root/radiance/ray/src/rt/preload.c
Revision: 2.17
Committed: Thu Apr 4 18:51:18 2024 UTC (8 weeks ago) by greg
Changes since 2.16: +23 -1 lines
perf: Added missing data preload calls for multi-processing with spectra
2 static const char RCSid[] = "$Id: preload.c,v 2.16 2018/06/26 14:42:18 greg Exp $";
5 * Preload associated object structures to maximize memory sharing.
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 #include "ray.h"
13 #include "otypes.h"
14 #include "face.h"
15 #include "cone.h"
16 #include "instance.h"
17 #include "mesh.h"
18 #include "data.h"
19 #include "func.h"
20 #include "bsdf.h"
21
22
23 /* KEEP THIS ROUTINE CONSISTENT WITH THE DIFFERENT OBJECT FUNCTIONS! */
24
25
26 int
27 load_os( /* load associated data for object */
28 OBJREC *op
29 )
30 {
31 DATARRAY *dp;
32 SDData *sd;
33
34 SDretainSet = SDretainAll;
35
36 switch (op->otype) {
37 case OBJ_FACE: /* polygon */
38 getface(op);
39 return(1);
40 case OBJ_CONE: /* cone */
41 case OBJ_RING: /* disk */
42 case OBJ_CYLINDER: /* cylinder */
43 case OBJ_CUP: /* inverted cone */
44 case OBJ_TUBE: /* inverted cylinder */
45 getcone(op, 1);
46 return(1);
47 case OBJ_INSTANCE: /* octree instance */
48 getinstance(op, IO_ALL);
49 return(1);
50 case OBJ_MESH: /* mesh instance */
51 getmeshinst(op, IO_ALL);
52 return(1);
53 case PAT_CPICT: /* color picture */
54 if (op->oargs.nsargs < 4)
55 goto sargerr;
56 getpict(op->oargs.sarg[3]);
57 getfunc(op, 4, 0x3<<5, 0);
58 return(1);
59 case PAT_CDATA: /* color data */
60 if (op->oargs.nsargs < 4)
61 goto sargerr;
62 dp = getdata(op->oargs.sarg[3]);
63 getdata(op->oargs.sarg[4]);
64 getdata(op->oargs.sarg[5]);
65 getfunc(op, 6, ((1<<dp->nd)-1)<<7, 0);
66 return(1);
67 case PAT_BDATA: /* brightness data */
68 if (op->oargs.nsargs < 2)
69 goto sargerr;
70 dp = getdata(op->oargs.sarg[1]);
71 getfunc(op, 2, ((1<<dp->nd)-1)<<3, 0);
72 return(1);
73 case PAT_BFUNC: /* brightness function */
74 getfunc(op, 1, 0x1, 0);
75 return(1);
76 case PAT_CFUNC: /* color function */
77 getfunc(op, 3, 0x7, 0);
78 return(1);
79 case PAT_SPECFUNC: /* spectral function */
80 getfunc(op, 1, 0, 0);
81 return(1);
82 case PAT_SPECFILE: /* spectrum file */
83 if (op->oargs.nsargs < 1)
84 goto sargerr;
85 getdata(op->oargs.sarg[0]);
86 return(1);
87 case PAT_SPECDATA: /* spectral data file */
88 if (op->oargs.nsargs < 2)
89 goto sargerr;
90 dp = getdata(op->oargs.sarg[1]);
91 getfunc(op, 2, ((1<<(dp->nd-1)) - 1)<<3, 0);
92 return(1);
93 case PAT_SPECPICT: /* spectral picture */
94 if (op->oargs.nsargs < 2)
95 goto sargerr;
96 getspec(op->oargs.sarg[1]);
97 getfunc(op, 2, 0x3<<3, 0);
98 return(1);
99 case TEX_DATA: /* texture data */
100 if (op->oargs.nsargs < 6)
101 goto sargerr;
102 dp = getdata(op->oargs.sarg[3]);
103 getdata(op->oargs.sarg[4]);
104 getdata(op->oargs.sarg[5]);
105 getfunc(op, 6, ((1<<dp->nd)-1)<<7, 1);
106 return(1);
107 case TEX_FUNC: /* texture function */
108 getfunc(op, 3, 0x7, 1);
109 return(1);
110 case MIX_DATA: /* mixture data */
111 dp = getdata(op->oargs.sarg[3]);
112 getfunc(op, 4, ((1<<dp->nd)-1)<<5, 0);
113 return(1);
114 case MIX_PICT: /* mixture picture */
115 getpict(op->oargs.sarg[3]);
116 getfunc(op, 4, 0x3<<5, 0);
117 return(1);
118 case MIX_FUNC: /* mixture function */
119 getfunc(op, 3, 0x4, 0);
120 return(1);
121 case MAT_PLASTIC2: /* anisotropic plastic */
122 case MAT_METAL2: /* anisotropic metal */
123 getfunc(op, 3, 0x7, 1);
124 return(1);
125 case MAT_BRTDF: /* BRDTfunc material */
126 getfunc(op, 9, 0x3f, 0);
127 return(1);
128 case MAT_BSDF: /* BSDF material */
129 if (op->oargs.nsargs < 6)
130 goto sargerr;
131 getfunc(op, 5, 0x1d, 1);
132 sd = loadBSDF(op->oargs.sarg[1]);
133 if (sd != NULL) SDfreeCache(sd);
134 return(1);
135 case MAT_ABSDF: /* aBSDF material */
136 if (op->oargs.nsargs < 5)
137 goto sargerr;
138 getfunc(op, 4, 0xe, 1);
139 sd = loadBSDF(op->oargs.sarg[0]);
140 if (sd != NULL) SDfreeCache(sd);
141 return(1);
142 case MAT_PDATA: /* plastic BRDF data */
143 case MAT_MDATA: /* metal BRDF data */
144 case MAT_TDATA: /* trans BRDF data */
145 if (op->oargs.nsargs < 2)
146 goto sargerr;
147 getdata(op->oargs.sarg[1]);
148 getfunc(op, 2, 0, 0);
149 return(1);
150 case MAT_PFUNC: /* plastic BRDF func */
151 case MAT_MFUNC: /* metal BRDF func */
152 case MAT_TFUNC: /* trans BRDF func */
153 getfunc(op, 1, 0, 0);
154 return(1);
155 case MAT_DIRECT1: /* prism1 material */
156 getfunc(op, 4, 0xf, 1);
157 return(1);
158 case MAT_DIRECT2: /* prism2 material */
159 getfunc(op, 8, 0xff, 1);
160 return(1);
161 }
162 /* nothing to load for the remaining types */
163 return(0);
164 sargerr:
165 objerror(op, USER, "too few string arguments");
166 return 0; /* pro forma return */
167 }
168
169
170 void
171 preload_objs(void) /* preload object data structures */
172 {
173 OBJECT on;
174 /* note that nobjects may change during loop */
175 for (on = 0; on < nobjects; on++)
176 load_os(objptr(on));
177 }
