root/radiance/ray/src/rt/preload.c
Revision 2.18 - (view) (download) (annotate) - [selected]
Wed Aug 21 20:42:20 2024 UTC (9 months, 1 week ago) by greg
Changes since 2.17: +27 -1 lines
Diff to previous 2.17
refactor: moved memory sharing routines to preload.c with common call interface
Thu Apr 4 18:51:18 2024 UTC (13 months, 4 weeks ago) by greg
Changes since 2.16: +23 -1 lines
Diff to previous 2.16 , to selected 2.18
perf: Added missing data preload calls for multi-processing with spectra
Tue Jun 26 14:42:18 2018 UTC (6 years, 11 months ago) by greg
CVS Tags: rad5R2, rad5R3, rad5R4
Diff to previous 2.15 , to selected 2.18
Decided to go with "aBSDF" for "aperture BSDF" rather than "sBSDF"
Mon Jun 25 20:49:10 2018 UTC (6 years, 11 months ago) by greg
Changes since 2.14: +8 -1 lines
Diff to previous 2.14 , to selected 2.18
Fri Jul 14 23:19:32 2017 UTC (7 years, 10 months ago) by greg
Diff to previous 2.13 , to selected 2.18
Improved consistency of BSDF loading
Fri Nov 8 17:11:42 2013 UTC (11 years, 6 months ago) by greg
Changes since 2.12: +5 -5 lines
Diff to previous 2.12 , to selected 2.18
Minor changes not affecting operation
Tue Aug 16 18:09:53 2011 UTC (13 years, 9 months ago) by greg
Changes since 2.11: +1 -2 lines
Diff to previous 2.11 , to selected 2.18
Minor fixes
Fri Feb 18 02:41:55 2011 UTC (14 years, 3 months ago) by greg
Changes since 2.10: +2 -6 lines
Diff to previous 2.10 , to selected 2.18
Minor fixes and adjustments
Fri Feb 18 00:40:25 2011 UTC (14 years, 3 months ago) by greg
Changes since 2.9: +14 -6 lines
Diff to previous 2.9 , to selected 2.18
Thu Sep 15 18:06:23 2005 UTC (19 years, 8 months ago) by greg
Changes since 2.8: +5 -1 lines
Diff to previous 2.8 , to selected 2.18
Tue Mar 30 16:13:01 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 2.7: +10 -6 lines
Diff to previous 2.7 , to selected 2.18
Tue Feb 25 02:47:23 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 2.6 , to selected 2.18
Sat Feb 22 02:07:29 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.5: +121 -9 lines
Diff to previous 2.5 , to selected 2.18
Wed Jul 3 17:31:02 1996 UTC (28 years, 11 months ago) by greg
Changes since 2.4: +29 -2 lines
Diff to previous 2.4 , to selected 2.18
Mon Jan 25 15:15:41 1993 UTC (32 years, 4 months ago) by greg
Changes since 2.3: +0 -13 lines
Diff to previous 2.3 , to selected 2.18
modified OBJREC and RAY structures to avoid redundant intersection
testing using sets instead of flags
Thu Jan 21 17:01:26 1993 UTC (32 years, 4 months ago) by greg
Changes since 2.2: +14 -1 lines
Diff to previous 2.2 , to selected 2.18
added code to reset ray counters and clock on persistent restart
Thu Jan 21 09:20:47 1993 UTC (32 years, 4 months ago) by greg
Diff to previous 2.1 , to selected 2.18
*** empty log message ***
Wed Jan 20 15:19:17 1993 UTC (32 years, 4 months ago) by greg
Diff to selected 2.18
