root/radiance/ray/src/rt/ray.h
Tue Mar 11 17:08:55 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.14: +1 -0 lines
Diff to previous 2.14 , to selected 1.3
Tue Mar 4 19:02:22 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.13: +3 -0 lines
Diff to previous 2.13 , to selected 1.3
Modified new ray hit interface to check whole sets at a time
Tue Feb 25 02:47:23 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.12: +2 -57 lines
Diff to previous 2.12 , to selected 1.3
Changes since 2.11: +279 -37 lines
Diff to previous 2.11 , to selected 1.3
Fri Mar 7 16:53:02 1997 UTC (28 years, 2 months ago) by greg
Diff to previous 2.10 , to selected 1.3
comment change
Fri Mar 7 16:42:54 1997 UTC (28 years, 2 months ago) by greg
Diff to previous 2.9 , to selected 1.3
added intersected object number for tracking instances
Wed Jun 5 11:27:30 1996 UTC (28 years, 11 months ago) by greg
Changes since 2.8: +0 -2 lines
Diff to previous 2.8 , to selected 1.3
moved MAXSLIST macro to m_mist.c routine
Wed Apr 17 14:01:51 1996 UTC (29 years ago) by greg
Diff to previous 2.7 , to selected 1.3
Wed Mar 27 12:17:10 1996 UTC (29 years, 1 month ago) by greg
Diff to previous 2.6 , to selected 1.3
fixed declaration of raydist()
Sat Dec 9 09:35:00 1995 UTC (29 years, 5 months ago) by greg
Diff to previous 2.5 , to selected 1.3
Thu Nov 2 17:38:07 1995 UTC (29 years, 6 months ago) by greg
Diff to previous 2.4 , to selected 1.3
added raydist() function
Tue Dec 20 20:18:20 1994 UTC (30 years, 4 months ago) by greg
Diff to previous 2.3 , to selected 1.3
Tue May 25 10:30:14 1993 UTC (31 years, 11 months ago) by greg
Diff to previous 2.2 , to selected 1.3
Sat Jan 4 19:53:55 1992 UTC (33 years, 4 months ago) by greg
Changes since 2.1: +4 -3 lines
Diff to previous 2.1 , to selected 1.3
added specular sampling
Tue Nov 12 17:10:16 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 1.6 , to selected 1.3
Thu Jun 20 13:29:31 1991 UTC (33 years, 10 months ago) by greg
Diff to previous 1.5 , to selected 1.3
added revf member to ray structure for dynamic evaluation
Thu May 23 08:12:57 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.4: +6 -0 lines
Diff to previous 1.4 , to selected 1.3
added MAXDIM
Sat Dec 15 16:41:44 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.3: +2 -5 lines
Diff to previous 1.3
Revision 1.3 - (view) (download) (annotate) - [selected]
Thu Mar 22 20:07:01 1990 UTC (35 years, 1 month ago) by greg
Diff to previous 1.2
added rt field for effective ray length
Tue Apr 11 13:16:43 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.1: +4 -1 lines
Diff to previous 1.1 , to selected 1.3
added forward object transform
Thu Feb 2 10:41:14 1989 UTC (36 years, 3 months ago) by greg
Diff to selected 1.3
