root/radiance/ray/src/rt/pmutil.c
Revision: 2.5
Committed: Wed Apr 8 15:14:21 2020 UTC (4 years, 11 months ago) by rschregle
Changes since 2.4: +7 -4 lines
Fixed est00pid bug in single photon lookups that returned junk when none found, added code to detect and handle (ignore).
2 static const char RCSid[] = "$Id: pmutil.c,v 2.4 2020/01/23 18:27:02 rschregle Exp $";
4
5 /*
6 ======================================================================
7 Photon map utilities
8
9 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
10 (c) Fraunhofer Institute for Solar Energy Systems,
11 (c) Lucerne University of Applied Sciences and Arts,
12 supported by the Swiss National Science Foundation (SNSF, #147053)
13 ======================================================================
14
15 $Id: pmutil.c,v 2.4 2020/01/23 18:27:02 rschregle Exp $
16 */
17
18 #include "pmap.h"
19 #include "pmapio.h"
20 #include "pmapbias.h"
21 #include "otypes.h"
22 #include <sys/stat.h>
23
24
25 extern char *octname;
26
27
28 /* Photon map lookup functions per type */
29 void (*pmapLookup [NUM_PMAP_TYPES])(PhotonMap*, RAY*, COLOR) = {
30 photonDensity, photonPreCompDensity, photonDensity, volumePhotonDensity,
31 photonDensity, photonDensity
32 };
33
34
35
36
37 void colorNorm (COLOR c)
38 /* Normalise colour channels to average of 1 */
39 {
40 const float avg = colorAvg(c);
41
42 if (!avg)
43 return;
44
45 c [0] /= avg;
46 c [1] /= avg;
47 c [2] /= avg;
48 }
49
50
51
52
53 void loadPmaps (PhotonMap **pmaps, const PhotonMapParams *parm)
54 {
55 unsigned t;
56 struct stat octstat, pmstat;
57 PhotonMap *pm;
58 PhotonMapType type;
59
60 for (t = 0; t < NUM_PMAP_TYPES; t++)
61 if (setPmapParam(&pm, parm + t)) {
62 /* Check if photon map newer than octree */
63 if (pm -> fileName && octname &&
64 !stat(pm -> fileName, &pmstat) && !stat(octname, &octstat) &&
65 octstat.st_mtime > pmstat.st_mtime) {
66 sprintf(errmsg, "photon map in file %s may be stale",
67 pm -> fileName);
68 error(USER, errmsg);
69 }
70
71 /* Load photon map from file and get its type */
72 if ((type = loadPhotonMap(pm, pm -> fileName)) == PMAP_TYPE_NONE)
73 error(USER, "failed loading photon map");
74
75 /* Assign to appropriate photon map type (deleting previously
76 * loaded photon map of same type if necessary) */
77 if (pmaps [type]) {
78 sprintf(errmsg, "multiple %s photon maps, dropping previous",
79 pmapName [type]);
80 error(WARNING, errmsg);
81 deletePhotons(pmaps [type]);
82 free(pmaps [type]);
83 }
84 pmaps [type] = pm;
85
86 /* Check for valid density estimate bandwidths */
87 if ((pm -> minGather > 1 || pm -> maxGather > 1) &&
88 (type == PMAP_TYPE_PRECOMP)) {
89 /* Force bwidth to 1 for precomputed pmap */
90 error(WARNING, "ignoring bandwidth for precomp photon map");
91 pm -> minGather = pm -> maxGather = 1;
92 }
93
94 if ((pm -> maxGather > pm -> minGather) &&
95 (type == PMAP_TYPE_VOLUME)) {
96 /* Biascomp for volume pmaps (see volumePhotonDensity() below)
97 is considered redundant, and there's probably no point in
98 recovering by using the lower bandwidth, since it's probably
99 not what the user wants, so bail out. */
100 sprintf(errmsg,
101 "bias compensation is not available with %s photon maps",
102 pmapName [type]);
103 error(USER, errmsg);
104 }
105
106 if (pm -> maxGather > pm -> numPhotons) {
107 error(WARNING, "adjusting density estimate bandwidth");
108 pm -> minGather = pm -> maxGather = pm -> numPhotons;
109 }
110 }
111 }
112
113
114
115 void cleanUpPmaps (PhotonMap **pmaps)
116 {
117 unsigned t;
118
119 for (t = 0; t < NUM_PMAP_TYPES; t++) {
120 if (pmaps [t]) {
121 deletePhotons(pmaps [t]);
122 free(pmaps [t]);
123 }
124 }
125 }
126
127
128
129
130 void photonDensity (PhotonMap *pmap, RAY *ray, COLOR irrad)
131 /* Photon density estimate. Returns irradiance at ray -> rop. */
132 {
133 unsigned i;
134 float r2;
135 COLOR flux;
136 Photon *photon;
137 const PhotonSearchQueueNode *sqn;
138
139 setcolor(irrad, 0, 0, 0);
140
141 if (!pmap -> maxGather)
142 return;
143
144 /* Ignore sources */
145 if (ray -> ro && islight(objptr(ray -> ro -> omod) -> otype))
146 return;
147
148 findPhotons(pmap, ray);
149
150 /* Need at least 2 photons */
151 if (pmap -> squeue.tail < 2) {
152 #ifdef PMAP_NONEFOUND
153 sprintf(errmsg, "no photons found on %s at (%.3f, %.3f, %.3f)",
154 ray -> ro ? ray -> ro -> oname : "<null>",
155 ray -> rop [0], ray -> rop [1], ray -> rop [2]);
156 error(WARNING, errmsg);
157 #endif
158
159 return;
160 }
161
162 if (pmap -> minGather == pmap -> maxGather) {
163 /* No bias compensation. Just do a plain vanilla estimate */
164 sqn = pmap -> squeue.node + 1;
165
166 /* Average radius^2 between furthest two photons to improve accuracy */
167 r2 = max(sqn -> dist2, (sqn + 1) -> dist2);
168 r2 = 0.25 * (pmap -> maxDist2 + r2 + 2 * sqrt(pmap -> maxDist2 * r2));
169
170 /* Skip the extra photon */
171 for (i = 1 ; i < pmap -> squeue.tail; i++, sqn++) {
172 photon = getNearestPhoton(&pmap -> squeue, sqn -> idx);
173 getPhotonFlux(photon, flux);
174 #ifdef PMAP_EPANECHNIKOV
175 /* Apply Epanechnikov kernel to photon flux based on photon dist */
176 scalecolor(flux, 2 * (1 - sqn -> dist2 / r2));
177 #endif
178 addcolor(irrad, flux);
179 }
180
181 /* Divide by search area PI * r^2, 1 / PI required as ambient
182 normalisation factor */
183 scalecolor(irrad, 1 / (PI * PI * r2));
184
185 return;
186 }
187 else
188 /* Apply bias compensation to density estimate */
189 biasComp(pmap, irrad);
190 }
191
192
193
194
195 void photonPreCompDensity (PhotonMap *pmap, RAY *r, COLOR irrad)
196 /* Returns precomputed photon density estimate at ray -> rop. */
197 {
198 Photon p;
199
200 setcolor(irrad, 0, 0, 0);
201
202 /* Ignore sources */
203 if (r -> ro && islight(objptr(r -> ro -> omod) -> otype))
204 return;
205
206 if (find1Photon(preCompPmap, r, &p))
207 /* p contains a found photon, so get its irradiance, otherwise it
208 * remains zero under the assumption all photons are too distant
209 * to contribute significantly */
210 getPhotonFlux(&p, irrad);
211 }
212
213
214
215
216 void volumePhotonDensity (PhotonMap *pmap, RAY *ray, COLOR irrad)
217 /* Photon volume density estimate. Returns irradiance at ray -> rop. */
218 {
219 unsigned i;
220 float r2, gecc2, ph;
221 COLOR flux;
222 Photon *photon;
223 const PhotonSearchQueueNode *sqn;
224
225 setcolor(irrad, 0, 0, 0);
226
227 if (!pmap -> maxGather)
228 return;
229
230 findPhotons(pmap, ray);
231
232 /* Need at least 2 photons */
233 if (pmap -> squeue.tail < 2)
234 return;
235
236 #if 0
237 /* Volume biascomp disabled (probably redundant) */
238 if (pmap -> minGather == pmap -> maxGather)
239 #endif
240 {
241 /* No bias compensation. Just do a plain vanilla estimate */
242 gecc2 = ray -> gecc * ray -> gecc;
243 sqn = pmap -> squeue.node + 1;
244
245 /* Average radius^2 between furthest two photons to improve accuracy */
246 r2 = max(sqn -> dist2, (sqn + 1) -> dist2);
247 r2 = 0.25 * (pmap -> maxDist2 + r2 + 2 * sqrt(pmap -> maxDist2 * r2));
248
249 /* Skip the extra photon */
250 for (i = 1; i < pmap -> squeue.tail; i++, sqn++) {
251 photon = getNearestPhoton(&pmap -> squeue, sqn -> idx);
252
253 /* Compute phase function for inscattering from photon */
254 if (gecc2 <= FTINY)
255 ph = 1;
256 else {
257 ph = DOT(ray -> rdir, photon -> norm) / 127;
258 ph = 1 + gecc2 - 2 * ray -> gecc * ph;
259 ph = (1 - gecc2) / (ph * sqrt(ph));
260 }
261
262 getPhotonFlux(photon, flux);
263 scalecolor(flux, ph);
264 addcolor(irrad, flux);
265 }
266
267 /* Divide by search volume 4 / 3 * PI * r^3 and phase function
268 normalization factor 1 / (4 * PI) */
269 scalecolor(irrad, 3 / (16 * PI * PI * r2 * sqrt(r2)));
270 return;
271 }
272 #if 0
273 else
274 /* Apply bias compensation to density estimate */
275 volumeBiasComp(pmap, ray, irrad);
276 #endif
277 }
