root/radiance/ray/src/rt/preload.c
Revision: 2.16
Committed: Tue Jun 26 14:42:18 2018 UTC (6 years, 10 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3
Decided to go with "aBSDF" for "aperture BSDF" rather than "sBSDF"
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.16 static const char RCSid[] = "$Id: preload.c,v 2.15 2018/06/25 20:49:10 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Preload associated object structures to maximize memory sharing.
6 greg 2.6 *
7     * External symbols declared in ray.h
8     */
9
10 greg 2.7 #include "copyright.h"
11 greg 2.1
12 greg 2.10 #include "ray.h"
13 greg 2.1 #include "otypes.h"
14     #include "face.h"
15     #include "cone.h"
16 greg 2.2 #include "instance.h"
17 greg 2.9 #include "mesh.h"
18 greg 2.5 #include "data.h"
19 schorsch 2.8 #include "func.h"
20 greg 2.10 #include "bsdf.h"
21 greg 2.1
22
23 greg 2.6 /* KEEP THIS ROUTINE CONSISTENT WITH THE DIFFERENT OBJECT FUNCTIONS! */
24
25
26 greg 2.13 int
27 schorsch 2.8 load_os( /* load associated data for object */
28 greg 2.13 OBJREC *op
29 schorsch 2.8 )
30 greg 2.1 {
31 greg 2.14 DATARRAY *dp;
32     SDData *sd;
33
34     SDretainSet = SDretainAll;
35 greg 2.6
36 greg 2.1 switch (op->otype) {
37     case OBJ_FACE: /* polygon */
38     getface(op);
39     return(1);
40     case OBJ_CONE: /* cone */
41     case OBJ_RING: /* disk */
42     case OBJ_CYLINDER: /* cylinder */
43     case OBJ_CUP: /* inverted cone */
44     case OBJ_TUBE: /* inverted cylinder */
45     getcone(op, 1);
46     return(1);
47     case OBJ_INSTANCE: /* octree instance */
48     getinstance(op, IO_ALL);
49     return(1);
50 greg 2.9 case OBJ_MESH: /* mesh instance */
51     getmeshinst(op, IO_ALL);
52     return(1);
53 greg 2.5 case PAT_CPICT: /* color picture */
54     if (op->oargs.nsargs < 4)
55     goto sargerr;
56     getpict(op->oargs.sarg[3]);
57 greg 2.6 getfunc(op, 4, 0x3<<5, 0);
58 greg 2.5 return(1);
59     case PAT_CDATA: /* color data */
60 greg 2.6 dp = getdata(op->oargs.sarg[3]);
61     getdata(op->oargs.sarg[4]);
62     getdata(op->oargs.sarg[5]);
63     getfunc(op, 6, ((1<<dp->nd)-1)<<7, 0);
64     return(1);
65     case PAT_BDATA: /* brightness data */
66     if (op->oargs.nsargs < 2)
67     goto sargerr;
68     dp = getdata(op->oargs.sarg[1]);
69     getfunc(op, 2, ((1<<dp->nd)-1)<<3, 0);
70     return(1);
71     case PAT_BFUNC: /* brightness function */
72     getfunc(op, 1, 0x1, 0);
73     return(1);
74     case PAT_CFUNC: /* color function */
75     getfunc(op, 3, 0x7, 0);
76     return(1);
77 greg 2.5 case TEX_DATA: /* texture data */
78     if (op->oargs.nsargs < 6)
79     goto sargerr;
80 greg 2.6 dp = getdata(op->oargs.sarg[3]);
81 greg 2.5 getdata(op->oargs.sarg[4]);
82     getdata(op->oargs.sarg[5]);
83 greg 2.6 getfunc(op, 6, ((1<<dp->nd)-1)<<7, 1);
84     return(1);
85     case TEX_FUNC: /* texture function */
86     getfunc(op, 3, 0x7, 1);
87     return(1);
88     case MIX_DATA: /* mixture data */
89     dp = getdata(op->oargs.sarg[3]);
90     getfunc(op, 4, ((1<<dp->nd)-1)<<5, 0);
91     return(1);
92     case MIX_PICT: /* mixture picture */
93     getpict(op->oargs.sarg[3]);
94     getfunc(op, 4, 0x3<<5, 0);
95     return(1);
96     case MIX_FUNC: /* mixture function */
97     getfunc(op, 3, 0x4, 0);
98     return(1);
99     case MAT_PLASTIC2: /* anisotropic plastic */
100     case MAT_METAL2: /* anisotropic metal */
101     getfunc(op, 3, 0x7, 1);
102     return(1);
103     case MAT_BRTDF: /* BRDTfunc material */
104     getfunc(op, 9, 0x3f, 0);
105 greg 2.5 return(1);
106 greg 2.10 case MAT_BSDF: /* BSDF material */
107     if (op->oargs.nsargs < 6)
108     goto sargerr;
109     getfunc(op, 5, 0x1d, 1);
110 greg 2.14 sd = loadBSDF(op->oargs.sarg[1]);
111     if (sd != NULL) SDfreeCache(sd);
112 greg 2.10 return(1);
113 greg 2.16 case MAT_ABSDF: /* aBSDF material */
114 greg 2.15 if (op->oargs.nsargs < 5)
115     goto sargerr;
116     getfunc(op, 4, 0xe, 1);
117     sd = loadBSDF(op->oargs.sarg[0]);
118     if (sd != NULL) SDfreeCache(sd);
119     return(1);
120 greg 2.5 case MAT_PDATA: /* plastic BRDF data */
121     case MAT_MDATA: /* metal BRDF data */
122     case MAT_TDATA: /* trans BRDF data */
123     if (op->oargs.nsargs < 2)
124     goto sargerr;
125     getdata(op->oargs.sarg[1]);
126 greg 2.6 getfunc(op, 2, 0, 0);
127     return(1);
128     case MAT_PFUNC: /* plastic BRDF func */
129     case MAT_MFUNC: /* metal BRDF func */
130     case MAT_TFUNC: /* trans BRDF func */
131     getfunc(op, 1, 0, 0);
132     return(1);
133     case MAT_DIRECT1: /* prism1 material */
134     getfunc(op, 4, 0xf, 1);
135     return(1);
136     case MAT_DIRECT2: /* prism2 material */
137     getfunc(op, 8, 0xff, 1);
138 greg 2.5 return(1);
139 greg 2.1 }
140 greg 2.6 /* nothing to load for the remaining types */
141 greg 2.2 return(0);
142 greg 2.5 sargerr:
143     objerror(op, USER, "too few string arguments");
144 schorsch 2.8 return 0; /* pro forma return */
145 greg 2.1 }
146
147
148 greg 2.13 void
149 schorsch 2.8 preload_objs(void) /* preload object data structures */
150 greg 2.1 {
151 greg 2.13 OBJECT on;
152 greg 2.3 /* note that nobjects may change during loop */
153 greg 2.1 for (on = 0; on < nobjects; on++)
154     load_os(objptr(on));
155 greg 2.3 }
