root/radiance/ray/src/rt/ray.h
Revision: 2.13
Committed: Tue Feb 25 02:47:23 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.12: +2 -57 lines
1 /* RCSid $Id$ */
2 /*
3 * ray.h - header file for routines using rays.
4 */
5
6 #include "copyright.h"
7
8 #include "standard.h"
9
10 #include "octree.h"
11
12 #include "object.h"
13
14 #include "color.h"
15
16 #define MAXDIM 32 /* maximum number of dimensions */
17
18 /* ray type flags */
19 #define PRIMARY 01 /* original ray */
20 #define SHADOW 02 /* ray to light source */
21 #define REFLECTED 04 /* reflected ray */
22 #define REFRACTED 010 /* refracted (bent) ray */
23 #define TRANS 020 /* transmitted/transferred ray */
24 #define AMBIENT 040 /* ray scattered for interreflection */
25 #define SPECULAR 0100 /* ray scattered for specular */
26
27 /* reflected ray types */
28 #define RAYREFL (SHADOW|REFLECTED|AMBIENT|SPECULAR)
29
30 typedef struct ray {
31 unsigned long rno; /* unique ray number */
32 int rlvl; /* number of reflections for this ray */
33 float rweight; /* cumulative weight of this ray */
34 short rtype; /* ray type */
35 short crtype; /* cumulative ray type */
36 struct ray *parent; /* ray this originated from */
37 FVECT rorg; /* origin of ray */
38 FVECT rdir; /* normalized direction of ray */
39 double rmax; /* maximum distance (aft clipping plane) */
40 int rsrc; /* source we're aiming for */
41 OBJECT *clipset; /* set of objects currently clipped */
42 OBJECT *newcset; /* next clipset, used for transmission */
43 void (*revf)(); /* evaluation function for this ray */
44 OBJECT robj; /* intersected object number */
45 OBJREC *ro; /* intersected object (one with material) */
46 double rot; /* distance to object */
47 FVECT rop; /* intersection point */
48 FVECT ron; /* intersection surface normal */
49 double rod; /* -DOT(rdir, ron) */
50 FULLXF *rox; /* object transformation */
51 FVECT pert; /* surface normal perturbation */
52 COLOR pcol; /* pattern color */
53 COLOR rcol; /* returned ray value */
54 double rt; /* returned effective ray length */
55 COLOR cext; /* medium extinction coefficient */
56 COLOR albedo; /* medium scattering albedo */
57 float gecc; /* scattering eccentricity coefficient */
58 int *slights; /* list of lights to test for scattering */
59 } RAY;
60
61 #define rayvalue(r) (*(r)->revf)(r)
62
63 extern char VersionID[]; /* Radiance version ID string */
64
65 extern CUBE thescene; /* our scene */
66 extern OBJECT nsceneobjs; /* number of objects in our scene */
67
68 extern unsigned long raynum; /* next ray ID */
69 extern unsigned long nrays; /* total rays traced so far */
70
71 extern OBJREC Lamb; /* a Lambertian surface */
72 extern OBJREC Aftplane; /* aft clipping object */
73
74 extern void (*trace)(); /* global trace reporting callback */
75
76 extern int dimlist[]; /* dimension list for distribution */
77 extern int ndims; /* number of dimensions so far */
78 extern int samplendx; /* index for this sample */
79
80 extern int ray_savesiz; /* size of parameter save buffer */
81
82 extern int do_irrad; /* compute irradiance? */
83
84 extern double dstrsrc; /* square source distribution */
85 extern double shadthresh; /* shadow threshold */
86 extern double shadcert; /* shadow testing certainty */
87 extern int directrelay; /* number of source relays */
88 extern int vspretest; /* virtual source pretest density */
89 extern int directvis; /* light sources visible to eye? */
90 extern double srcsizerat; /* maximum source size/dist. ratio */
91
92 extern double specthresh; /* specular sampling threshold */
93 extern double specjitter; /* specular sampling jitter */
94
95 extern COLOR cextinction; /* global extinction coefficient */
96 extern COLOR salbedo; /* global scattering albedo */
97 extern double seccg; /* global scattering eccentricity */
98 extern double ssampdist; /* scatter sampling distance */
99
100 extern int backvis; /* back face visibility */
101
102 extern int maxdepth; /* maximum recursion depth */
103 extern double minweight; /* minimum ray weight */
104
105 extern char *ambfile; /* ambient file name */
106 extern COLOR ambval; /* ambient value */
107 extern int ambvwt; /* initial weight for ambient value */
108 extern double ambacc; /* ambient accuracy */
109 extern int ambres; /* ambient resolution */
110 extern int ambdiv; /* ambient divisions */
111 extern int ambssamp; /* ambient super-samples */
112 extern int ambounce; /* ambient bounces */
113 extern char *amblist[]; /* ambient include/exclude list */
114 extern int ambincl; /* include == 1, exclude == 0 */
115
116 extern int ray_pnprocs; /* number of child processes */
117 extern int ray_pnidle; /* number of idle processes */
118
119 #define AMBLLEN 128 /* max. ambient list length */
120 #define AMBWORD 8 /* average word length */
121
122 typedef struct { /* rendering parameter holder */
123 int do_irrad;
124 double dstrsrc;
125 double shadthresh;
126 double shadcert;
127 int directrelay;
128 int vspretest;
129 int directvis;
130 double srcsizerat;
131 COLOR cextinction;
132 COLOR salbedo;
133 double seccg;
134 double ssampdist;
135 double specthresh;
136 double specjitter;
137 int backvis;
138 int maxdepth;
139 double minweight;
140 char ambfile[512];
141 COLOR ambval;
142 int ambvwt;
143 double ambacc;
144 int ambres;
145 int ambdiv;
146 int ambssamp;
147 int ambounce;
148 int ambincl;
149 short amblndx[AMBLLEN+1];
150 char amblval[AMBLLEN*AMBWORD];
151 } RAYPARAMS;
152
153 #define rpambmod(p,i) ( (i)>=AMBLLEN||(p)->amblndx[i]<0 ? \
154 (char *)NULL : (p)->amblval+(p)->amblndx[i] )
155
156 #ifdef NOPROTO
157
158 extern void headclean();
159 extern void openheader();
160 extern void dupheader();
161 extern void pfdetach();
162 extern void pfclean();
163 extern void pflock();
164 extern void pfhold();
165 extern void io_process();
166 extern int free_objs();
167 extern void free_objmem();
168 extern int load_os();
169 extern void preload_objs();
170 extern void ray_init();
171 extern void ray_trace();
172 extern void ray_done();
173 extern void ray_save();
174 extern void ray_restore();
175 extern void ray_defaults();
176 extern void ray_pinit();
177 extern void ray_psend();
178 extern int ray_pqueue();
179 extern int ray_presult();
180 extern void ray_pdone();
181 extern void ray_popen();
182 extern void ray_pclose();
183 extern int rayorigin();
184 extern void rayclear();
185 extern void raytrace();
186 extern void raycont();
187 extern void raytrans();
188 extern int rayshade();
189 extern void rayparticipate();
190 extern int raymixture();
191 extern double raydist();
192 extern double raynormal();
193 extern void newrayxf();
194 extern void flipsurface();
195 extern int localhit();
196 extern int getrenderopt();
197 extern void print_rdefaults();
198 extern void drawsources();
199 extern void rtrace();
200 extern void rview();
201 extern void rpict();
202
203 #else
204 /* defined in duphead.c */
205 extern void headclean(void);
206 extern void openheader(void);
207 extern void dupheader(void);
208 extern void pfdetach(void);
209 extern void pfclean(void);
210 extern void pflock(int lf);
211 extern void pfhold(void);
212 extern void io_process(void);
213 /* defined in freeobjmem.c */
214 extern int free_objs(OBJECT on, OBJECT no);
215 extern void free_objmem(void);
216 /* defined in preload.c */
217 extern int load_os(OBJREC *op);
218 extern void preload_objs(void);
219 /* defined in raycalls.c */
220 extern void ray_init(char *otnm);
221 extern void ray_trace(RAY *r);
222 extern void ray_done(int freall);
223 extern void ray_save(RAYPARAMS *rp);
224 extern void ray_restore(RAYPARAMS *rp);
225 extern void ray_defaults(RAYPARAMS *rp);
226 /* defined in raypcalls.c */
227 extern void ray_pinit(char *otnm, int nproc);
228 extern void ray_psend(RAY *r);
229 extern int ray_pqueue(RAY *r);
230 extern int ray_presult(RAY *r, int poll);
231 extern void ray_pdone(int freall);
232 extern void ray_popen(int nadd);
233 extern void ray_pclose(int nsub);
234 /* defined in raytrace.c */
235 extern int rayorigin(RAY *r, RAY *ro, int rt, double rw);
236 extern void rayclear(RAY *r);
237 extern void raytrace(RAY *r);
238 extern void raycont(RAY *r);
239 extern void raytrans(RAY *r);
240 extern int rayshade(RAY *r, int mod);
241 extern void rayparticipate(RAY *r);
242 extern int raymixture(RAY *r, OBJECT fore, OBJECT back, double coef);
243 extern double raydist(RAY *r, int flags);
244 extern double raynormal(FVECT norm, RAY *r);
245 extern void newrayxf(RAY *r);
246 extern void flipsurface(RAY *r);
247 extern int localhit(RAY *r, CUBE *scene);
248 /* defined in renderopts.c */
249 extern int getrenderopt(int ac, char *av[]);
250 extern void print_rdefaults(void);
251 /* defined in srcdraw.c */
252 extern void drawsources(COLOR *pic[], float *zbf[],
253 int x0, int xsiz, int y0, int ysiz);
254 /* module main procedures */
255 extern void rtrace(char *fname);
256 extern void rview(void);
257 extern void rpict(int seq, char *pout, char *zout, char *prvr);
258
259 #endif
