root/radiance/ray/src/rt/preload.c
Revision: 2.8
Committed: Tue Mar 30 16:13:01 2004 UTC (21 years, 2 months ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1
Changes since 2.7: +10 -6 lines
2 static const char RCSid[] = "$Id: preload.c,v 2.7 2003/02/25 02:47:23 greg Exp $";
5 * Preload associated object structures to maximize memory sharing.
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 #include "standard.h"
13 #include "octree.h"
14 #include "object.h"
15 #include "otypes.h"
16 #include "face.h"
17 #include "cone.h"
18 #include "instance.h"
19 #include "color.h"
20 #include "data.h"
21 #include "func.h"
22 #include "ray.h"
23
24
25 /* KEEP THIS ROUTINE CONSISTENT WITH THE DIFFERENT OBJECT FUNCTIONS! */
26
27
28 extern int
29 load_os( /* load associated data for object */
30 register OBJREC *op
31 )
32 {
33 DATARRAY *dp;
34
35 switch (op->otype) {
36 case OBJ_FACE: /* polygon */
37 getface(op);
38 return(1);
39 case OBJ_CONE: /* cone */
40 case OBJ_RING: /* disk */
41 case OBJ_CYLINDER: /* cylinder */
42 case OBJ_CUP: /* inverted cone */
43 case OBJ_TUBE: /* inverted cylinder */
44 getcone(op, 1);
45 return(1);
46 case OBJ_INSTANCE: /* octree instance */
47 getinstance(op, IO_ALL);
48 return(1);
49 case PAT_CPICT: /* color picture */
50 if (op->oargs.nsargs < 4)
51 goto sargerr;
52 getpict(op->oargs.sarg[3]);
53 getfunc(op, 4, 0x3<<5, 0);
54 return(1);
55 case PAT_CDATA: /* color data */
56 dp = getdata(op->oargs.sarg[3]);
57 getdata(op->oargs.sarg[4]);
58 getdata(op->oargs.sarg[5]);
59 getfunc(op, 6, ((1<<dp->nd)-1)<<7, 0);
60 return(1);
61 case PAT_BDATA: /* brightness data */
62 if (op->oargs.nsargs < 2)
63 goto sargerr;
64 dp = getdata(op->oargs.sarg[1]);
65 getfunc(op, 2, ((1<<dp->nd)-1)<<3, 0);
66 return(1);
67 case PAT_BFUNC: /* brightness function */
68 getfunc(op, 1, 0x1, 0);
69 return(1);
70 case PAT_CFUNC: /* color function */
71 getfunc(op, 3, 0x7, 0);
72 return(1);
73 case TEX_DATA: /* texture data */
74 if (op->oargs.nsargs < 6)
75 goto sargerr;
76 dp = getdata(op->oargs.sarg[3]);
77 getdata(op->oargs.sarg[4]);
78 getdata(op->oargs.sarg[5]);
79 getfunc(op, 6, ((1<<dp->nd)-1)<<7, 1);
80 return(1);
81 case TEX_FUNC: /* texture function */
82 getfunc(op, 3, 0x7, 1);
83 return(1);
84 case MIX_DATA: /* mixture data */
85 dp = getdata(op->oargs.sarg[3]);
86 getfunc(op, 4, ((1<<dp->nd)-1)<<5, 0);
87 return(1);
88 case MIX_PICT: /* mixture picture */
89 getpict(op->oargs.sarg[3]);
90 getfunc(op, 4, 0x3<<5, 0);
91 return(1);
92 case MIX_FUNC: /* mixture function */
93 getfunc(op, 3, 0x4, 0);
94 return(1);
95 case MAT_PLASTIC2: /* anisotropic plastic */
96 case MAT_METAL2: /* anisotropic metal */
97 getfunc(op, 3, 0x7, 1);
98 return(1);
99 case MAT_BRTDF: /* BRDTfunc material */
100 getfunc(op, 9, 0x3f, 0);
101 return(1);
102 case MAT_PDATA: /* plastic BRDF data */
103 case MAT_MDATA: /* metal BRDF data */
104 case MAT_TDATA: /* trans BRDF data */
105 if (op->oargs.nsargs < 2)
106 goto sargerr;
107 getdata(op->oargs.sarg[1]);
108 getfunc(op, 2, 0, 0);
109 return(1);
110 case MAT_PFUNC: /* plastic BRDF func */
111 case MAT_MFUNC: /* metal BRDF func */
112 case MAT_TFUNC: /* trans BRDF func */
113 getfunc(op, 1, 0, 0);
114 return(1);
115 case MAT_DIRECT1: /* prism1 material */
116 getfunc(op, 4, 0xf, 1);
117 return(1);
118 case MAT_DIRECT2: /* prism2 material */
119 getfunc(op, 8, 0xff, 1);
120 return(1);
121 }
122 /* nothing to load for the remaining types */
123 return(0);
124 sargerr:
125 objerror(op, USER, "too few string arguments");
126 return 0; /* pro forma return */
127 }
128
129
130 extern void
131 preload_objs(void) /* preload object data structures */
132 {
133 register OBJECT on;
134 /* note that nobjects may change during loop */
135 for (on = 0; on < nobjects; on++)
136 load_os(objptr(on));
137 }
