root/radiance/ray/src/rt/ray.h
Revision: 1.6
Committed: Thu Jun 20 13:29:31 1991 UTC (34 years ago) by greg
added revf member to ray structure for dynamic evaluation
1 /* Copyright (c) 1990 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * ray.h - header file for routines using rays.
7 *
8 * 8/7/85
9 */
10
11 #include "standard.h"
12
13 #include "object.h"
14
15 #include "color.h"
16
17 /* ray type flags */
18 #define PRIMARY 01 /* original ray */
19 #define SHADOW 02 /* ray to light source */
20 #define REFLECTED 04 /* reflected ray */
21 #define REFRACTED 010 /* refracted (bent) ray */
22 #define TRANS 020 /* transmitted/transferred ray */
23 #define AMBIENT 040 /* ray scattered for interreflection */
24
25 /* reflected ray types */
26 #define RAYREFL (SHADOW|REFLECTED|AMBIENT)
27
28 typedef struct ray {
29 long rno; /* unique ray number */
30 int rlvl; /* number of reflections for this ray */
31 float rweight; /* cumulative weight of this ray */
32 short rtype; /* ray type */
33 short crtype; /* cumulative ray type */
34 struct ray *parent; /* ray this originated from */
35 FVECT rorg; /* origin of ray */
36 FVECT rdir; /* normalized direction of ray */
37 int rsrc; /* source we're aiming for */
38 OBJECT *clipset; /* set of objects currently clipped */
39 OBJECT *newcset; /* next clipset, used for transmission */
40 int (*revf)(); /* evaluation function for this ray */
41 OBJREC *ro; /* intersected object */
42 double rot; /* distance to object */
43 FVECT rop; /* intersection point */
44 FVECT ron; /* intersection surface normal */
45 double rod; /* -DOT(rdir, ron) */
46 FULLXF *rox; /* object transformation */
47 FVECT pert; /* surface normal perturbation */
48 COLOR pcol; /* pattern color */
49 COLOR rcol; /* returned ray value */
50 double rt; /* returned effective ray length */
51 } RAY;
52
53 extern int raytrace();
54
55 extern double raynormal();
56
57 extern int dimlist[]; /* dimension list for distribution */
58 extern int ndims; /* number of dimensions so far */
59 extern int samplendx; /* index for this sample */
60
61 #define MAXDIM 16 /* maximum number of dimensions */
62
63 #define rayvalue(r) (*(r)->revf)(r)
