root/radiance/ray/src/rt/pmutil.c
Fri Jan 10 21:43:22 2025 UTC (4 months, 1 week ago) by greg
fix: Avoid second release of photon maps (malloc error)
Tue Mar 23 00:07:13 2021 UTC (4 years, 1 month ago) by rschregle
Changes since 2.5: +18 -11 lines
Fixed off-by-one bug in photon density estimate bandwidth clamping if
exceeds number of photons.
Wed Apr 8 15:14:21 2020 UTC (5 years, 1 month ago) by rschregle
Changes since 2.4: +7 -4 lines
Fixed est00pid bug in single photon lookups that returned junk when none found, added code to detect and handle (ignore).
Thu Jan 23 18:27:02 2020 UTC (5 years, 3 months ago) by rschregle
Changes since 2.3: +26 -4 lines
Added check for deprecated biascomp with volume pmaps in loadPmaps().
Fri Feb 9 14:57:42 2018 UTC (7 years, 3 months ago) by rschregle
Changes since 2.2: +13 -13 lines
r -> r2 in photonDensity() to emphasise squared radius
Wed Jan 24 19:39:05 2018 UTC (7 years, 3 months ago) by rschregle
Hack to render contrib pmap as regular global pmap with rpict/rtrace/rvu
Mon Sep 26 20:19:30 2016 UTC (8 years, 7 months ago) by greg
Diff to selected 2.3
Pulled pmap routines needed during rendering from pmap.c into pmutil.c
