1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: preload.c,v 2.12 2011/08/16 18:09:53 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Preload associated object structures to maximize memory sharing. |
6 |
7 |
* External symbols declared in ray.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include "ray.h" |
13 |
#include "otypes.h" |
14 |
#include "face.h" |
15 |
#include "cone.h" |
16 |
#include "instance.h" |
17 |
#include "mesh.h" |
18 |
#include "data.h" |
19 |
#include "func.h" |
20 |
#include "bsdf.h" |
21 |
22 |
23 |
/* KEEP THIS ROUTINE CONSISTENT WITH THE DIFFERENT OBJECT FUNCTIONS! */ |
24 |
25 |
26 |
int |
27 |
load_os( /* load associated data for object */ |
28 |
OBJREC *op |
29 |
30 |
31 |
DATARRAY *dp; |
32 |
33 |
switch (op->otype) { |
34 |
case OBJ_FACE: /* polygon */ |
35 |
getface(op); |
36 |
return(1); |
37 |
case OBJ_CONE: /* cone */ |
38 |
case OBJ_RING: /* disk */ |
39 |
case OBJ_CYLINDER: /* cylinder */ |
40 |
case OBJ_CUP: /* inverted cone */ |
41 |
case OBJ_TUBE: /* inverted cylinder */ |
42 |
getcone(op, 1); |
43 |
return(1); |
44 |
case OBJ_INSTANCE: /* octree instance */ |
45 |
getinstance(op, IO_ALL); |
46 |
return(1); |
47 |
case OBJ_MESH: /* mesh instance */ |
48 |
getmeshinst(op, IO_ALL); |
49 |
return(1); |
50 |
case PAT_CPICT: /* color picture */ |
51 |
if (op->oargs.nsargs < 4) |
52 |
goto sargerr; |
53 |
getpict(op->oargs.sarg[3]); |
54 |
getfunc(op, 4, 0x3<<5, 0); |
55 |
return(1); |
56 |
case PAT_CDATA: /* color data */ |
57 |
dp = getdata(op->oargs.sarg[3]); |
58 |
getdata(op->oargs.sarg[4]); |
59 |
getdata(op->oargs.sarg[5]); |
60 |
getfunc(op, 6, ((1<<dp->nd)-1)<<7, 0); |
61 |
return(1); |
62 |
case PAT_BDATA: /* brightness data */ |
63 |
if (op->oargs.nsargs < 2) |
64 |
goto sargerr; |
65 |
dp = getdata(op->oargs.sarg[1]); |
66 |
getfunc(op, 2, ((1<<dp->nd)-1)<<3, 0); |
67 |
return(1); |
68 |
case PAT_BFUNC: /* brightness function */ |
69 |
getfunc(op, 1, 0x1, 0); |
70 |
return(1); |
71 |
case PAT_CFUNC: /* color function */ |
72 |
getfunc(op, 3, 0x7, 0); |
73 |
return(1); |
74 |
case TEX_DATA: /* texture data */ |
75 |
if (op->oargs.nsargs < 6) |
76 |
goto sargerr; |
77 |
78 |
79 |
80 |
getfunc(op, 6, ((1<<dp->nd)-1)<<7, 1); |
81 |
return(1); |
82 |
case TEX_FUNC: /* texture function */ |
83 |
getfunc(op, 3, 0x7, 1); |
84 |
return(1); |
85 |
case MIX_DATA: /* mixture data */ |
86 |
87 |
getfunc(op, 4, ((1<<dp->nd)-1)<<5, 0); |
88 |
return(1); |
89 |
case MIX_PICT: /* mixture picture */ |
90 |
91 |
92 |
return(1); |
93 |
case MIX_FUNC: /* mixture function */ |
94 |
getfunc(op, 3, 0x4, 0); |
95 |
return(1); |
96 |
case MAT_PLASTIC2: /* anisotropic plastic */ |
97 |
case MAT_METAL2: /* anisotropic metal */ |
98 |
99 |
return(1); |
100 |
case MAT_BRTDF: /* BRDTfunc material */ |
101 |
getfunc(op, 9, 0x3f, 0); |
102 |
return(1); |
103 |
case MAT_BSDF: /* BSDF material */ |
104 |
105 |
goto sargerr; |
106 |
getfunc(op, 5, 0x1d, 1); |
107 |
loadBSDF(op->oargs.sarg[1]); |
108 |
return(1); |
109 |
case MAT_PDATA: /* plastic BRDF data */ |
110 |
case MAT_MDATA: /* metal BRDF data */ |
111 |
case MAT_TDATA: /* trans BRDF data */ |
112 |
113 |
goto sargerr; |
114 |
115 |
getfunc(op, 2, 0, 0); |
116 |
return(1); |
117 |
case MAT_PFUNC: /* plastic BRDF func */ |
118 |
case MAT_MFUNC: /* metal BRDF func */ |
119 |
case MAT_TFUNC: /* trans BRDF func */ |
120 |
getfunc(op, 1, 0, 0); |
121 |
return(1); |
122 |
case MAT_DIRECT1: /* prism1 material */ |
123 |
getfunc(op, 4, 0xf, 1); |
124 |
return(1); |
125 |
case MAT_DIRECT2: /* prism2 material */ |
126 |
getfunc(op, 8, 0xff, 1); |
127 |
return(1); |
128 |
129 |
/* nothing to load for the remaining types */ |
130 |
return(0); |
131 |
sargerr: |
132 |
objerror(op, USER, "too few string arguments"); |
133 |
return 0; /* pro forma return */ |
134 |
135 |
136 |
137 |
void |
138 |
preload_objs(void) /* preload object data structures */ |
139 |
140 |
OBJECT on; |
141 |
/* note that nobjects may change during loop */ |
142 |
for (on = 0; on < nobjects; on++) |
143 |
load_os(objptr(on)); |
144 |
