| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id$";
| 3 |
#endif
| 4 |
| 5 |
* Preload associated object structures to maximize memory sharing.
| 6 |
| 7 |
* External symbols declared in ray.h
| 8 |
| 9 |
| 10 |
| 11 |
* The Radiance Software License, Version 1.0
| 12 |
| 13 |
* Copyright (c) 1990 - 2002 The Regents of the University of California,
| 14 |
* through Lawrence Berkeley National Laboratory. All rights reserved.
| 15 |
| 16 |
* Redistribution and use in source and binary forms, with or without
| 17 |
* modification, are permitted provided that the following conditions
| 18 |
* are met:
| 19 |
| 20 |
* 1. Redistributions of source code must retain the above copyright
| 21 |
* notice, this list of conditions and the following disclaimer.
| 22 |
| 23 |
* 2. Redistributions in binary form must reproduce the above copyright
| 24 |
* notice, this list of conditions and the following disclaimer in
| 25 |
* the documentation and/or other materials provided with the
| 26 |
* distribution.
| 27 |
| 28 |
* 3. The end-user documentation included with the redistribution,
| 29 |
* if any, must include the following acknowledgment:
| 30 |
* "This product includes Radiance software
| 31 |
* (http://radsite.lbl.gov/)
| 32 |
* developed by the Lawrence Berkeley National Laboratory
| 33 |
* (http://www.lbl.gov/)."
| 34 |
* Alternately, this acknowledgment may appear in the software itself,
| 35 |
* if and wherever such third-party acknowledgments normally appear.
| 36 |
| 37 |
* 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
| 38 |
* and "The Regents of the University of California" must
| 39 |
* not be used to endorse or promote products derived from this
| 40 |
* software without prior written permission. For written
| 41 |
* permission, please contact [email protected].
| 42 |
| 43 |
* 5. Products derived from this software may not be called "Radiance",
| 44 |
* nor may "Radiance" appear in their name, without prior written
| 45 |
* permission of Lawrence Berkeley National Laboratory.
| 46 |
| 47 |
* THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
| 48 |
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
| 49 |
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
| 50 |
* DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
| 51 |
* ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
| 52 |
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
| 53 |
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
| 54 |
* USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
| 55 |
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
| 56 |
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
| 57 |
* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
| 58 |
* SUCH DAMAGE.
| 59 |
| 60 |
| 61 |
* This software consists of voluntary contributions made by many
| 62 |
* individuals on behalf of Lawrence Berkeley National Laboratory. For more
| 63 |
* information on Lawrence Berkeley National Laboratory, please see
| 64 |
* <http://www.lbl.gov/>.
| 65 |
| 66 |
| 67 |
#include "standard.h"
| 68 |
#include "octree.h"
| 69 |
#include "object.h"
| 70 |
#include "otypes.h"
| 71 |
#include "face.h"
| 72 |
#include "cone.h"
| 73 |
#include "instance.h"
| 74 |
#include "color.h"
| 75 |
#include "data.h"
| 76 |
| 77 |
| 78 |
/* KEEP THIS ROUTINE CONSISTENT WITH THE DIFFERENT OBJECT FUNCTIONS! */
| 79 |
| 80 |
| 81 |
int
| 82 |
load_os(op) /* load associated data for object */
| 83 |
register OBJREC *op;
| 84 |
| 85 |
DATARRAY *dp;
| 86 |
| 87 |
switch (op->otype) {
| 88 |
case OBJ_FACE: /* polygon */
| 89 |
getface(op);
| 90 |
return(1);
| 91 |
case OBJ_CONE: /* cone */
| 92 |
case OBJ_RING: /* disk */
| 93 |
case OBJ_CYLINDER: /* cylinder */
| 94 |
case OBJ_CUP: /* inverted cone */
| 95 |
case OBJ_TUBE: /* inverted cylinder */
| 96 |
getcone(op, 1);
| 97 |
return(1);
| 98 |
case OBJ_INSTANCE: /* octree instance */
| 99 |
getinstance(op, IO_ALL);
| 100 |
return(1);
| 101 |
case PAT_CPICT: /* color picture */
| 102 |
if (op->oargs.nsargs < 4)
| 103 |
goto sargerr;
| 104 |
getpict(op->oargs.sarg[3]);
| 105 |
getfunc(op, 4, 0x3<<5, 0);
| 106 |
return(1);
| 107 |
case PAT_CDATA: /* color data */
| 108 |
dp = getdata(op->oargs.sarg[3]);
| 109 |
getdata(op->oargs.sarg[4]);
| 110 |
getdata(op->oargs.sarg[5]);
| 111 |
getfunc(op, 6, ((1<<dp->nd)-1)<<7, 0);
| 112 |
return(1);
| 113 |
case PAT_BDATA: /* brightness data */
| 114 |
if (op->oargs.nsargs < 2)
| 115 |
goto sargerr;
| 116 |
dp = getdata(op->oargs.sarg[1]);
| 117 |
getfunc(op, 2, ((1<<dp->nd)-1)<<3, 0);
| 118 |
return(1);
| 119 |
case PAT_BFUNC: /* brightness function */
| 120 |
getfunc(op, 1, 0x1, 0);
| 121 |
return(1);
| 122 |
case PAT_CFUNC: /* color function */
| 123 |
getfunc(op, 3, 0x7, 0);
| 124 |
return(1);
| 125 |
case TEX_DATA: /* texture data */
| 126 |
if (op->oargs.nsargs < 6)
| 127 |
goto sargerr;
| 128 |
| 129 |
| 130 |
| 131 |
getfunc(op, 6, ((1<<dp->nd)-1)<<7, 1);
| 132 |
return(1);
| 133 |
case TEX_FUNC: /* texture function */
| 134 |
getfunc(op, 3, 0x7, 1);
| 135 |
return(1);
| 136 |
case MIX_DATA: /* mixture data */
| 137 |
| 138 |
getfunc(op, 4, ((1<<dp->nd)-1)<<5, 0);
| 139 |
return(1);
| 140 |
case MIX_PICT: /* mixture picture */
| 141 |
| 142 |
| 143 |
return(1);
| 144 |
case MIX_FUNC: /* mixture function */
| 145 |
getfunc(op, 3, 0x4, 0);
| 146 |
return(1);
| 147 |
case MAT_PLASTIC2: /* anisotropic plastic */
| 148 |
case MAT_METAL2: /* anisotropic metal */
| 149 |
| 150 |
return(1);
| 151 |
case MAT_BRTDF: /* BRDTfunc material */
| 152 |
getfunc(op, 9, 0x3f, 0);
| 153 |
return(1);
| 154 |
case MAT_PDATA: /* plastic BRDF data */
| 155 |
case MAT_MDATA: /* metal BRDF data */
| 156 |
case MAT_TDATA: /* trans BRDF data */
| 157 |
| 158 |
goto sargerr;
| 159 |
| 160 |
getfunc(op, 2, 0, 0);
| 161 |
return(1);
| 162 |
case MAT_PFUNC: /* plastic BRDF func */
| 163 |
case MAT_MFUNC: /* metal BRDF func */
| 164 |
case MAT_TFUNC: /* trans BRDF func */
| 165 |
getfunc(op, 1, 0, 0);
| 166 |
return(1);
| 167 |
case MAT_DIRECT1: /* prism1 material */
| 168 |
getfunc(op, 4, 0xf, 1);
| 169 |
return(1);
| 170 |
case MAT_DIRECT2: /* prism2 material */
| 171 |
getfunc(op, 8, 0xff, 1);
| 172 |
return(1);
| 173 |
| 174 |
/* nothing to load for the remaining types */
| 175 |
return(0);
| 176 |
sargerr:
| 177 |
objerror(op, USER, "too few string arguments");
| 178 |
| 179 |
| 180 |
| 181 |
void
| 182 |
preload_objs() /* preload object data structures */
| 183 |
| 184 |
register OBJECT on;
| 185 |
/* note that nobjects may change during loop */
| 186 |
for (on = 0; on < nobjects; on++)
| 187 |
load_os(objptr(on));
| 188 |
