root/radiance/ray/src/rt/preload.c
Revision: 2.6
Committed: Sat Feb 22 02:07:29 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.5: +121 -9 lines
5 * Preload associated object structures to maximize memory sharing.
6 *
7 * External symbols declared in ray.h
8 */
9
10 /* ====================================================================
11 * The Radiance Software License, Version 1.0
12 *
13 * Copyright (c) 1990 - 2002 The Regents of the University of California,
14 * through Lawrence Berkeley National Laboratory. All rights reserved.
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 *
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 *
23 * 2. Redistributions in binary form must reproduce the above copyright
24 * notice, this list of conditions and the following disclaimer in
25 * the documentation and/or other materials provided with the
26 * distribution.
27 *
28 * 3. The end-user documentation included with the redistribution,
29 * if any, must include the following acknowledgment:
30 * "This product includes Radiance software
31 * (http://radsite.lbl.gov/)
32 * developed by the Lawrence Berkeley National Laboratory
33 * (http://www.lbl.gov/)."
34 * Alternately, this acknowledgment may appear in the software itself,
35 * if and wherever such third-party acknowledgments normally appear.
36 *
37 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
38 * and "The Regents of the University of California" must
39 * not be used to endorse or promote products derived from this
40 * software without prior written permission. For written
41 * permission, please contact [email protected].
42 *
43 * 5. Products derived from this software may not be called "Radiance",
44 * nor may "Radiance" appear in their name, without prior written
45 * permission of Lawrence Berkeley National Laboratory.
46 *
47 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
48 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
49 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
50 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
51 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
52 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
53 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
54 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
55 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
56 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
57 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
58 * SUCH DAMAGE.
59 * ====================================================================
60 *
61 * This software consists of voluntary contributions made by many
62 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
63 * information on Lawrence Berkeley National Laboratory, please see
64 * <http://www.lbl.gov/>.
65 */
66
67 #include "standard.h"
68 #include "octree.h"
69 #include "object.h"
70 #include "otypes.h"
71 #include "face.h"
72 #include "cone.h"
73 #include "instance.h"
74 #include "color.h"
75 #include "data.h"
76
77
78 /* KEEP THIS ROUTINE CONSISTENT WITH THE DIFFERENT OBJECT FUNCTIONS! */
79
80
81 int
82 load_os(op) /* load associated data for object */
83 register OBJREC *op;
84 {
85 DATARRAY *dp;
86
87 switch (op->otype) {
88 case OBJ_FACE: /* polygon */
89 getface(op);
90 return(1);
91 case OBJ_CONE: /* cone */
92 case OBJ_RING: /* disk */
93 case OBJ_CYLINDER: /* cylinder */
94 case OBJ_CUP: /* inverted cone */
95 case OBJ_TUBE: /* inverted cylinder */
96 getcone(op, 1);
97 return(1);
98 case OBJ_INSTANCE: /* octree instance */
99 getinstance(op, IO_ALL);
100 return(1);
101 case PAT_CPICT: /* color picture */
102 if (op->oargs.nsargs < 4)
103 goto sargerr;
104 getpict(op->oargs.sarg[3]);
105 getfunc(op, 4, 0x3<<5, 0);
106 return(1);
107 case PAT_CDATA: /* color data */
108 dp = getdata(op->oargs.sarg[3]);
109 getdata(op->oargs.sarg[4]);
110 getdata(op->oargs.sarg[5]);
111 getfunc(op, 6, ((1<<dp->nd)-1)<<7, 0);
112 return(1);
113 case PAT_BDATA: /* brightness data */
114 if (op->oargs.nsargs < 2)
115 goto sargerr;
116 dp = getdata(op->oargs.sarg[1]);
117 getfunc(op, 2, ((1<<dp->nd)-1)<<3, 0);
118 return(1);
119 case PAT_BFUNC: /* brightness function */
120 getfunc(op, 1, 0x1, 0);
121 return(1);
122 case PAT_CFUNC: /* color function */
123 getfunc(op, 3, 0x7, 0);
124 return(1);
125 case TEX_DATA: /* texture data */
126 if (op->oargs.nsargs < 6)
127 goto sargerr;
128 dp = getdata(op->oargs.sarg[3]);
129 getdata(op->oargs.sarg[4]);
130 getdata(op->oargs.sarg[5]);
131 getfunc(op, 6, ((1<<dp->nd)-1)<<7, 1);
132 return(1);
133 case TEX_FUNC: /* texture function */
134 getfunc(op, 3, 0x7, 1);
135 return(1);
136 case MIX_DATA: /* mixture data */
137 dp = getdata(op->oargs.sarg[3]);
138 getfunc(op, 4, ((1<<dp->nd)-1)<<5, 0);
139 return(1);
140 case MIX_PICT: /* mixture picture */
141 getpict(op->oargs.sarg[3]);
142 getfunc(op, 4, 0x3<<5, 0);
143 return(1);
144 case MIX_FUNC: /* mixture function */
145 getfunc(op, 3, 0x4, 0);
146 return(1);
147 case MAT_PLASTIC2: /* anisotropic plastic */
148 case MAT_METAL2: /* anisotropic metal */
149 getfunc(op, 3, 0x7, 1);
150 return(1);
151 case MAT_BRTDF: /* BRDTfunc material */
152 getfunc(op, 9, 0x3f, 0);
153 return(1);
154 case MAT_PDATA: /* plastic BRDF data */
155 case MAT_MDATA: /* metal BRDF data */
156 case MAT_TDATA: /* trans BRDF data */
157 if (op->oargs.nsargs < 2)
158 goto sargerr;
159 getdata(op->oargs.sarg[1]);
160 getfunc(op, 2, 0, 0);
161 return(1);
162 case MAT_PFUNC: /* plastic BRDF func */
163 case MAT_MFUNC: /* metal BRDF func */
164 case MAT_TFUNC: /* trans BRDF func */
165 getfunc(op, 1, 0, 0);
166 return(1);
167 case MAT_DIRECT1: /* prism1 material */
168 getfunc(op, 4, 0xf, 1);
169 return(1);
170 case MAT_DIRECT2: /* prism2 material */
171 getfunc(op, 8, 0xff, 1);
172 return(1);
173 }
174 /* nothing to load for the remaining types */
175 return(0);
176 sargerr:
177 objerror(op, USER, "too few string arguments");
178 }
179
180
181 void
182 preload_objs() /* preload object data structures */
183 {
184 register OBJECT on;
185 /* note that nobjects may change during loop */
186 for (on = 0; on < nobjects; on++)
187 load_os(objptr(on));
188 }
