1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: pmapcontrib.c,v 2.12 2016/05/17 17:39:47 rschregle Exp $"; |
3 |
#endif |
4 |
5 |
6 |
7 |
Photon map support for using light source contributions |
8 |
9 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
10 |
(c) Lucerne University of Applied Sciences and Arts, |
11 |
supported by the Swiss National Science Foundation (SNSF, #147053) |
12 |
13 |
14 |
$Id: pmapcontrib.c,v 2.12 2016/05/17 17:39:47 rschregle Exp $ |
15 |
16 |
17 |
18 |
#include "pmapcontrib.h" |
19 |
#include "pmapmat.h" |
20 |
#include "pmapsrc.h" |
21 |
#include "pmaprand.h" |
22 |
#include "pmapio.h" |
23 |
#include "pmapdiag.h" |
24 |
#include "rcontrib.h" |
25 |
#include "otypes.h" |
26 |
#include <sys/mman.h> |
27 |
#include <sys/wait.h> |
28 |
29 |
30 |
31 |
static void setPmapContribParams (PhotonMap *pmap, LUTAB *srcContrib) |
32 |
/* Set parameters for light source contributions */ |
33 |
34 |
/* Set light source modifier list and appropriate callback to extract |
35 |
* their contributions from the photon map */ |
36 |
if (pmap) { |
37 |
pmap -> srcContrib = srcContrib; |
38 |
pmap -> lookup = photonContrib; |
39 |
/* Ensure we get all requested photon contribs during lookups */ |
40 |
pmap -> gatherTolerance = 1.0; |
41 |
42 |
43 |
44 |
45 |
46 |
static void checkPmapContribs (const PhotonMap *pmap, LUTAB *srcContrib) |
47 |
/* Check modifiers for light source contributions */ |
48 |
49 |
const PhotonPrimary *primary = pmap -> primaries; |
50 |
PhotonPrimaryIdx i, found = 0; |
51 |
OBJREC *srcMod; |
52 |
53 |
/* Make sure at least one of the modifiers is actually in the pmap, |
54 |
* otherwise findPhotons() winds up in an infinite loop! */ |
55 |
for (i = pmap -> numPrimary; i; --i, ++primary) { |
56 |
if (primary -> srcIdx < 0 || primary -> srcIdx >= nsources) |
57 |
error(INTERNAL, "invalid light source index in photon map"); |
58 |
59 |
srcMod = findmaterial(source [primary -> srcIdx].so); |
60 |
if ((MODCONT*)lu_find(srcContrib, srcMod -> oname) -> data) |
61 |
++found; |
62 |
63 |
64 |
if (!found) |
65 |
error(USER, "modifiers not in photon map"); |
66 |
67 |
68 |
69 |
70 |
void initPmapContrib (LUTAB *srcContrib, unsigned numSrcContrib) |
71 |
72 |
unsigned t; |
73 |
74 |
for (t = 0; t < NUM_PMAP_TYPES; t++) |
75 |
if (photonMaps [t] && t != PMAP_TYPE_CONTRIB) { |
76 |
sprintf(errmsg, "%s photon map does not support contributions", |
77 |
pmapName [t]); |
78 |
error(USER, errmsg); |
79 |
80 |
81 |
/* Get params */ |
82 |
setPmapContribParams(contribPmap, srcContrib); |
83 |
84 |
if (contribPhotonMapping) { |
85 |
if (contribPmap -> maxGather < numSrcContrib) { |
86 |
/* Adjust density estimate bandwidth if lower than modifier |
87 |
* count, otherwise contributions are missing */ |
88 |
error(WARNING, "contrib density estimate bandwidth too low, " |
89 |
"adjusting to modifier count"); |
90 |
contribPmap -> maxGather = numSrcContrib; |
91 |
92 |
93 |
/* Sanity check */ |
94 |
checkPmapContribs(contribPmap, srcContrib); |
95 |
96 |
97 |
98 |
99 |
100 |
void photonContrib (PhotonMap *pmap, RAY *ray, COLOR irrad) |
101 |
/* Sum up light source contributions from photons in pmap->srcContrib */ |
102 |
103 |
unsigned i; |
104 |
PhotonSearchQueueNode *sqn; |
105 |
float r, invArea; |
106 |
RREAL rayCoeff [3]; |
107 |
Photon *photon; |
108 |
static char warn = 1; |
109 |
110 |
setcolor(irrad, 0, 0, 0); |
111 |
112 |
if (!pmap -> maxGather) |
113 |
return; |
114 |
115 |
/* Ignore sources */ |
116 |
if (ray -> ro && islight(objptr(ray -> ro -> omod) -> otype)) |
117 |
return; |
118 |
119 |
/* Get cumulative path coefficient up to photon lookup point */ |
120 |
raycontrib(rayCoeff, ray, PRIMARY); |
121 |
122 |
/* Lookup photons */ |
123 |
pmap -> squeue.tail = 0; |
124 |
findPhotons(pmap, ray); |
125 |
126 |
/* Need at least 2 photons */ |
127 |
if (pmap -> squeue.tail < 2) { |
128 |
#ifdef PMAP_NONEFOUND |
129 |
sprintf(errmsg, "no photons found on %s at (%.3f, %.3f, %.3f)", |
130 |
ray -> ro ? ray -> ro -> oname : "<null>", |
131 |
ray -> rop [0], ray -> rop [1], ray -> rop [2]); |
132 |
error(WARNING, errmsg); |
133 |
#endif |
134 |
135 |
return; |
136 |
137 |
138 |
/* Average (squared) radius between furthest two photons to improve |
139 |
* accuracy and get inverse search area 1 / (PI * r^2), with extra |
140 |
* normalisation factor 1 / PI for ambient calculation */ |
141 |
sqn = pmap -> squeue.node + 1; |
142 |
r = max(sqn -> dist2, (sqn + 1) -> dist2); |
143 |
r = 0.25 * (pmap -> maxDist2 + r + 2 * sqrt(pmap -> maxDist2 * r)); |
144 |
invArea = 1 / (PI * PI * r); |
145 |
146 |
/* Skip the extra photon */ |
147 |
for (i = 1 ; i < pmap -> squeue.tail; i++, sqn++) { |
148 |
COLOR flux; |
149 |
150 |
/* Get photon's contribution to density estimate */ |
151 |
photon = getNearestPhoton(&pmap -> squeue, sqn -> idx); |
152 |
getPhotonFlux(photon, flux); |
153 |
scalecolor(flux, invArea); |
154 |
#ifdef PMAP_EPANECHNIKOV |
155 |
/* Apply Epanechnikov kernel to photon flux based on photon distance */ |
156 |
scalecolor(flux, 2 * (1 - sqn -> dist2 / r)); |
157 |
#endif |
158 |
addcolor(irrad, flux); |
159 |
160 |
if (pmap -> srcContrib) { |
161 |
const PhotonPrimary *primary = pmap -> primaries + |
162 |
photon -> primary; |
163 |
const SRCREC *sp = &source [primary -> srcIdx]; |
164 |
OBJREC *srcMod = findmaterial(sp -> so); |
165 |
MODCONT *srcContrib = (MODCONT*)lu_find(pmap -> srcContrib, |
166 |
srcMod -> oname) -> data; |
167 |
double srcBinReal; |
168 |
int srcBin; |
169 |
RAY srcRay; |
170 |
171 |
if (!srcContrib) |
172 |
continue; |
173 |
174 |
/* Photon's emitting light source has modifier whose contributions |
175 |
* are sought */ |
176 |
if (srcContrib -> binv -> type != NUM) { |
177 |
/* Use intersection function to set shadow ray parameters if |
178 |
* it's not simply a constant */ |
179 |
rayorigin(&srcRay, SHADOW, NULL, NULL); |
180 |
srcRay.rsrc = primary -> srcIdx; |
181 |
#ifdef PMAP_PRIMARYPOS |
182 |
VCOPY(srcRay.rorg, primary -> pos); |
183 |
#else |
184 |
/* No primary hitpoints; set dummy ray origin and warn once */ |
185 |
srcRay.rorg [0] = srcRay.rorg [1] = srcRay.rorg [2] = 0; |
186 |
if (warn) { |
187 |
error(WARNING, "no photon primary hitpoints for bin evaluation;" |
188 |
" using dummy (0,0,0) !"); |
189 |
warn = 0; |
190 |
191 |
#endif |
192 |
decodedir(srcRay.rdir, primary -> dir); |
193 |
194 |
if (!(sp->sflags & SDISTANT |
195 |
? sourcehit(&srcRay) |
196 |
: (*ofun[sp -> so -> otype].funp)(sp -> so, &srcRay))) |
197 |
continue; /* XXX shouldn't happen! */ |
198 |
199 |
worldfunc(RCCONTEXT, &srcRay); |
200 |
set_eparams((char *)srcContrib -> params); |
201 |
202 |
203 |
if ((srcBinReal = evalue(srcContrib -> binv)) < -.5) |
204 |
continue; /* silently ignore negative bins */ |
205 |
206 |
if ((srcBin = srcBinReal + .5) >= srcContrib -> nbins) { |
207 |
error(WARNING, "bad bin number (ignored)"); |
208 |
continue; |
209 |
210 |
211 |
if (!contrib) { |
212 |
/* Ray coefficient mode; normalise by light source radiance |
213 |
* after applying distrib pattern */ |
214 |
int j; |
215 |
216 |
raytexture(ray, srcMod -> omod); |
217 |
setcolor(ray -> rcol, srcMod -> oargs.farg [0], |
218 |
srcMod -> oargs.farg [1], srcMod -> oargs.farg [2]); |
219 |
multcolor(ray -> rcol, ray -> pcol); |
220 |
for (j = 0; j < 3; j++) |
221 |
flux [j] = ray -> rcol [j] ? flux [j] / ray -> rcol [j] : 0; |
222 |
223 |
224 |
multcolor(flux, rayCoeff); |
225 |
addcolor(srcContrib -> cbin [srcBin], flux); |
226 |
227 |
228 |
229 |
return; |
230 |
