| 1 |
/* RCSid $Id: ray.h,v 2.57 2024/11/15 20:47:42 greg Exp $ */
| 2 |
| 3 |
* ray.h - header file for routines using rays.
| 4 |
| 5 |
#ifndef _RAD_RAY_H_
| 6 |
#define _RAD_RAY_H_
| 7 |
| 8 |
#include "standard.h"
| 9 |
#include "octree.h"
| 10 |
#include "object.h"
| 11 |
#include "color.h"
| 12 |
#include "pmapparm.h"
| 13 |
| 14 |
#ifdef __cplusplus
| 15 |
extern "C" {
| 16 |
#endif
| 17 |
| 18 |
#ifndef RNUMBER
| 19 |
#define RNUMBER size_t /* ray counter (>= sizeof pointer) */
| 20 |
#endif
| 21 |
| 22 |
#define MAXDIM 32 /* maximum number of sampling dimensions */
| 23 |
| 24 |
/* ray type flags */
| 25 |
#define PRIMARY 01 /* original ray */
| 26 |
#define RSHADOW 02 /* reflected ray to light source */
| 27 |
#define REFLECTED 04 /* reflected ray */
| 28 |
#define REFRACTED 010 /* refracted (bent) ray */
| 29 |
#define TRANS 020 /* transmitted/transferred ray */
| 30 |
#define RAMBIENT 040 /* reflected diffuse interreflection */
| 31 |
#define RSPECULAR 0100 /* reflected specular */
| 32 |
#define TSHADOW 0200 /* transmitted shadow */
| 33 |
#define TAMBIENT 0400 /* transmitted ambient */
| 34 |
#define TSPECULAR 01000 /* transmitted specular */
| 35 |
#define SHADOW (RSHADOW|TSHADOW)
| 36 |
#define AMBIENT (RAMBIENT|TAMBIENT)
| 37 |
#define SPECULAR (RSPECULAR|TSPECULAR)
| 38 |
| 39 |
/* reflected ray types */
| 40 |
#define RAYREFL (RSHADOW|REFLECTED|RAMBIENT|RSPECULAR)
| 41 |
| 42 |
/* Arrange so double's come first for optimal alignment */
| 43 |
/* Pointers and long's come second for 64-bit mode */
| 44 |
/* Int's next (unknown length), then floats, followed by short's & char's */
| 45 |
typedef struct ray {
| 46 |
FVECT rorg; /* origin of ray */
| 47 |
FVECT rdir; /* normalized direction of ray */
| 48 |
RREAL rmax; /* maximum distance (aft clipping plane) */
| 49 |
RREAL rot; /* distance to object */
| 50 |
FVECT rop; /* intersection point */
| 51 |
FVECT ron; /* intersection surface normal */
| 52 |
RREAL rod; /* -DOT(rdir, ron) */
| 53 |
RREAL uv[2]; /* local coordinates */
| 54 |
FVECT pert; /* surface normal perturbation */
| 55 |
RREAL rmt; /* returned mirrored ray length */
| 56 |
RREAL rxt; /* returned unmirrored ray length */
| 57 |
const struct ray *parent; /* ray this originated from */
| 58 |
OBJECT *clipset; /* set of objects currently clipped */
| 59 |
OBJECT *newcset; /* next clipset, used for transmission */
| 60 |
void (*revf)(struct ray *); /* ray evaluation function */
| 61 |
void (*hitf)(OBJECT *, struct ray *); /* custom hit test */
| 62 |
OBJREC *ro; /* intersected object (one with material) */
| 63 |
FULLXF *rox; /* object transformation */
| 64 |
int *slights; /* list of lights to test for scattering */
| 65 |
RNUMBER rno; /* unique ray number */
| 66 |
OBJECT robj; /* intersected object number */
| 67 |
int rsrc; /* source we're aiming for (or ones to skip) */
| 68 |
float rweight; /* cumulative weight (for termination) */
| 69 |
float gecc; /* scattering eccentricity coefficient */
| 70 |
SCOLOR rcoef; /* contribution coefficient w.r.t. parent */
| 71 |
SCOLOR pcol; /* pattern color */
| 72 |
SCOLOR mcol; /* mirrored color contribution */
| 73 |
SCOLOR rcol; /* returned radiance value */
| 74 |
COLOR cext; /* medium extinction coefficient */
| 75 |
COLOR albedo; /* medium scattering albedo */
| 76 |
short rflips; /* surface orientation has been reversed */
| 77 |
short rlvl; /* number of reflections for this ray */
| 78 |
short rtype; /* ray type */
| 79 |
short crtype; /* cumulative ray type */
| 80 |
} RAY;
| 81 |
| 82 |
#define rayvalue(r) (*(r)->revf)(r)
| 83 |
| 84 |
#define thrudir(r,v) ((r)->rod > 0 ^ DOT((r)->ron,v) > 0)
| 85 |
| 86 |
#define raydistance(r) (pbright((r)->mcol) > 0.5*pbright((r)->rcol) ? \
| 87 |
(r)->rmt : (r)->rxt)
| 88 |
| 89 |
#define rayreorient(r) if ((r)->rflips & 1) flipsurface(r); else
| 90 |
| 91 |
extern char VersionID[]; /* Radiance version ID string */
| 92 |
extern char RFeatureList[]; /* newline-separated feature list */
| 93 |
| 94 |
extern CUBE thescene; /* our scene */
| 95 |
extern OBJECT nsceneobjs; /* number of objects in our scene */
| 96 |
| 97 |
extern RNUMBER raynum; /* next ray ID */
| 98 |
extern RNUMBER nrays; /* total rays traced so far */
| 99 |
| 100 |
extern OBJREC Lamb; /* a Lambertian surface */
| 101 |
extern OBJREC Aftplane; /* aft clipping object */
| 102 |
| 103 |
extern void (*trace)(RAY*); /* global trace reporting callback */
| 104 |
| 105 |
extern int dimlist[]; /* dimension list for distribution */
| 106 |
extern int ndims; /* number of dimensions so far */
| 107 |
extern int samplendx; /* index for this sample */
| 108 |
| 109 |
extern int do_irrad; /* compute irradiance? */
| 110 |
| 111 |
extern int rand_samp; /* pure Monte Carlo sampling? */
| 112 |
| 113 |
extern double dstrsrc; /* square source distribution */
| 114 |
extern double shadthresh; /* shadow threshold */
| 115 |
extern double shadcert; /* shadow testing certainty */
| 116 |
extern int directrelay; /* number of source relays */
| 117 |
extern int vspretest; /* virtual source pretest density */
| 118 |
extern int directvis; /* light sources visible to eye? */
| 119 |
extern double srcsizerat; /* maximum source size/dist. ratio */
| 120 |
| 121 |
extern double specthresh; /* specular sampling threshold */
| 122 |
extern double specjitter; /* specular sampling jitter */
| 123 |
| 124 |
extern COLOR cextinction; /* global extinction coefficient */
| 125 |
extern COLOR salbedo; /* global scattering albedo */
| 126 |
extern double seccg; /* global scattering eccentricity */
| 127 |
extern double ssampdist; /* scatter sampling distance */
| 128 |
| 129 |
extern int backvis; /* back face visibility */
| 130 |
| 131 |
extern int maxdepth; /* maximum recursion depth */
| 132 |
extern double minweight; /* minimum ray weight */
| 133 |
| 134 |
extern char *ambfile; /* ambient file name */
| 135 |
extern COLOR ambval; /* ambient value */
| 136 |
extern int ambvwt; /* initial weight for ambient value */
| 137 |
extern double ambacc; /* ambient accuracy */
| 138 |
extern int ambres; /* ambient resolution */
| 139 |
extern int ambdiv; /* ambient divisions */
| 140 |
extern int ambssamp; /* ambient super-samples */
| 141 |
extern int ambounce; /* ambient bounces */
| 142 |
extern char *amblist[]; /* ambient include/exclude list */
| 143 |
extern int ambincl; /* include == 1, exclude == 0 */
| 144 |
| 145 |
extern int ray_pnprocs; /* number of child processes */
| 146 |
extern int ray_pnidle; /* number of idle processes */
| 147 |
| 148 |
#ifndef AMBLLEN
| 149 |
#define AMBLLEN 512 /* max. ambient list length */
| 150 |
#endif
| 151 |
#define AMBWORD 12 /* average word length */
| 152 |
| 153 |
typedef struct { /* rendering parameter holder */
| 154 |
int do_irrad;
| 155 |
int rand_samp;
| 156 |
double dstrsrc;
| 157 |
double shadthresh;
| 158 |
double shadcert;
| 159 |
int directrelay;
| 160 |
int vspretest;
| 161 |
int directvis;
| 162 |
double srcsizerat;
| 163 |
COLOR cextinction;
| 164 |
COLOR salbedo;
| 165 |
double seccg;
| 166 |
double ssampdist;
| 167 |
double specthresh;
| 168 |
double specjitter;
| 169 |
int backvis;
| 170 |
int maxdepth;
| 171 |
double minweight;
| 172 |
char ambfile[512];
| 173 |
COLOR ambval;
| 174 |
int ambvwt;
| 175 |
double ambacc;
| 176 |
int ambres;
| 177 |
int ambdiv;
| 178 |
int ambssamp;
| 179 |
int ambounce;
| 180 |
int ambincl;
| 181 |
short amblndx[AMBLLEN+1];
| 182 |
char amblval[AMBLLEN*AMBWORD];
| 183 |
| 184 |
/* PMAP: photon mapping parameters */
| 185 |
PhotonMapParams pmapParams [NUM_PMAP_TYPES];
| 186 |
} RAYPARAMS;
| 187 |
| 188 |
#define rpambmod(p,i) ( (i)>=AMBLLEN||(p)->amblndx[i]<0 ? \
| 189 |
(char *)NULL : (p)->amblval+(p)->amblndx[i] )
| 190 |
| 191 |
/* defined in duphead.c */
| 192 |
extern void headclean(void);
| 193 |
extern void openheader(void);
| 194 |
extern void dupheader(void);
| 195 |
/* defined in persist.c */
| 196 |
extern void persistfile(char *pfn);
| 197 |
extern void pfdetach(void);
| 198 |
extern void pfclean(void);
| 199 |
extern void pflock(int lf);
| 200 |
extern void pfhold(void);
| 201 |
extern void io_process(void);
| 202 |
/* defined in freeobjmem.c */
| 203 |
extern int free_objs(OBJECT on, OBJECT no);
| 204 |
extern void free_objmem(void);
| 205 |
/* defined in preload.c */
| 206 |
extern int load_os(OBJREC *op);
| 207 |
extern void preload_objs(void);
| 208 |
extern char *shm_boundary;
| 209 |
extern void cow_memshare(void);
| 210 |
extern void cow_doneshare(void);
| 211 |
/* defined in raycalls.c */
| 212 |
extern void ray_init(char *otnm);
| 213 |
extern void ray_trace(RAY *r);
| 214 |
extern void ray_done(int freall);
| 215 |
extern void ray_save(RAYPARAMS *rp);
| 216 |
extern void ray_restore(RAYPARAMS *rp);
| 217 |
extern void ray_defaults(RAYPARAMS *rp);
| 218 |
/* defined in raypcalls.c */
| 219 |
extern void ray_pinit(char *otnm, int nproc);
| 220 |
extern int ray_psend(RAY *r);
| 221 |
extern int ray_pqueue(RAY *r);
| 222 |
extern int ray_presult(RAY *r, int poll);
| 223 |
extern void ray_pdone(int freall);
| 224 |
extern void ray_popen(int nadd);
| 225 |
extern void ray_pclose(int nsub);
| 226 |
/* defined in ray_fifo.c */
| 227 |
extern int (*ray_fifo_out)(RAY *r);
| 228 |
extern int ray_fifo_in(RAY *r);
| 229 |
extern int ray_fifo_flush(void);
| 230 |
/* defined in raytrace.c */
| 231 |
extern int rayorigin(RAY *r, int rt, const RAY *ro, const SCOLOR rc);
| 232 |
extern void rayclear(RAY *r);
| 233 |
extern void raytrace(RAY *r);
| 234 |
extern int rayreject(OBJREC *o, RAY *r, double t, double rod);
| 235 |
extern void rayhit(OBJECT *oset, RAY *r);
| 236 |
extern void raycont(RAY *r);
| 237 |
extern void raytrans(RAY *r);
| 238 |
extern int raytirrad(OBJREC *m, RAY *r);
| 239 |
extern int rayshade(RAY *r, int mod);
| 240 |
extern void rayparticipate(RAY *r);
| 241 |
extern void raytexture(RAY *r, OBJECT mod);
| 242 |
extern int raymixture(RAY *r, OBJECT fore, OBJECT back, double coef);
| 243 |
extern void raycontrib(SCOLOR rc, const RAY *r, int flags);
| 244 |
extern double raydist(const RAY *r, int flags);
| 245 |
extern double raynormal(FVECT norm, RAY *r);
| 246 |
extern void newrayxf(RAY *r);
| 247 |
extern void flipsurface(RAY *r);
| 248 |
extern int localhit(RAY *r, CUBE *scene);
| 249 |
/* defined in renderopts.c */
| 250 |
extern int feature_status(int ac, char *av[]);
| 251 |
extern int getrenderopt(int ac, char *av[]);
| 252 |
extern void print_rdefaults(void);
| 253 |
/* defined in srcdraw.c */
| 254 |
extern void init_drawsources(int rad);
| 255 |
extern void drawsources(COLORV *pic[], RGBPRIMP primp, float *zbf[],
| 256 |
int x0, int xsiz, int y0, int ysiz);
| 257 |
/* defined in rt/initotypes.c */
| 258 |
extern void initotypes(void);
| 259 |
/* module main procedures */
| 260 |
extern void rtrace(char *fname, int nproc);
| 261 |
extern const char *formstr(int f);
| 262 |
extern void rview(void);
| 263 |
extern void rpict(int seq, char *pout, char *zout, char *prvr);
| 264 |
| 265 |
#ifdef __FAST_MATH__
| 266 |
#define checknorm(vn) (void)normalize(vn)
| 267 |
#else
| 268 |
| 269 |
#endif
| 270 |
| 271 |
#ifdef __cplusplus
| 272 |
| 273 |
#endif
| 274 |
#endif /* _RAD_RAY_H_ */
| 275 |
