root/radiance/ray/src/rt/preload.c
Revision: 2.14
Committed: Fri Jul 14 23:19:32 2017 UTC (7 years, 10 months ago) by greg
Improved consistency of BSDF loading
2 static const char RCSid[] = "$Id: preload.c,v 2.13 2013/11/08 17:11:42 greg Exp $";
5 * Preload associated object structures to maximize memory sharing.
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 #include "ray.h"
13 #include "otypes.h"
14 #include "face.h"
15 #include "cone.h"
16 #include "instance.h"
17 #include "mesh.h"
18 #include "data.h"
19 #include "func.h"
20 #include "bsdf.h"
21
22
23 /* KEEP THIS ROUTINE CONSISTENT WITH THE DIFFERENT OBJECT FUNCTIONS! */
24
25
26 int
27 load_os( /* load associated data for object */
28 OBJREC *op
29 )
30 {
31 DATARRAY *dp;
32 SDData *sd;
33
34 SDretainSet = SDretainAll;
35
36 switch (op->otype) {
37 case OBJ_FACE: /* polygon */
38 getface(op);
39 return(1);
40 case OBJ_CONE: /* cone */
41 case OBJ_RING: /* disk */
42 case OBJ_CYLINDER: /* cylinder */
43 case OBJ_CUP: /* inverted cone */
44 case OBJ_TUBE: /* inverted cylinder */
45 getcone(op, 1);
46 return(1);
47 case OBJ_INSTANCE: /* octree instance */
48 getinstance(op, IO_ALL);
49 return(1);
50 case OBJ_MESH: /* mesh instance */
51 getmeshinst(op, IO_ALL);
52 return(1);
53 case PAT_CPICT: /* color picture */
54 if (op->oargs.nsargs < 4)
55 goto sargerr;
56 getpict(op->oargs.sarg[3]);
57 getfunc(op, 4, 0x3<<5, 0);
58 return(1);
59 case PAT_CDATA: /* color data */
60 dp = getdata(op->oargs.sarg[3]);
61 getdata(op->oargs.sarg[4]);
62 getdata(op->oargs.sarg[5]);
63 getfunc(op, 6, ((1<<dp->nd)-1)<<7, 0);
64 return(1);
65 case PAT_BDATA: /* brightness data */
66 if (op->oargs.nsargs < 2)
67 goto sargerr;
68 dp = getdata(op->oargs.sarg[1]);
69 getfunc(op, 2, ((1<<dp->nd)-1)<<3, 0);
70 return(1);
71 case PAT_BFUNC: /* brightness function */
72 getfunc(op, 1, 0x1, 0);
73 return(1);
74 case PAT_CFUNC: /* color function */
75 getfunc(op, 3, 0x7, 0);
76 return(1);
77 case TEX_DATA: /* texture data */
78 if (op->oargs.nsargs < 6)
79 goto sargerr;
80 dp = getdata(op->oargs.sarg[3]);
81 getdata(op->oargs.sarg[4]);
82 getdata(op->oargs.sarg[5]);
83 getfunc(op, 6, ((1<<dp->nd)-1)<<7, 1);
84 return(1);
85 case TEX_FUNC: /* texture function */
86 getfunc(op, 3, 0x7, 1);
87 return(1);
88 case MIX_DATA: /* mixture data */
89 dp = getdata(op->oargs.sarg[3]);
90 getfunc(op, 4, ((1<<dp->nd)-1)<<5, 0);
91 return(1);
92 case MIX_PICT: /* mixture picture */
93 getpict(op->oargs.sarg[3]);
94 getfunc(op, 4, 0x3<<5, 0);
95 return(1);
96 case MIX_FUNC: /* mixture function */
97 getfunc(op, 3, 0x4, 0);
98 return(1);
99 case MAT_PLASTIC2: /* anisotropic plastic */
100 case MAT_METAL2: /* anisotropic metal */
101 getfunc(op, 3, 0x7, 1);
102 return(1);
103 case MAT_BRTDF: /* BRDTfunc material */
104 getfunc(op, 9, 0x3f, 0);
105 return(1);
106 case MAT_BSDF: /* BSDF material */
107 if (op->oargs.nsargs < 6)
108 goto sargerr;
109 getfunc(op, 5, 0x1d, 1);
110 sd = loadBSDF(op->oargs.sarg[1]);
111 if (sd != NULL) SDfreeCache(sd);
112 return(1);
113 case MAT_PDATA: /* plastic BRDF data */
114 case MAT_MDATA: /* metal BRDF data */
115 case MAT_TDATA: /* trans BRDF data */
116 if (op->oargs.nsargs < 2)
117 goto sargerr;
118 getdata(op->oargs.sarg[1]);
119 getfunc(op, 2, 0, 0);
120 return(1);
121 case MAT_PFUNC: /* plastic BRDF func */
122 case MAT_MFUNC: /* metal BRDF func */
123 case MAT_TFUNC: /* trans BRDF func */
124 getfunc(op, 1, 0, 0);
125 return(1);
126 case MAT_DIRECT1: /* prism1 material */
127 getfunc(op, 4, 0xf, 1);
128 return(1);
129 case MAT_DIRECT2: /* prism2 material */
130 getfunc(op, 8, 0xff, 1);
131 return(1);
132 }
133 /* nothing to load for the remaining types */
134 return(0);
135 sargerr:
136 objerror(op, USER, "too few string arguments");
137 return 0; /* pro forma return */
138 }
139
140
141 void
142 preload_objs(void) /* preload object data structures */
143 {
144 OBJECT on;
145 /* note that nobjects may change during loop */
146 for (on = 0; on < nobjects; on++)
147 load_os(objptr(on));
148 }
