root/radiance/ray/src/rt/ray.h
Revision: 2.15
Committed: Tue Mar 11 17:08:55 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.14: +1 -0 lines
# User Rev Content
1 greg 2.13 /* RCSid $Id$ */
2 greg 1.1 /*
3     * ray.h - header file for routines using rays.
4 greg 2.12 */
5
6 greg 2.13 #include "copyright.h"
7 greg 1.1
8     #include "standard.h"
9
10 greg 2.12 #include "octree.h"
11
12 greg 1.1 #include "object.h"
13
14     #include "color.h"
15
16 greg 2.6 #define MAXDIM 32 /* maximum number of dimensions */
17
18 greg 1.1 /* ray type flags */
19     #define PRIMARY 01 /* original ray */
20     #define SHADOW 02 /* ray to light source */
21     #define REFLECTED 04 /* reflected ray */
22     #define REFRACTED 010 /* refracted (bent) ray */
23     #define TRANS 020 /* transmitted/transferred ray */
24     #define AMBIENT 040 /* ray scattered for interreflection */
25 greg 2.2 #define SPECULAR 0100 /* ray scattered for specular */
26 greg 1.1
27     /* reflected ray types */
28 greg 2.2 #define RAYREFL (SHADOW|REFLECTED|AMBIENT|SPECULAR)
29 greg 1.1
30     typedef struct ray {
31 greg 2.3 unsigned long rno; /* unique ray number */
32 greg 2.12 int rlvl; /* number of reflections for this ray */
33     float rweight; /* cumulative weight of this ray */
34     short rtype; /* ray type */
35     short crtype; /* cumulative ray type */
36 greg 1.1 struct ray *parent; /* ray this originated from */
37 greg 2.12 FVECT rorg; /* origin of ray */
38     FVECT rdir; /* normalized direction of ray */
39     double rmax; /* maximum distance (aft clipping plane) */
40     int rsrc; /* source we're aiming for */
41     OBJECT *clipset; /* set of objects currently clipped */
42     OBJECT *newcset; /* next clipset, used for transmission */
43     void (*revf)(); /* evaluation function for this ray */
44 greg 2.14 void (*hitf)(); /* custom hit test for this traversal */
45 greg 2.11 OBJECT robj; /* intersected object number */
46 greg 2.12 OBJREC *ro; /* intersected object (one with material) */
47     double rot; /* distance to object */
48     FVECT rop; /* intersection point */
49     FVECT ron; /* intersection surface normal */
50     double rod; /* -DOT(rdir, ron) */
51     FULLXF *rox; /* object transformation */
52 greg 2.15 FLOAT uv[2]; /* local coordinates */
53 greg 2.12 FVECT pert; /* surface normal perturbation */
54     COLOR pcol; /* pattern color */
55     COLOR rcol; /* returned ray value */
56     double rt; /* returned effective ray length */
57     COLOR cext; /* medium extinction coefficient */
58     COLOR albedo; /* medium scattering albedo */
59     float gecc; /* scattering eccentricity coefficient */
60     int *slights; /* list of lights to test for scattering */
61 greg 1.1 } RAY;
62
63 greg 2.12 #define rayvalue(r) (*(r)->revf)(r)
64
65     extern char VersionID[]; /* Radiance version ID string */
66 greg 1.6
67 greg 2.12 extern CUBE thescene; /* our scene */
68     extern OBJECT nsceneobjs; /* number of objects in our scene */
69 greg 2.5
70 greg 2.12 extern unsigned long raynum; /* next ray ID */
71     extern unsigned long nrays; /* total rays traced so far */
72 greg 1.5
73 greg 2.12 extern OBJREC Lamb; /* a Lambertian surface */
74     extern OBJREC Aftplane; /* aft clipping object */
75
76     extern void (*trace)(); /* global trace reporting callback */
77
78     extern int dimlist[]; /* dimension list for distribution */
79     extern int ndims; /* number of dimensions so far */
80     extern int samplendx; /* index for this sample */
81
82     extern int ray_savesiz; /* size of parameter save buffer */
83
84     extern int do_irrad; /* compute irradiance? */
85
86     extern double dstrsrc; /* square source distribution */
87     extern double shadthresh; /* shadow threshold */
88     extern double shadcert; /* shadow testing certainty */
89     extern int directrelay; /* number of source relays */
90     extern int vspretest; /* virtual source pretest density */
91     extern int directvis; /* light sources visible to eye? */
92     extern double srcsizerat; /* maximum source size/dist. ratio */
93
94     extern double specthresh; /* specular sampling threshold */
95     extern double specjitter; /* specular sampling jitter */
96
97     extern COLOR cextinction; /* global extinction coefficient */
98     extern COLOR salbedo; /* global scattering albedo */
99     extern double seccg; /* global scattering eccentricity */
100     extern double ssampdist; /* scatter sampling distance */
101
102     extern int backvis; /* back face visibility */
103
104     extern int maxdepth; /* maximum recursion depth */
105     extern double minweight; /* minimum ray weight */
106
107     extern char *ambfile; /* ambient file name */
108     extern COLOR ambval; /* ambient value */
109     extern int ambvwt; /* initial weight for ambient value */
110     extern double ambacc; /* ambient accuracy */
111     extern int ambres; /* ambient resolution */
112     extern int ambdiv; /* ambient divisions */
113     extern int ambssamp; /* ambient super-samples */
114     extern int ambounce; /* ambient bounces */
115     extern char *amblist[]; /* ambient include/exclude list */
116     extern int ambincl; /* include == 1, exclude == 0 */
117
118     extern int ray_pnprocs; /* number of child processes */
119     extern int ray_pnidle; /* number of idle processes */
120
121     #define AMBLLEN 128 /* max. ambient list length */
122     #define AMBWORD 8 /* average word length */
123
124     typedef struct { /* rendering parameter holder */
125     int do_irrad;
126     double dstrsrc;
127     double shadthresh;
128     double shadcert;
129     int directrelay;
130     int vspretest;
131     int directvis;
132     double srcsizerat;
133     COLOR cextinction;
134     COLOR salbedo;
135     double seccg;
136     double ssampdist;
137     double specthresh;
138     double specjitter;
139     int backvis;
140     int maxdepth;
141     double minweight;
142     char ambfile[512];
143     COLOR ambval;
144     int ambvwt;
145     double ambacc;
146     int ambres;
147     int ambdiv;
148     int ambssamp;
149     int ambounce;
150     int ambincl;
151     short amblndx[AMBLLEN+1];
152     char amblval[AMBLLEN*AMBWORD];
153     } RAYPARAMS;
154
155     #define rpambmod(p,i) ( (i)>=AMBLLEN||(p)->amblndx[i]<0 ? \
156     (char *)NULL : (p)->amblval+(p)->amblndx[i] )
157
158     #ifdef NOPROTO
159
160     extern void headclean();
161     extern void openheader();
162     extern void dupheader();
163     extern void pfdetach();
164     extern void pfclean();
165     extern void pflock();
166     extern void pfhold();
167     extern void io_process();
168     extern int free_objs();
169     extern void free_objmem();
170     extern int load_os();
171     extern void preload_objs();
172     extern void ray_init();
173     extern void ray_trace();
174     extern void ray_done();
175     extern void ray_save();
176     extern void ray_restore();
177     extern void ray_defaults();
178     extern void ray_pinit();
179     extern void ray_psend();
180     extern int ray_pqueue();
181     extern int ray_presult();
182     extern void ray_pdone();
183     extern void ray_popen();
184     extern void ray_pclose();
185     extern int rayorigin();
186     extern void rayclear();
187     extern void raytrace();
188 greg 2.14 extern void rayhit();
189 greg 2.12 extern void raycont();
190     extern void raytrans();
191     extern int rayshade();
192     extern void rayparticipate();
193     extern int raymixture();
194     extern double raydist();
195     extern double raynormal();
196     extern void newrayxf();
197     extern void flipsurface();
198     extern int localhit();
199     extern int getrenderopt();
200     extern void print_rdefaults();
201     extern void drawsources();
202     extern void rtrace();
203     extern void rview();
204     extern void rpict();
205
206     #else
207     /* defined in duphead.c */
208     extern void headclean(void);
209     extern void openheader(void);
210     extern void dupheader(void);
211     extern void pfdetach(void);
212     extern void pfclean(void);
213     extern void pflock(int lf);
214     extern void pfhold(void);
215     extern void io_process(void);
216     /* defined in freeobjmem.c */
217     extern int free_objs(OBJECT on, OBJECT no);
218     extern void free_objmem(void);
219     /* defined in preload.c */
220     extern int load_os(OBJREC *op);
221     extern void preload_objs(void);
222     /* defined in raycalls.c */
223     extern void ray_init(char *otnm);
224     extern void ray_trace(RAY *r);
225     extern void ray_done(int freall);
226     extern void ray_save(RAYPARAMS *rp);
227     extern void ray_restore(RAYPARAMS *rp);
228     extern void ray_defaults(RAYPARAMS *rp);
229     /* defined in raypcalls.c */
230     extern void ray_pinit(char *otnm, int nproc);
231     extern void ray_psend(RAY *r);
232     extern int ray_pqueue(RAY *r);
233     extern int ray_presult(RAY *r, int poll);
234     extern void ray_pdone(int freall);
235     extern void ray_popen(int nadd);
236     extern void ray_pclose(int nsub);
237     /* defined in raytrace.c */
238     extern int rayorigin(RAY *r, RAY *ro, int rt, double rw);
239     extern void rayclear(RAY *r);
240     extern void raytrace(RAY *r);
241 greg 2.14 extern void rayhit(OBJECT *oset, RAY *r);
242 greg 2.12 extern void raycont(RAY *r);
243     extern void raytrans(RAY *r);
244     extern int rayshade(RAY *r, int mod);
245     extern void rayparticipate(RAY *r);
246     extern int raymixture(RAY *r, OBJECT fore, OBJECT back, double coef);
247     extern double raydist(RAY *r, int flags);
248     extern double raynormal(FVECT norm, RAY *r);
249     extern void newrayxf(RAY *r);
250     extern void flipsurface(RAY *r);
251     extern int localhit(RAY *r, CUBE *scene);
252     /* defined in renderopts.c */
253     extern int getrenderopt(int ac, char *av[]);
254     extern void print_rdefaults(void);
255     /* defined in srcdraw.c */
256     extern void drawsources(COLOR *pic[], float *zbf[],
257     int x0, int xsiz, int y0, int ysiz);
258     /* module main procedures */
259     extern void rtrace(char *fname);
260     extern void rview(void);
261     extern void rpict(int seq, char *pout, char *zout, char *prvr);
262 greg 1.6
263 greg 2.12 #endif
