root/Development/ray/src/rt/preload.c
Revision: 2.20
Committed: Fri Jun 20 23:48:28 2025 UTC (4 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
fix: syntax error in previous commit(!)
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.20 static const char RCSid[] = "$Id: preload.c,v 2.19 2025/06/20 23:47:43 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Preload associated object structures to maximize memory sharing.
6 greg 2.6 *
7     * External symbols declared in ray.h
8     */
9
10 greg 2.7 #include "copyright.h"
11 greg 2.1
12 greg 2.10 #include "ray.h"
13 greg 2.1 #include "otypes.h"
14     #include "face.h"
15     #include "cone.h"
16 greg 2.2 #include "instance.h"
17 greg 2.9 #include "mesh.h"
18 greg 2.5 #include "data.h"
19 schorsch 2.8 #include "func.h"
20 greg 2.10 #include "bsdf.h"
21 greg 2.1
22 greg 2.18 char *shm_boundary = NULL; /* boundary of shared memory */
23
24 greg 2.1
25 greg 2.6 /* KEEP THIS ROUTINE CONSISTENT WITH THE DIFFERENT OBJECT FUNCTIONS! */
26
27
28 greg 2.13 int
29 schorsch 2.8 load_os( /* load associated data for object */
30 greg 2.13 OBJREC *op
31 schorsch 2.8 )
32 greg 2.1 {
33 greg 2.14 DATARRAY *dp;
34     SDData *sd;
35
36     SDretainSet = SDretainAll;
37 greg 2.6
38 greg 2.1 switch (op->otype) {
39     case OBJ_FACE: /* polygon */
40     getface(op);
41     return(1);
42     case OBJ_CONE: /* cone */
43     case OBJ_RING: /* disk */
44     case OBJ_CYLINDER: /* cylinder */
45     case OBJ_CUP: /* inverted cone */
46     case OBJ_TUBE: /* inverted cylinder */
47     getcone(op, 1);
48     return(1);
49     case OBJ_INSTANCE: /* octree instance */
50     getinstance(op, IO_ALL);
51     return(1);
52 greg 2.9 case OBJ_MESH: /* mesh instance */
53     getmeshinst(op, IO_ALL);
54     return(1);
55 greg 2.5 case PAT_CPICT: /* color picture */
56     if (op->oargs.nsargs < 4)
57     goto sargerr;
58     getpict(op->oargs.sarg[3]);
59 greg 2.6 getfunc(op, 4, 0x3<<5, 0);
60 greg 2.5 return(1);
61     case PAT_CDATA: /* color data */
62 greg 2.17 if (op->oargs.nsargs < 4)
63     goto sargerr;
64 greg 2.6 dp = getdata(op->oargs.sarg[3]);
65     getdata(op->oargs.sarg[4]);
66     getdata(op->oargs.sarg[5]);
67     getfunc(op, 6, ((1<<dp->nd)-1)<<7, 0);
68     return(1);
69     case PAT_BDATA: /* brightness data */
70     if (op->oargs.nsargs < 2)
71     goto sargerr;
72     dp = getdata(op->oargs.sarg[1]);
73     getfunc(op, 2, ((1<<dp->nd)-1)<<3, 0);
74     return(1);
75     case PAT_BFUNC: /* brightness function */
76     getfunc(op, 1, 0x1, 0);
77     return(1);
78     case PAT_CFUNC: /* color function */
79     getfunc(op, 3, 0x7, 0);
80     return(1);
81 greg 2.17 case PAT_SPECFUNC: /* spectral function */
82     getfunc(op, 1, 0, 0);
83     return(1);
84     case PAT_SPECFILE: /* spectrum file */
85     if (op->oargs.nsargs < 1)
86     goto sargerr;
87     getdata(op->oargs.sarg[0]);
88     return(1);
89     case PAT_SPECDATA: /* spectral data file */
90     if (op->oargs.nsargs < 2)
91     goto sargerr;
92     dp = getdata(op->oargs.sarg[1]);
93     getfunc(op, 2, ((1<<(dp->nd-1)) - 1)<<3, 0);
94     return(1);
95     case PAT_SPECPICT: /* spectral picture */
96     if (op->oargs.nsargs < 2)
97     goto sargerr;
98     getspec(op->oargs.sarg[1]);
99     getfunc(op, 2, 0x3<<3, 0);
100     return(1);
101 greg 2.5 case TEX_DATA: /* texture data */
102     if (op->oargs.nsargs < 6)
103     goto sargerr;
104 greg 2.6 dp = getdata(op->oargs.sarg[3]);
105 greg 2.5 getdata(op->oargs.sarg[4]);
106     getdata(op->oargs.sarg[5]);
107 greg 2.6 getfunc(op, 6, ((1<<dp->nd)-1)<<7, 1);
108     return(1);
109     case TEX_FUNC: /* texture function */
110     getfunc(op, 3, 0x7, 1);
111     return(1);
112     case MIX_DATA: /* mixture data */
113     dp = getdata(op->oargs.sarg[3]);
114     getfunc(op, 4, ((1<<dp->nd)-1)<<5, 0);
115     return(1);
116     case MIX_PICT: /* mixture picture */
117     getpict(op->oargs.sarg[3]);
118     getfunc(op, 4, 0x3<<5, 0);
119     return(1);
120     case MIX_FUNC: /* mixture function */
121     getfunc(op, 3, 0x4, 0);
122     return(1);
123     case MAT_PLASTIC2: /* anisotropic plastic */
124     case MAT_METAL2: /* anisotropic metal */
125     getfunc(op, 3, 0x7, 1);
126     return(1);
127 greg 2.19 case MAT_WGMDF: /* WGMDfunc material */
128 greg 2.20 getfunc(op, 12, 0xEEE, 1);
129 greg 2.19 return(1);
130 greg 2.6 case MAT_BRTDF: /* BRDTfunc material */
131     getfunc(op, 9, 0x3f, 0);
132 greg 2.5 return(1);
133 greg 2.10 case MAT_BSDF: /* BSDF material */
134     if (op->oargs.nsargs < 6)
135     goto sargerr;
136     getfunc(op, 5, 0x1d, 1);
137 greg 2.14 sd = loadBSDF(op->oargs.sarg[1]);
138     if (sd != NULL) SDfreeCache(sd);
139 greg 2.10 return(1);
140 greg 2.16 case MAT_ABSDF: /* aBSDF material */
141 greg 2.15 if (op->oargs.nsargs < 5)
142     goto sargerr;
143     getfunc(op, 4, 0xe, 1);
144     sd = loadBSDF(op->oargs.sarg[0]);
145     if (sd != NULL) SDfreeCache(sd);
146     return(1);
147 greg 2.5 case MAT_PDATA: /* plastic BRDF data */
148     case MAT_MDATA: /* metal BRDF data */
149     case MAT_TDATA: /* trans BRDF data */
150     if (op->oargs.nsargs < 2)
151     goto sargerr;
152     getdata(op->oargs.sarg[1]);
153 greg 2.6 getfunc(op, 2, 0, 0);
154     return(1);
155     case MAT_PFUNC: /* plastic BRDF func */
156     case MAT_MFUNC: /* metal BRDF func */
157     case MAT_TFUNC: /* trans BRDF func */
158     getfunc(op, 1, 0, 0);
159     return(1);
160     case MAT_DIRECT1: /* prism1 material */
161     getfunc(op, 4, 0xf, 1);
162     return(1);
163     case MAT_DIRECT2: /* prism2 material */
164     getfunc(op, 8, 0xff, 1);
165 greg 2.5 return(1);
166 greg 2.1 }
167 greg 2.6 /* nothing to load for the remaining types */
168 greg 2.2 return(0);
169 greg 2.5 sargerr:
170     objerror(op, USER, "too few string arguments");
171 schorsch 2.8 return 0; /* pro forma return */
172 greg 2.1 }
173
174
175 greg 2.13 void
176 schorsch 2.8 preload_objs(void) /* preload object data structures */
177 greg 2.1 {
178 greg 2.13 OBJECT on;
179 greg 2.3 /* note that nobjects may change during loop */
180 greg 2.1 for (on = 0; on < nobjects; on++)
181     load_os(objptr(on));
182 greg 2.3 }
183 greg 2.18
184
185     void
186     cow_memshare(void) /* set up copy-on-write memory sharing */
187     {
188     if (shm_boundary != NULL)
189     return; /* assume we're good */
190
191     preload_objs(); /* preload auxiliary data */
192     /* set shared memory boundary */
193     shm_boundary = (char *)malloc(16);
194     strcpy(shm_boundary, "SHM_BOUNDARY");
195     }
196
197
198     void
199     cow_doneshare(void) /* clear memory sharing boundary */
200     {
201     if (shm_boundary == NULL)
202     return;
203     /* clear shared memory boundary */
204     free((void *)shm_boundary);
205     shm_boundary = NULL;
206     }
