root/radiance/ray/src/rt/ray.h
Revision: 2.62
Committed: Fri Jun 20 18:05:30 2025 UTC (2 days, 5 hours ago) by greg
Changes since 2.61: +3 -3 lines
refactor: Changed macros to function type for clarity
# User Rev Content
1 greg 2.62 /* RCSid $Id: ray.h,v 2.61 2025/06/20 16:48:39 greg Exp $ */
2 greg 1.1 /*
3     * ray.h - header file for routines using rays.
4 greg 2.12 */
5 schorsch 2.17 #ifndef _RAD_RAY_H_
6     #define _RAD_RAY_H_
7 greg 1.1
8     #include "standard.h"
9 greg 2.12 #include "octree.h"
10 greg 1.1 #include "object.h"
11 schorsch 2.20 #include "color.h"
12 greg 2.38 #include "pmapparm.h"
13 greg 1.1
14 schorsch 2.20 #ifdef __cplusplus
15     extern "C" {
16     #endif
17 greg 1.1
18 greg 2.30 #ifndef RNUMBER
19 greg 2.48 #define RNUMBER size_t /* ray counter (>= sizeof pointer) */
20 greg 2.30 #endif
21
22 greg 2.60 #define MAXDIM 36 /* maximum number of sampling dimensions */
23     #define XTRADIM 3 /* #spare dimensions */
24 greg 2.62 #define ndims_inc() (ndims -= ndims>=MAXDIM-XTRADIM, ndims++)
25     #define dec_ndims() (ndims -= ndims>0)
26 greg 2.6
27 greg 1.1 /* ray type flags */
28     #define PRIMARY 01 /* original ray */
29 greg 2.52 #define RSHADOW 02 /* reflected ray to light source */
30 greg 1.1 #define REFLECTED 04 /* reflected ray */
31     #define REFRACTED 010 /* refracted (bent) ray */
32     #define TRANS 020 /* transmitted/transferred ray */
33 greg 2.52 #define RAMBIENT 040 /* reflected diffuse interreflection */
34     #define RSPECULAR 0100 /* reflected specular */
35     #define TSHADOW 0200 /* transmitted shadow */
36     #define TAMBIENT 0400 /* transmitted ambient */
37     #define TSPECULAR 01000 /* transmitted specular */
38     #define SHADOW (RSHADOW|TSHADOW)
39     #define AMBIENT (RAMBIENT|TAMBIENT)
40     #define SPECULAR (RSPECULAR|TSPECULAR)
41 greg 1.1
42     /* reflected ray types */
43 greg 2.52 #define RAYREFL (RSHADOW|REFLECTED|RAMBIENT|RSPECULAR)
44 greg 1.1
45 greg 2.29 /* Arrange so double's come first for optimal alignment */
46     /* Pointers and long's come second for 64-bit mode */
47     /* Int's next (unknown length), then floats, followed by short's & char's */
48 greg 1.1 typedef struct ray {
49 greg 2.12 FVECT rorg; /* origin of ray */
50     FVECT rdir; /* normalized direction of ray */
51 greg 2.29 RREAL rmax; /* maximum distance (aft clipping plane) */
52     RREAL rot; /* distance to object */
53     FVECT rop; /* intersection point */
54     FVECT ron; /* intersection surface normal */
55     RREAL rod; /* -DOT(rdir, ron) */
56     RREAL uv[2]; /* local coordinates */
57     FVECT pert; /* surface normal perturbation */
58 greg 2.39 RREAL rmt; /* returned mirrored ray length */
59     RREAL rxt; /* returned unmirrored ray length */
60 greg 2.29 const struct ray *parent; /* ray this originated from */
61 greg 2.12 OBJECT *clipset; /* set of objects currently clipped */
62     OBJECT *newcset; /* next clipset, used for transmission */
63 greg 2.26 void (*revf)(struct ray *); /* ray evaluation function */
64 greg 2.21 void (*hitf)(OBJECT *, struct ray *); /* custom hit test */
65 greg 2.12 OBJREC *ro; /* intersected object (one with material) */
66     FULLXF *rox; /* object transformation */
67 greg 2.29 int *slights; /* list of lights to test for scattering */
68 greg 2.30 RNUMBER rno; /* unique ray number */
69 greg 2.42 OBJECT robj; /* intersected object number */
70 greg 2.57 int rsrc; /* source we're aiming for (or ones to skip) */
71 greg 2.29 float rweight; /* cumulative weight (for termination) */
72 greg 2.42 float gecc; /* scattering eccentricity coefficient */
73 greg 2.51 SCOLOR rcoef; /* contribution coefficient w.r.t. parent */
74     SCOLOR pcol; /* pattern color */
75     SCOLOR mcol; /* mirrored color contribution */
76     SCOLOR rcol; /* returned radiance value */
77 greg 2.12 COLOR cext; /* medium extinction coefficient */
78     COLOR albedo; /* medium scattering albedo */
79 greg 2.42 short rflips; /* surface orientation has been reversed */
80     short rlvl; /* number of reflections for this ray */
81 greg 2.29 short rtype; /* ray type */
82     short crtype; /* cumulative ray type */
83 greg 1.1 } RAY;
84
85 greg 2.26 #define rayvalue(r) (*(r)->revf)(r)
86
87 greg 2.52 #define thrudir(r,v) ((r)->rod > 0 ^ DOT((r)->ron,v) > 0)
88
89 greg 2.51 #define raydistance(r) (pbright((r)->mcol) > 0.5*pbright((r)->rcol) ? \
90 greg 2.39 (r)->rmt : (r)->rxt)
91
92 greg 2.41 #define rayreorient(r) if ((r)->rflips & 1) flipsurface(r); else
93
94 greg 2.47 extern char VersionID[]; /* Radiance version ID string */
95     extern char RFeatureList[]; /* newline-separated feature list */
96 greg 1.6
97 greg 2.12 extern CUBE thescene; /* our scene */
98     extern OBJECT nsceneobjs; /* number of objects in our scene */
99 greg 2.5
100 greg 2.35 extern RNUMBER raynum; /* next ray ID */
101     extern RNUMBER nrays; /* total rays traced so far */
102 greg 1.5
103 greg 2.12 extern OBJREC Lamb; /* a Lambertian surface */
104     extern OBJREC Aftplane; /* aft clipping object */
105
106 greg 2.49 extern void (*trace)(RAY*); /* global trace reporting callback */
107 greg 2.12
108     extern int dimlist[]; /* dimension list for distribution */
109     extern int ndims; /* number of dimensions so far */
110 greg 2.59 extern unsigned long
111     samplendx; /* index for this sample */
112 greg 2.12
113     extern int do_irrad; /* compute irradiance? */
114
115 greg 2.27 extern int rand_samp; /* pure Monte Carlo sampling? */
116
117 greg 2.12 extern double dstrsrc; /* square source distribution */
118     extern double shadthresh; /* shadow threshold */
119     extern double shadcert; /* shadow testing certainty */
120     extern int directrelay; /* number of source relays */
121     extern int vspretest; /* virtual source pretest density */
122     extern int directvis; /* light sources visible to eye? */
123     extern double srcsizerat; /* maximum source size/dist. ratio */
124
125     extern double specthresh; /* specular sampling threshold */
126     extern double specjitter; /* specular sampling jitter */
127
128     extern COLOR cextinction; /* global extinction coefficient */
129     extern COLOR salbedo; /* global scattering albedo */
130     extern double seccg; /* global scattering eccentricity */
131     extern double ssampdist; /* scatter sampling distance */
132
133     extern int backvis; /* back face visibility */
134
135     extern int maxdepth; /* maximum recursion depth */
136     extern double minweight; /* minimum ray weight */
137
138     extern char *ambfile; /* ambient file name */
139     extern COLOR ambval; /* ambient value */
140     extern int ambvwt; /* initial weight for ambient value */
141     extern double ambacc; /* ambient accuracy */
142     extern int ambres; /* ambient resolution */
143     extern int ambdiv; /* ambient divisions */
144     extern int ambssamp; /* ambient super-samples */
145     extern int ambounce; /* ambient bounces */
146     extern char *amblist[]; /* ambient include/exclude list */
147     extern int ambincl; /* include == 1, exclude == 0 */
148
149     extern int ray_pnprocs; /* number of child processes */
150     extern int ray_pnidle; /* number of idle processes */
151
152 greg 2.23 #ifndef AMBLLEN
153     #define AMBLLEN 512 /* max. ambient list length */
154     #endif
155     #define AMBWORD 12 /* average word length */
156 greg 2.12
157     typedef struct { /* rendering parameter holder */
158     int do_irrad;
159 greg 2.27 int rand_samp;
160 greg 2.12 double dstrsrc;
161     double shadthresh;
162     double shadcert;
163     int directrelay;
164     int vspretest;
165     int directvis;
166     double srcsizerat;
167     COLOR cextinction;
168     COLOR salbedo;
169     double seccg;
170     double ssampdist;
171     double specthresh;
172     double specjitter;
173     int backvis;
174     int maxdepth;
175     double minweight;
176     char ambfile[512];
177     COLOR ambval;
178     int ambvwt;
179     double ambacc;
180     int ambres;
181     int ambdiv;
182     int ambssamp;
183     int ambounce;
184     int ambincl;
185     short amblndx[AMBLLEN+1];
186     char amblval[AMBLLEN*AMBWORD];
187 greg 2.38
188     /* PMAP: photon mapping parameters */
189     PhotonMapParams pmapParams [NUM_PMAP_TYPES];
190 greg 2.12 } RAYPARAMS;
191
192     #define rpambmod(p,i) ( (i)>=AMBLLEN||(p)->amblndx[i]<0 ? \
193     (char *)NULL : (p)->amblval+(p)->amblndx[i] )
194
195     /* defined in duphead.c */
196     extern void headclean(void);
197     extern void openheader(void);
198     extern void dupheader(void);
199 schorsch 2.22 /* defined in persist.c */
200 greg 2.46 extern void persistfile(char *pfn);
201 greg 2.12 extern void pfdetach(void);
202     extern void pfclean(void);
203     extern void pflock(int lf);
204     extern void pfhold(void);
205     extern void io_process(void);
206     /* defined in freeobjmem.c */
207     extern int free_objs(OBJECT on, OBJECT no);
208     extern void free_objmem(void);
209     /* defined in preload.c */
210     extern int load_os(OBJREC *op);
211     extern void preload_objs(void);
212 greg 2.56 extern char *shm_boundary;
213     extern void cow_memshare(void);
214     extern void cow_doneshare(void);
215 greg 2.12 /* defined in raycalls.c */
216     extern void ray_init(char *otnm);
217     extern void ray_trace(RAY *r);
218     extern void ray_done(int freall);
219     extern void ray_save(RAYPARAMS *rp);
220     extern void ray_restore(RAYPARAMS *rp);
221     extern void ray_defaults(RAYPARAMS *rp);
222 greg 2.59 extern void reset_random(void);
223 greg 2.12 /* defined in raypcalls.c */
224     extern void ray_pinit(char *otnm, int nproc);
225 greg 2.33 extern int ray_psend(RAY *r);
226 greg 2.12 extern int ray_pqueue(RAY *r);
227     extern int ray_presult(RAY *r, int poll);
228     extern void ray_pdone(int freall);
229     extern void ray_popen(int nadd);
230     extern void ray_pclose(int nsub);
231 greg 2.31 /* defined in ray_fifo.c */
232     extern int (*ray_fifo_out)(RAY *r);
233     extern int ray_fifo_in(RAY *r);
234     extern int ray_fifo_flush(void);
235 greg 2.12 /* defined in raytrace.c */
236 greg 2.51 extern int rayorigin(RAY *r, int rt, const RAY *ro, const SCOLOR rc);
237 greg 2.12 extern void rayclear(RAY *r);
238 greg 2.26 extern void raytrace(RAY *r);
239 greg 2.50 extern int rayreject(OBJREC *o, RAY *r, double t, double rod);
240 greg 2.14 extern void rayhit(OBJECT *oset, RAY *r);
241 greg 2.12 extern void raycont(RAY *r);
242     extern void raytrans(RAY *r);
243 greg 2.40 extern int raytirrad(OBJREC *m, RAY *r);
244 greg 2.12 extern int rayshade(RAY *r, int mod);
245     extern void rayparticipate(RAY *r);
246 greg 2.16 extern void raytexture(RAY *r, OBJECT mod);
247 greg 2.12 extern int raymixture(RAY *r, OBJECT fore, OBJECT back, double coef);
248 greg 2.51 extern void raycontrib(SCOLOR rc, const RAY *r, int flags);
249 greg 2.25 extern double raydist(const RAY *r, int flags);
250 greg 2.12 extern double raynormal(FVECT norm, RAY *r);
251     extern void newrayxf(RAY *r);
252     extern void flipsurface(RAY *r);
253     extern int localhit(RAY *r, CUBE *scene);
254     /* defined in renderopts.c */
255 greg 2.47 extern int feature_status(int ac, char *av[]);
256 greg 2.12 extern int getrenderopt(int ac, char *av[]);
257     extern void print_rdefaults(void);
258     /* defined in srcdraw.c */
259 greg 2.55 extern void init_drawsources(int rad);
260     extern void drawsources(COLORV *pic[], RGBPRIMP primp, float *zbf[],
261 greg 2.12 int x0, int xsiz, int y0, int ysiz);
262 schorsch 2.22 /* defined in rt/initotypes.c */
263 greg 2.46 extern void initotypes(void);
264 greg 2.12 /* module main procedures */
265 greg 2.32 extern void rtrace(char *fname, int nproc);
266 greg 2.49 extern const char *formstr(int f);
267 greg 2.12 extern void rview(void);
268     extern void rpict(int seq, char *pout, char *zout, char *prvr);
269 greg 1.6
270 greg 2.34 #ifdef __FAST_MATH__
271 greg 2.37 #define checknorm(vn) (void)normalize(vn)
272 greg 2.34 #else
273 greg 2.37 #define checknorm(vn)
274 greg 2.34 #endif
275 schorsch 2.17
276     #ifdef __cplusplus
277     }
278 greg 2.12 #endif
279 schorsch 2.17 #endif /* _RAD_RAY_H_ */
280
