root/radiance/ray/src/rt/preload.c
Revision: 2.10
Committed: Fri Feb 18 00:40:25 2011 UTC (13 years, 3 months ago) by greg
Changes since 2.9: +14 -6 lines
2 static const char RCSid[] = "$Id: preload.c,v 2.9 2005/09/15 18:06:23 greg Exp $";
5 * Preload associated object structures to maximize memory sharing.
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 #include "ray.h"
13 #include "otypes.h"
14 #include "face.h"
15 #include "cone.h"
16 #include "instance.h"
17 #include "mesh.h"
18 #include "data.h"
19 #include "func.h"
20 #include "bsdf.h"
21 #include "paths.h"
22
23
24 /* KEEP THIS ROUTINE CONSISTENT WITH THE DIFFERENT OBJECT FUNCTIONS! */
25
26
27 extern int
28 load_os( /* load associated data for object */
29 register OBJREC *op
30 )
31 {
32 DATARRAY *dp;
33 SDData *sd;
34
35 switch (op->otype) {
36 case OBJ_FACE: /* polygon */
37 getface(op);
38 return(1);
39 case OBJ_CONE: /* cone */
40 case OBJ_RING: /* disk */
41 case OBJ_CYLINDER: /* cylinder */
42 case OBJ_CUP: /* inverted cone */
43 case OBJ_TUBE: /* inverted cylinder */
44 getcone(op, 1);
45 return(1);
46 case OBJ_INSTANCE: /* octree instance */
47 getinstance(op, IO_ALL);
48 return(1);
49 case OBJ_MESH: /* mesh instance */
50 getmeshinst(op, IO_ALL);
51 return(1);
52 case PAT_CPICT: /* color picture */
53 if (op->oargs.nsargs < 4)
54 goto sargerr;
55 getpict(op->oargs.sarg[3]);
56 getfunc(op, 4, 0x3<<5, 0);
57 return(1);
58 case PAT_CDATA: /* color data */
59 dp = getdata(op->oargs.sarg[3]);
60 getdata(op->oargs.sarg[4]);
61 getdata(op->oargs.sarg[5]);
62 getfunc(op, 6, ((1<<dp->nd)-1)<<7, 0);
63 return(1);
64 case PAT_BDATA: /* brightness data */
65 if (op->oargs.nsargs < 2)
66 goto sargerr;
67 dp = getdata(op->oargs.sarg[1]);
68 getfunc(op, 2, ((1<<dp->nd)-1)<<3, 0);
69 return(1);
70 case PAT_BFUNC: /* brightness function */
71 getfunc(op, 1, 0x1, 0);
72 return(1);
73 case PAT_CFUNC: /* color function */
74 getfunc(op, 3, 0x7, 0);
75 return(1);
76 case TEX_DATA: /* texture data */
77 if (op->oargs.nsargs < 6)
78 goto sargerr;
79 dp = getdata(op->oargs.sarg[3]);
80 getdata(op->oargs.sarg[4]);
81 getdata(op->oargs.sarg[5]);
82 getfunc(op, 6, ((1<<dp->nd)-1)<<7, 1);
83 return(1);
84 case TEX_FUNC: /* texture function */
85 getfunc(op, 3, 0x7, 1);
86 return(1);
87 case MIX_DATA: /* mixture data */
88 dp = getdata(op->oargs.sarg[3]);
89 getfunc(op, 4, ((1<<dp->nd)-1)<<5, 0);
90 return(1);
91 case MIX_PICT: /* mixture picture */
92 getpict(op->oargs.sarg[3]);
93 getfunc(op, 4, 0x3<<5, 0);
94 return(1);
95 case MIX_FUNC: /* mixture function */
96 getfunc(op, 3, 0x4, 0);
97 return(1);
98 case MAT_PLASTIC2: /* anisotropic plastic */
99 case MAT_METAL2: /* anisotropic metal */
100 getfunc(op, 3, 0x7, 1);
101 return(1);
102 case MAT_BRTDF: /* BRDTfunc material */
103 getfunc(op, 9, 0x3f, 0);
104 return(1);
105 case MAT_BSDF: /* BSDF material */
106 if (op->oargs.nsargs < 6)
107 goto sargerr;
108 getfunc(op, 5, 0x1d, 1);
109 sd = SDgetCache(op->oargs.sarg[1]);
110 if (sd != NULL && !SDisLoaded(sd))
111 SDloadFile(sd, getpath(op->oargs.sarg[1],
112 getrlibpath(), R_OK));
113 return(1);
114 case MAT_PDATA: /* plastic BRDF data */
115 case MAT_MDATA: /* metal BRDF data */
116 case MAT_TDATA: /* trans BRDF data */
117 if (op->oargs.nsargs < 2)
118 goto sargerr;
119 getdata(op->oargs.sarg[1]);
120 getfunc(op, 2, 0, 0);
121 return(1);
122 case MAT_PFUNC: /* plastic BRDF func */
123 case MAT_MFUNC: /* metal BRDF func */
124 case MAT_TFUNC: /* trans BRDF func */
125 getfunc(op, 1, 0, 0);
126 return(1);
127 case MAT_DIRECT1: /* prism1 material */
128 getfunc(op, 4, 0xf, 1);
129 return(1);
130 case MAT_DIRECT2: /* prism2 material */
131 getfunc(op, 8, 0xff, 1);
132 return(1);
133 }
134 /* nothing to load for the remaining types */
135 return(0);
136 sargerr:
137 objerror(op, USER, "too few string arguments");
138 return 0; /* pro forma return */
139 }
140
141
142 extern void
143 preload_objs(void) /* preload object data structures */
144 {
145 register OBJECT on;
146 /* note that nobjects may change during loop */
147 for (on = 0; on < nobjects; on++)
148 load_os(objptr(on));
149 }
