16 2003/05/09 22:18:03 greg Exp $ */ +/* RCSid $Id: ray.h,v 2.21 2003/08/28 03:22:16 greg Exp $ */ /* * ray.h - header file for routines using rays. */ +#ifndef _RAD_RAY_H_ +#define _RAD_RAY_H_ -#include "copyright.h" - #include "standard.h" - #include "octree.h" - #include "object.h" - #include "color.h" +#ifdef __cplusplus +extern "C" { +#endif + #define MAXDIM 32 /* maximum number of dimensions */ /* ray type flags */ @@ -40,8 +41,8 @@ typedef struct ray { int rsrc; /* source we're aiming for */ OBJECT *clipset; /* set of objects currently clipped */ OBJECT *newcset; /* next clipset, used for transmission */ - void (*revf)(); /* evaluation function for this ray */ - void (*hitf)(); /* custom hit test for this traversal */ + void (*revf)(struct ray *); /* evaluation function for this ray */ + void (*hitf)(OBJECT *, struct ray *); /* custom hit test */ OBJECT robj; /* intersected object number */ OBJREC *ro; /* intersected object (one with material) */ double rot; /* distance to object */ @@ -49,7 +50,7 @@ typedef struct ray { FVECT ron; /* intersection surface normal */ double rod; /* -DOT(rdir, ron) */ FULLXF *rox; /* object transformation */ - FLOAT uv[2]; /* local coordinates */ + RREAL uv[2]; /* local coordinates */ FVECT pert; /* surface normal perturbation */ COLOR pcol; /* pattern color */ COLOR rcol; /* returned ray value */ @@ -155,56 +156,6 @@ typedef struct { /* rendering parameter holder */ #define rpambmod(p,i) ( (i)>=AMBLLEN||(p)->amblndx[i]<0 ? \ (char *)NULL : (p)->amblval+(p)->amblndx[i] ) -#ifdef NOPROTO - -extern void headclean(); -extern void openheader(); -extern void dupheader(); -extern void pfdetach(); -extern void pfclean(); -extern void pflock(); -extern void pfhold(); -extern void io_process(); -extern int free_objs(); -extern void free_objmem(); -extern int load_os(); -extern void preload_objs(); -extern void ray_init(); -extern void ray_trace(); -extern void ray_done(); -extern void ray_save(); -extern void ray_restore(); -extern void ray_defaults(); -extern void ray_pinit(); -extern void ray_psend(); -extern int ray_pqueue(); -extern int ray_presult(); -extern void ray_pdone(); -extern void ray_popen(); -extern void ray_pclose(); -extern int rayorigin(); -extern void rayclear(); -extern void raytrace(); -extern void rayhit(); -extern void raycont(); -extern void raytrans(); -extern int rayshade(); -extern void rayparticipate(); -extern void raytexture(); -extern int raymixture(); -extern double raydist(); -extern double raynormal(); -extern void newrayxf(); -extern void flipsurface(); -extern int localhit(); -extern int getrenderopt(); -extern void print_rdefaults(); -extern void drawsources(); -extern void rtrace(); -extern void rview(); -extern void rpict(); - -#else /* defined in duphead.c */ extern void headclean(void); extern void openheader(void); @@ -262,4 +213,9 @@ extern void rtrace(char *fname); extern void rview(void); extern void rpict(int seq, char *pout, char *zout, char *prvr); + +#ifdef __cplusplus +} #endif +#endif /* _RAD_RAY_H_ */ +
