1 |
/* RCSid $Id$ */ |
2 |
3 |
* ray.h - header file for routines using rays. |
4 |
5 |
6 |
#include "copyright.h" |
7 |
8 |
#include "standard.h" |
9 |
10 |
#include "octree.h" |
11 |
12 |
#include "object.h" |
13 |
14 |
#include "color.h" |
15 |
16 |
#define MAXDIM 32 /* maximum number of dimensions */ |
17 |
18 |
/* ray type flags */ |
19 |
#define PRIMARY 01 /* original ray */ |
20 |
#define SHADOW 02 /* ray to light source */ |
21 |
#define REFLECTED 04 /* reflected ray */ |
22 |
#define REFRACTED 010 /* refracted (bent) ray */ |
23 |
#define TRANS 020 /* transmitted/transferred ray */ |
24 |
#define AMBIENT 040 /* ray scattered for interreflection */ |
25 |
#define SPECULAR 0100 /* ray scattered for specular */ |
26 |
27 |
/* reflected ray types */ |
28 |
#define RAYREFL (SHADOW|REFLECTED|AMBIENT|SPECULAR) |
29 |
30 |
typedef struct ray { |
31 |
unsigned long rno; /* unique ray number */ |
32 |
int rlvl; /* number of reflections for this ray */ |
33 |
float rweight; /* cumulative weight of this ray */ |
34 |
short rtype; /* ray type */ |
35 |
short crtype; /* cumulative ray type */ |
36 |
struct ray *parent; /* ray this originated from */ |
37 |
FVECT rorg; /* origin of ray */ |
38 |
FVECT rdir; /* normalized direction of ray */ |
39 |
double rmax; /* maximum distance (aft clipping plane) */ |
40 |
int rsrc; /* source we're aiming for */ |
41 |
OBJECT *clipset; /* set of objects currently clipped */ |
42 |
OBJECT *newcset; /* next clipset, used for transmission */ |
43 |
void (*revf)(); /* evaluation function for this ray */ |
44 |
void (*hitf)(); /* custom hit test for this traversal */ |
45 |
OBJECT robj; /* intersected object number */ |
46 |
OBJREC *ro; /* intersected object (one with material) */ |
47 |
double rot; /* distance to object */ |
48 |
FVECT rop; /* intersection point */ |
49 |
FVECT ron; /* intersection surface normal */ |
50 |
double rod; /* -DOT(rdir, ron) */ |
51 |
FULLXF *rox; /* object transformation */ |
52 |
FLOAT uv[2]; /* local coordinates */ |
53 |
FVECT pert; /* surface normal perturbation */ |
54 |
COLOR pcol; /* pattern color */ |
55 |
COLOR rcol; /* returned ray value */ |
56 |
double rt; /* returned effective ray length */ |
57 |
COLOR cext; /* medium extinction coefficient */ |
58 |
COLOR albedo; /* medium scattering albedo */ |
59 |
float gecc; /* scattering eccentricity coefficient */ |
60 |
int *slights; /* list of lights to test for scattering */ |
61 |
} RAY; |
62 |
63 |
#define rayvalue(r) (*(r)->revf)(r) |
64 |
65 |
extern char VersionID[]; /* Radiance version ID string */ |
66 |
67 |
extern CUBE thescene; /* our scene */ |
68 |
extern OBJECT nsceneobjs; /* number of objects in our scene */ |
69 |
70 |
extern unsigned long raynum; /* next ray ID */ |
71 |
extern unsigned long nrays; /* total rays traced so far */ |
72 |
73 |
extern OBJREC Lamb; /* a Lambertian surface */ |
74 |
extern OBJREC Aftplane; /* aft clipping object */ |
75 |
76 |
extern void (*trace)(); /* global trace reporting callback */ |
77 |
78 |
extern int dimlist[]; /* dimension list for distribution */ |
79 |
extern int ndims; /* number of dimensions so far */ |
80 |
extern int samplendx; /* index for this sample */ |
81 |
82 |
extern int ray_savesiz; /* size of parameter save buffer */ |
83 |
84 |
extern int do_irrad; /* compute irradiance? */ |
85 |
86 |
extern double dstrsrc; /* square source distribution */ |
87 |
extern double shadthresh; /* shadow threshold */ |
88 |
extern double shadcert; /* shadow testing certainty */ |
89 |
extern int directrelay; /* number of source relays */ |
90 |
extern int vspretest; /* virtual source pretest density */ |
91 |
extern int directvis; /* light sources visible to eye? */ |
92 |
extern double srcsizerat; /* maximum source size/dist. ratio */ |
93 |
94 |
extern double specthresh; /* specular sampling threshold */ |
95 |
extern double specjitter; /* specular sampling jitter */ |
96 |
97 |
extern COLOR cextinction; /* global extinction coefficient */ |
98 |
extern COLOR salbedo; /* global scattering albedo */ |
99 |
extern double seccg; /* global scattering eccentricity */ |
100 |
extern double ssampdist; /* scatter sampling distance */ |
101 |
102 |
extern int backvis; /* back face visibility */ |
103 |
104 |
extern int maxdepth; /* maximum recursion depth */ |
105 |
extern double minweight; /* minimum ray weight */ |
106 |
107 |
extern char *ambfile; /* ambient file name */ |
108 |
extern COLOR ambval; /* ambient value */ |
109 |
extern int ambvwt; /* initial weight for ambient value */ |
110 |
extern double ambacc; /* ambient accuracy */ |
111 |
extern int ambres; /* ambient resolution */ |
112 |
extern int ambdiv; /* ambient divisions */ |
113 |
extern int ambssamp; /* ambient super-samples */ |
114 |
extern int ambounce; /* ambient bounces */ |
115 |
extern char *amblist[]; /* ambient include/exclude list */ |
116 |
extern int ambincl; /* include == 1, exclude == 0 */ |
117 |
118 |
extern int ray_pnprocs; /* number of child processes */ |
119 |
extern int ray_pnidle; /* number of idle processes */ |
120 |
121 |
#define AMBLLEN 128 /* max. ambient list length */ |
122 |
#define AMBWORD 8 /* average word length */ |
123 |
124 |
typedef struct { /* rendering parameter holder */ |
125 |
int do_irrad; |
126 |
double dstrsrc; |
127 |
double shadthresh; |
128 |
double shadcert; |
129 |
int directrelay; |
130 |
int vspretest; |
131 |
int directvis; |
132 |
double srcsizerat; |
133 |
COLOR cextinction; |
134 |
COLOR salbedo; |
135 |
double seccg; |
136 |
double ssampdist; |
137 |
double specthresh; |
138 |
double specjitter; |
139 |
int backvis; |
140 |
int maxdepth; |
141 |
double minweight; |
142 |
char ambfile[512]; |
143 |
COLOR ambval; |
144 |
int ambvwt; |
145 |
double ambacc; |
146 |
int ambres; |
147 |
int ambdiv; |
148 |
int ambssamp; |
149 |
int ambounce; |
150 |
int ambincl; |
151 |
short amblndx[AMBLLEN+1]; |
152 |
char amblval[AMBLLEN*AMBWORD]; |
153 |
} RAYPARAMS; |
154 |
155 |
#define rpambmod(p,i) ( (i)>=AMBLLEN||(p)->amblndx[i]<0 ? \ |
156 |
(char *)NULL : (p)->amblval+(p)->amblndx[i] ) |
157 |
158 |
#ifdef NOPROTO |
159 |
160 |
extern void headclean(); |
161 |
extern void openheader(); |
162 |
extern void dupheader(); |
163 |
extern void pfdetach(); |
164 |
extern void pfclean(); |
165 |
extern void pflock(); |
166 |
extern void pfhold(); |
167 |
extern void io_process(); |
168 |
extern int free_objs(); |
169 |
extern void free_objmem(); |
170 |
extern int load_os(); |
171 |
extern void preload_objs(); |
172 |
extern void ray_init(); |
173 |
extern void ray_trace(); |
174 |
extern void ray_done(); |
175 |
extern void ray_save(); |
176 |
extern void ray_restore(); |
177 |
extern void ray_defaults(); |
178 |
extern void ray_pinit(); |
179 |
extern void ray_psend(); |
180 |
extern int ray_pqueue(); |
181 |
extern int ray_presult(); |
182 |
extern void ray_pdone(); |
183 |
extern void ray_popen(); |
184 |
extern void ray_pclose(); |
185 |
extern int rayorigin(); |
186 |
extern void rayclear(); |
187 |
extern void raytrace(); |
188 |
extern void rayhit(); |
189 |
extern void raycont(); |
190 |
extern void raytrans(); |
191 |
extern int rayshade(); |
192 |
extern void rayparticipate(); |
193 |
extern int raymixture(); |
194 |
extern double raydist(); |
195 |
extern double raynormal(); |
196 |
extern void newrayxf(); |
197 |
extern void flipsurface(); |
198 |
extern int localhit(); |
199 |
extern int getrenderopt(); |
200 |
extern void print_rdefaults(); |
201 |
extern void drawsources(); |
202 |
extern void rtrace(); |
203 |
extern void rview(); |
204 |
extern void rpict(); |
205 |
206 |
#else |
207 |
/* defined in duphead.c */ |
208 |
extern void headclean(void); |
209 |
extern void openheader(void); |
210 |
extern void dupheader(void); |
211 |
extern void pfdetach(void); |
212 |
extern void pfclean(void); |
213 |
extern void pflock(int lf); |
214 |
extern void pfhold(void); |
215 |
extern void io_process(void); |
216 |
/* defined in freeobjmem.c */ |
217 |
extern int free_objs(OBJECT on, OBJECT no); |
218 |
extern void free_objmem(void); |
219 |
/* defined in preload.c */ |
220 |
extern int load_os(OBJREC *op); |
221 |
extern void preload_objs(void); |
222 |
/* defined in raycalls.c */ |
223 |
extern void ray_init(char *otnm); |
224 |
extern void ray_trace(RAY *r); |
225 |
extern void ray_done(int freall); |
226 |
extern void ray_save(RAYPARAMS *rp); |
227 |
extern void ray_restore(RAYPARAMS *rp); |
228 |
extern void ray_defaults(RAYPARAMS *rp); |
229 |
/* defined in raypcalls.c */ |
230 |
extern void ray_pinit(char *otnm, int nproc); |
231 |
extern void ray_psend(RAY *r); |
232 |
extern int ray_pqueue(RAY *r); |
233 |
extern int ray_presult(RAY *r, int poll); |
234 |
extern void ray_pdone(int freall); |
235 |
extern void ray_popen(int nadd); |
236 |
extern void ray_pclose(int nsub); |
237 |
/* defined in raytrace.c */ |
238 |
extern int rayorigin(RAY *r, RAY *ro, int rt, double rw); |
239 |
extern void rayclear(RAY *r); |
240 |
extern void raytrace(RAY *r); |
241 |
extern void rayhit(OBJECT *oset, RAY *r); |
242 |
extern void raycont(RAY *r); |
243 |
extern void raytrans(RAY *r); |
244 |
extern int rayshade(RAY *r, int mod); |
245 |
extern void rayparticipate(RAY *r); |
246 |
extern int raymixture(RAY *r, OBJECT fore, OBJECT back, double coef); |
247 |
extern double raydist(RAY *r, int flags); |
248 |
extern double raynormal(FVECT norm, RAY *r); |
249 |
extern void newrayxf(RAY *r); |
250 |
extern void flipsurface(RAY *r); |
251 |
extern int localhit(RAY *r, CUBE *scene); |
252 |
/* defined in renderopts.c */ |
253 |
extern int getrenderopt(int ac, char *av[]); |
254 |
extern void print_rdefaults(void); |
255 |
/* defined in srcdraw.c */ |
256 |
extern void drawsources(COLOR *pic[], float *zbf[], |
257 |
int x0, int xsiz, int y0, int ysiz); |
258 |
/* module main procedures */ |
259 |
extern void rtrace(char *fname); |
260 |
extern void rview(void); |
261 |
extern void rpict(int seq, char *pout, char *zout, char *prvr); |
262 |
263 |
#endif |
