root/radiance/ray/src/rt/preload.c
Revision: 2.9
Committed: Thu Sep 15 18:06:23 2005 UTC (19 years, 9 months ago) by greg
CVS Tags: rad4R0, rad3R8, rad3R9
Changes since 2.8: +5 -1 lines
2 static const char RCSid[] = "$Id: preload.c,v 2.8 2004/03/30 16:13:01 schorsch Exp $";
5 * Preload associated object structures to maximize memory sharing.
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 #include "standard.h"
13 #include "octree.h"
14 #include "object.h"
15 #include "otypes.h"
16 #include "face.h"
17 #include "cone.h"
18 #include "instance.h"
19 #include "mesh.h"
20 #include "color.h"
21 #include "data.h"
22 #include "func.h"
23 #include "ray.h"
24
25
26 /* KEEP THIS ROUTINE CONSISTENT WITH THE DIFFERENT OBJECT FUNCTIONS! */
27
28
29 extern int
30 load_os( /* load associated data for object */
31 register OBJREC *op
32 )
33 {
34 DATARRAY *dp;
35
36 switch (op->otype) {
37 case OBJ_FACE: /* polygon */
38 getface(op);
39 return(1);
40 case OBJ_CONE: /* cone */
41 case OBJ_RING: /* disk */
42 case OBJ_CYLINDER: /* cylinder */
43 case OBJ_CUP: /* inverted cone */
44 case OBJ_TUBE: /* inverted cylinder */
45 getcone(op, 1);
46 return(1);
47 case OBJ_INSTANCE: /* octree instance */
48 getinstance(op, IO_ALL);
49 return(1);
50 case OBJ_MESH: /* mesh instance */
51 getmeshinst(op, IO_ALL);
52 return(1);
53 case PAT_CPICT: /* color picture */
54 if (op->oargs.nsargs < 4)
55 goto sargerr;
56 getpict(op->oargs.sarg[3]);
57 getfunc(op, 4, 0x3<<5, 0);
58 return(1);
59 case PAT_CDATA: /* color data */
60 dp = getdata(op->oargs.sarg[3]);
61 getdata(op->oargs.sarg[4]);
62 getdata(op->oargs.sarg[5]);
63 getfunc(op, 6, ((1<<dp->nd)-1)<<7, 0);
64 return(1);
65 case PAT_BDATA: /* brightness data */
66 if (op->oargs.nsargs < 2)
67 goto sargerr;
68 dp = getdata(op->oargs.sarg[1]);
69 getfunc(op, 2, ((1<<dp->nd)-1)<<3, 0);
70 return(1);
71 case PAT_BFUNC: /* brightness function */
72 getfunc(op, 1, 0x1, 0);
73 return(1);
74 case PAT_CFUNC: /* color function */
75 getfunc(op, 3, 0x7, 0);
76 return(1);
77 case TEX_DATA: /* texture data */
78 if (op->oargs.nsargs < 6)
79 goto sargerr;
80 dp = getdata(op->oargs.sarg[3]);
81 getdata(op->oargs.sarg[4]);
82 getdata(op->oargs.sarg[5]);
83 getfunc(op, 6, ((1<<dp->nd)-1)<<7, 1);
84 return(1);
85 case TEX_FUNC: /* texture function */
86 getfunc(op, 3, 0x7, 1);
87 return(1);
88 case MIX_DATA: /* mixture data */
89 dp = getdata(op->oargs.sarg[3]);
90 getfunc(op, 4, ((1<<dp->nd)-1)<<5, 0);
91 return(1);
92 case MIX_PICT: /* mixture picture */
93 getpict(op->oargs.sarg[3]);
94 getfunc(op, 4, 0x3<<5, 0);
95 return(1);
96 case MIX_FUNC: /* mixture function */
97 getfunc(op, 3, 0x4, 0);
98 return(1);
99 case MAT_PLASTIC2: /* anisotropic plastic */
100 case MAT_METAL2: /* anisotropic metal */
101 getfunc(op, 3, 0x7, 1);
102 return(1);
103 case MAT_BRTDF: /* BRDTfunc material */
104 getfunc(op, 9, 0x3f, 0);
105 return(1);
106 case MAT_PDATA: /* plastic BRDF data */
107 case MAT_MDATA: /* metal BRDF data */
108 case MAT_TDATA: /* trans BRDF data */
109 if (op->oargs.nsargs < 2)
110 goto sargerr;
111 getdata(op->oargs.sarg[1]);
112 getfunc(op, 2, 0, 0);
113 return(1);
114 case MAT_PFUNC: /* plastic BRDF func */
115 case MAT_MFUNC: /* metal BRDF func */
116 case MAT_TFUNC: /* trans BRDF func */
117 getfunc(op, 1, 0, 0);
118 return(1);
119 case MAT_DIRECT1: /* prism1 material */
120 getfunc(op, 4, 0xf, 1);
121 return(1);
122 case MAT_DIRECT2: /* prism2 material */
123 getfunc(op, 8, 0xff, 1);
124 return(1);
125 }
126 /* nothing to load for the remaining types */
127 return(0);
128 sargerr:
129 objerror(op, USER, "too few string arguments");
130 return 0; /* pro forma return */
131 }
132
133
134 extern void
135 preload_objs(void) /* preload object data structures */
136 {
137 register OBJECT on;
138 /* note that nobjects may change during loop */
139 for (on = 0; on < nobjects; on++)
140 load_os(objptr(on));
141 }
