--- ray/src/rt/preload.c 2003/02/25 02:47:23 2.7 +++ ray/src/rt/preload.c 2004/03/30 16:13:01 2.8 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: preload.c,v 2.7 2003/02/25 02:47:23 greg Exp $"; +static const char RCSid[] = "$Id: preload.c,v 2.8 2004/03/30 16:13:01 schorsch Exp $"; #endif /* * Preload associated object structures to maximize memory sharing. @@ -18,14 +18,17 @@ static const char RCSid[] = "$Id: preload.c,v 2.7 2003 #include "instance.h" #include "color.h" #include "data.h" +#include "func.h" +#include "ray.h" /* KEEP THIS ROUTINE CONSISTENT WITH THE DIFFERENT OBJECT FUNCTIONS! */ -int -load_os(op) /* load associated data for object */ -register OBJREC *op; +extern int +load_os( /* load associated data for object */ + register OBJREC *op +) { DATARRAY *dp; @@ -120,11 +123,12 @@ register OBJREC *op; return(0); sargerr: objerror(op, USER, "too few string arguments"); + return 0; /* pro forma return */ } -void -preload_objs() /* preload object data structures */ +extern void +preload_objs(void) /* preload object data structures */ { register OBJECT on; /* note that nobjects may change during loop */
