root/radiance/ray/src/rt/preload.c
Revision: 2.18
Committed: Wed Aug 21 20:42:20 2024 UTC (8 months, 1 week ago) by greg
Changes since 2.17: +27 -1 lines
Error occurred while calculating annotation data.
refactor: moved memory sharing routines to preload.c with common call interface
2 static const char RCSid[] = "$Id: preload.c,v 2.17 2024/04/04 18:51:18 greg Exp $";
5 * Preload associated object structures to maximize memory sharing.
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 #include "ray.h"
13 #include "otypes.h"
14 #include "face.h"
15 #include "cone.h"
16 #include "instance.h"
17 #include "mesh.h"
18 #include "data.h"
19 #include "func.h"
20 #include "bsdf.h"
21
22 char *shm_boundary = NULL; /* boundary of shared memory */
23
24
25 /* KEEP THIS ROUTINE CONSISTENT WITH THE DIFFERENT OBJECT FUNCTIONS! */
26
27
28 int
29 load_os( /* load associated data for object */
30 OBJREC *op
31 )
32 {
33 DATARRAY *dp;
34 SDData *sd;
35
36 SDretainSet = SDretainAll;
37
38 switch (op->otype) {
39 case OBJ_FACE: /* polygon */
40 getface(op);
41 return(1);
42 case OBJ_CONE: /* cone */
43 case OBJ_RING: /* disk */
44 case OBJ_CYLINDER: /* cylinder */
45 case OBJ_CUP: /* inverted cone */
46 case OBJ_TUBE: /* inverted cylinder */
47 getcone(op, 1);
48 return(1);
49 case OBJ_INSTANCE: /* octree instance */
50 getinstance(op, IO_ALL);
51 return(1);
52 case OBJ_MESH: /* mesh instance */
53 getmeshinst(op, IO_ALL);
54 return(1);
55 case PAT_CPICT: /* color picture */
56 if (op->oargs.nsargs < 4)
57 goto sargerr;
58 getpict(op->oargs.sarg[3]);
59 getfunc(op, 4, 0x3<<5, 0);
60 return(1);
61 case PAT_CDATA: /* color data */
62 if (op->oargs.nsargs < 4)
63 goto sargerr;
64 dp = getdata(op->oargs.sarg[3]);
65 getdata(op->oargs.sarg[4]);
66 getdata(op->oargs.sarg[5]);
67 getfunc(op, 6, ((1<<dp->nd)-1)<<7, 0);
68 return(1);
69 case PAT_BDATA: /* brightness data */
70 if (op->oargs.nsargs < 2)
71 goto sargerr;
72 dp = getdata(op->oargs.sarg[1]);
73 getfunc(op, 2, ((1<<dp->nd)-1)<<3, 0);
74 return(1);
75 case PAT_BFUNC: /* brightness function */
76 getfunc(op, 1, 0x1, 0);
77 return(1);
78 case PAT_CFUNC: /* color function */
79 getfunc(op, 3, 0x7, 0);
80 return(1);
81 case PAT_SPECFUNC: /* spectral function */
82 getfunc(op, 1, 0, 0);
83 return(1);
84 case PAT_SPECFILE: /* spectrum file */
85 if (op->oargs.nsargs < 1)
86 goto sargerr;
87 getdata(op->oargs.sarg[0]);
88 return(1);
89 case PAT_SPECDATA: /* spectral data file */
90 if (op->oargs.nsargs < 2)
91 goto sargerr;
92 dp = getdata(op->oargs.sarg[1]);
93 getfunc(op, 2, ((1<<(dp->nd-1)) - 1)<<3, 0);
94 return(1);
95 case PAT_SPECPICT: /* spectral picture */
96 if (op->oargs.nsargs < 2)
97 goto sargerr;
98 getspec(op->oargs.sarg[1]);
99 getfunc(op, 2, 0x3<<3, 0);
100 return(1);
101 case TEX_DATA: /* texture data */
102 if (op->oargs.nsargs < 6)
103 goto sargerr;
104 dp = getdata(op->oargs.sarg[3]);
105 getdata(op->oargs.sarg[4]);
106 getdata(op->oargs.sarg[5]);
107 getfunc(op, 6, ((1<<dp->nd)-1)<<7, 1);
108 return(1);
109 case TEX_FUNC: /* texture function */
110 getfunc(op, 3, 0x7, 1);
111 return(1);
112 case MIX_DATA: /* mixture data */
113 dp = getdata(op->oargs.sarg[3]);
114 getfunc(op, 4, ((1<<dp->nd)-1)<<5, 0);
115 return(1);
116 case MIX_PICT: /* mixture picture */
117 getpict(op->oargs.sarg[3]);
118 getfunc(op, 4, 0x3<<5, 0);
119 return(1);
120 case MIX_FUNC: /* mixture function */
121 getfunc(op, 3, 0x4, 0);
122 return(1);
123 case MAT_PLASTIC2: /* anisotropic plastic */
124 case MAT_METAL2: /* anisotropic metal */
125 getfunc(op, 3, 0x7, 1);
126 return(1);
127 case MAT_BRTDF: /* BRDTfunc material */
128 getfunc(op, 9, 0x3f, 0);
129 return(1);
130 case MAT_BSDF: /* BSDF material */
131 if (op->oargs.nsargs < 6)
132 goto sargerr;
133 getfunc(op, 5, 0x1d, 1);
134 sd = loadBSDF(op->oargs.sarg[1]);
135 if (sd != NULL) SDfreeCache(sd);
136 return(1);
137 case MAT_ABSDF: /* aBSDF material */
138 if (op->oargs.nsargs < 5)
139 goto sargerr;
140 getfunc(op, 4, 0xe, 1);
141 sd = loadBSDF(op->oargs.sarg[0]);
142 if (sd != NULL) SDfreeCache(sd);
143 return(1);
144 case MAT_PDATA: /* plastic BRDF data */
145 case MAT_MDATA: /* metal BRDF data */
146 case MAT_TDATA: /* trans BRDF data */
147 if (op->oargs.nsargs < 2)
148 goto sargerr;
149 getdata(op->oargs.sarg[1]);
150 getfunc(op, 2, 0, 0);
151 return(1);
152 case MAT_PFUNC: /* plastic BRDF func */
153 case MAT_MFUNC: /* metal BRDF func */
154 case MAT_TFUNC: /* trans BRDF func */
155 getfunc(op, 1, 0, 0);
156 return(1);
157 case MAT_DIRECT1: /* prism1 material */
158 getfunc(op, 4, 0xf, 1);
159 return(1);
160 case MAT_DIRECT2: /* prism2 material */
161 getfunc(op, 8, 0xff, 1);
162 return(1);
163 }
164 /* nothing to load for the remaining types */
165 return(0);
166 sargerr:
167 objerror(op, USER, "too few string arguments");
168 return 0; /* pro forma return */
169 }
170
171
172 void
173 preload_objs(void) /* preload object data structures */
174 {
175 OBJECT on;
176 /* note that nobjects may change during loop */
177 for (on = 0; on < nobjects; on++)
178 load_os(objptr(on));
179 }
180
181
182 void
183 cow_memshare(void) /* set up copy-on-write memory sharing */
184 {
185 if (shm_boundary != NULL)
186 return; /* assume we're good */
187
188 preload_objs(); /* preload auxiliary data */
189 /* set shared memory boundary */
190 shm_boundary = (char *)malloc(16);
191 strcpy(shm_boundary, "SHM_BOUNDARY");
192 }
193
194
195 void
196 cow_doneshare(void) /* clear memory sharing boundary */
197 {
198 if (shm_boundary == NULL)
199 return;
200 /* clear shared memory boundary */
201 free((void *)shm_boundary);
202 shm_boundary = NULL;
203 }
