1 |
greg |
2.1 |
#ifndef lint |
2 |
greg |
2.5 |
static const char RCSid[] = "$Id: pmcontrib2.c,v 2.4 2018/02/09 14:59:08 rschregle Exp $"; |
3 |
greg |
2.1 |
#endif |
4 |
5 |
6 |
7 |
Photon map support for using light source contributions |
8 |
9 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
10 |
(c) Lucerne University of Applied Sciences and Arts, |
11 |
supported by the Swiss National Science Foundation (SNSF, #147053) |
12 |
13 |
14 |
greg |
2.5 |
$Id: pmcontrib2.c,v 2.4 2018/02/09 14:59:08 rschregle Exp $ |
15 |
greg |
2.1 |
16 |
17 |
18 |
#include "pmapcontrib.h" |
19 |
#include "pmapmat.h" |
20 |
#include "pmapsrc.h" |
21 |
#include "pmaprand.h" |
22 |
#include "pmapio.h" |
23 |
#include "pmapdiag.h" |
24 |
#include "rcontrib.h" |
25 |
#include "otypes.h" |
26 |
greg |
2.5 |
#include "otspecial.h" |
27 |
greg |
2.1 |
28 |
29 |
static void setPmapContribParams (PhotonMap *pmap, LUTAB *srcContrib) |
30 |
/* Set parameters for light source contributions */ |
31 |
32 |
/* Set light source modifier list and appropriate callback to extract |
33 |
* their contributions from the photon map */ |
34 |
if (pmap) { |
35 |
pmap -> srcContrib = srcContrib; |
36 |
pmap -> lookup = photonContrib; |
37 |
/* Ensure we get all requested photon contribs during lookups */ |
38 |
pmap -> gatherTolerance = 1.0; |
39 |
40 |
41 |
42 |
43 |
44 |
static void checkPmapContribs (const PhotonMap *pmap, LUTAB *srcContrib) |
45 |
/* Check modifiers for light source contributions */ |
46 |
47 |
const PhotonPrimary *primary = pmap -> primaries; |
48 |
PhotonPrimaryIdx i, found = 0; |
49 |
OBJREC *srcMod; |
50 |
51 |
/* Make sure at least one of the modifiers is actually in the pmap, |
52 |
* otherwise findPhotons() winds up in an infinite loop! */ |
53 |
for (i = pmap -> numPrimary; i; --i, ++primary) { |
54 |
if (primary -> srcIdx < 0 || primary -> srcIdx >= nsources) |
55 |
error(INTERNAL, "invalid light source index in photon map"); |
56 |
57 |
srcMod = findmaterial(source [primary -> srcIdx].so); |
58 |
if ((MODCONT*)lu_find(srcContrib, srcMod -> oname) -> data) |
59 |
++found; |
60 |
61 |
62 |
if (!found) |
63 |
error(USER, "modifiers not in photon map"); |
64 |
65 |
66 |
67 |
68 |
void initPmapContrib (LUTAB *srcContrib, unsigned numSrcContrib) |
69 |
70 |
unsigned t; |
71 |
72 |
for (t = 0; t < NUM_PMAP_TYPES; t++) |
73 |
if (photonMaps [t] && t != PMAP_TYPE_CONTRIB) { |
74 |
sprintf(errmsg, "%s photon map does not support contributions", |
75 |
pmapName [t]); |
76 |
error(USER, errmsg); |
77 |
78 |
79 |
/* Get params */ |
80 |
setPmapContribParams(contribPmap, srcContrib); |
81 |
82 |
if (contribPhotonMapping) { |
83 |
if (contribPmap -> maxGather < numSrcContrib) { |
84 |
rschregle |
2.3 |
#if 0 |
85 |
greg |
2.1 |
/* Adjust density estimate bandwidth if lower than modifier |
86 |
* count, otherwise contributions are missing */ |
87 |
error(WARNING, "contrib density estimate bandwidth too low, " |
88 |
"adjusting to modifier count"); |
89 |
contribPmap -> maxGather = numSrcContrib; |
90 |
rschregle |
2.3 |
#else |
91 |
/* Warn if density estimate bandwidth is lower than modifier |
92 |
* count, since some contributions will be missing */ |
93 |
error(WARNING, "photon density estimate bandwidth too low," |
94 |
" contributions may be underestimated"); |
95 |
#endif |
96 |
greg |
2.1 |
97 |
98 |
/* Sanity check */ |
99 |
checkPmapContribs(contribPmap, srcContrib); |
100 |
101 |
102 |
103 |
104 |
105 |
void photonContrib (PhotonMap *pmap, RAY *ray, COLOR irrad) |
106 |
/* Sum up light source contributions from photons in pmap->srcContrib */ |
107 |
108 |
unsigned i; |
109 |
PhotonSearchQueueNode *sqn; |
110 |
rschregle |
2.4 |
float r2, invArea; |
111 |
greg |
2.1 |
RREAL rayCoeff [3]; |
112 |
Photon *photon; |
113 |
rschregle |
2.4 |
static char warnPos = 1, warnDir = 1; |
114 |
greg |
2.1 |
115 |
setcolor(irrad, 0, 0, 0); |
116 |
117 |
if (!pmap -> maxGather) |
118 |
return; |
119 |
120 |
/* Ignore sources */ |
121 |
if (ray -> ro && islight(objptr(ray -> ro -> omod) -> otype)) |
122 |
return; |
123 |
124 |
/* Get cumulative path coefficient up to photon lookup point */ |
125 |
raycontrib(rayCoeff, ray, PRIMARY); |
126 |
127 |
/* Lookup photons */ |
128 |
pmap -> squeue.tail = 0; |
129 |
findPhotons(pmap, ray); |
130 |
131 |
/* Need at least 2 photons */ |
132 |
if (pmap -> squeue.tail < 2) { |
133 |
#ifdef PMAP_NONEFOUND |
134 |
sprintf(errmsg, "no photons found on %s at (%.3f, %.3f, %.3f)", |
135 |
ray -> ro ? ray -> ro -> oname : "<null>", |
136 |
ray -> rop [0], ray -> rop [1], ray -> rop [2]); |
137 |
error(WARNING, errmsg); |
138 |
#endif |
139 |
140 |
return; |
141 |
142 |
143 |
rschregle |
2.4 |
/* Average radius^2 between furthest two photons to improve accuracy and |
144 |
* get inverse search area 1 / (PI * r^2), with extra normalisation |
145 |
* factor 1 / PI for ambient calculation */ |
146 |
greg |
2.1 |
sqn = pmap -> squeue.node + 1; |
147 |
rschregle |
2.4 |
r2 = max(sqn -> dist2, (sqn + 1) -> dist2); |
148 |
r2 = 0.25 * (pmap -> maxDist2 + r2 + 2 * sqrt(pmap -> maxDist2 * r2)); |
149 |
invArea = 1 / (PI * PI * r2); |
150 |
greg |
2.1 |
151 |
/* Skip the extra photon */ |
152 |
for (i = 1 ; i < pmap -> squeue.tail; i++, sqn++) { |
153 |
COLOR flux; |
154 |
155 |
/* Get photon's contribution to density estimate */ |
156 |
photon = getNearestPhoton(&pmap -> squeue, sqn -> idx); |
157 |
getPhotonFlux(photon, flux); |
158 |
scalecolor(flux, invArea); |
159 |
#ifdef PMAP_EPANECHNIKOV |
160 |
/* Apply Epanechnikov kernel to photon flux based on photon distance */ |
161 |
rschregle |
2.4 |
scalecolor(flux, 2 * (1 - sqn -> dist2 / r2)); |
162 |
greg |
2.1 |
#endif |
163 |
addcolor(irrad, flux); |
164 |
165 |
if (pmap -> srcContrib) { |
166 |
const PhotonPrimary *primary = pmap -> primaries + |
167 |
photon -> primary; |
168 |
const SRCREC *sp = &source [primary -> srcIdx]; |
169 |
OBJREC *srcMod = findmaterial(sp -> so); |
170 |
MODCONT *srcContrib = (MODCONT*)lu_find(pmap -> srcContrib, |
171 |
srcMod -> oname) -> data; |
172 |
double srcBinReal; |
173 |
int srcBin; |
174 |
RAY srcRay; |
175 |
176 |
if (!srcContrib) |
177 |
continue; |
178 |
179 |
/* Photon's emitting light source has modifier whose contributions |
180 |
* are sought */ |
181 |
if (srcContrib -> binv -> type != NUM) { |
182 |
/* Use intersection function to set shadow ray parameters if |
183 |
* it's not simply a constant */ |
184 |
rayorigin(&srcRay, SHADOW, NULL, NULL); |
185 |
srcRay.rsrc = primary -> srcIdx; |
186 |
#ifdef PMAP_PRIMARYPOS |
187 |
VCOPY(srcRay.rorg, primary -> pos); |
188 |
#else |
189 |
/* No primary hitpoints; set dummy ray origin and warn once */ |
190 |
srcRay.rorg [0] = srcRay.rorg [1] = srcRay.rorg [2] = 0; |
191 |
rschregle |
2.4 |
if (warnPos) { |
192 |
error(WARNING, |
193 |
"no photon primary hitpoints for bin evaluation; " |
194 |
"using dummy (0,0,0)! Recompile with -DPMAP_CBDM."); |
195 |
warnPos = 0; |
196 |
greg |
2.1 |
197 |
#endif |
198 |
rschregle |
2.4 |
#ifdef PMAP_PRIMARYDIR |
199 |
greg |
2.1 |
decodedir(srcRay.rdir, primary -> dir); |
200 |
rschregle |
2.4 |
#else |
201 |
/* No primary incident direction; set dummy and warn once */ |
202 |
if (warnDir) { |
203 |
error(WARNING, |
204 |
"no photon primary directions for bin evaluation; " |
205 |
206 |
warnDir = 0; |
207 |
208 |
srcRay.rdir [0] = srcRay.rdir [1] = srcRay.rdir [2] = 0; |
209 |
#endif |
210 |
greg |
2.1 |
211 |
if (!(sp->sflags & SDISTANT |
212 |
? sourcehit(&srcRay) |
213 |
: (*ofun[sp -> so -> otype].funp)(sp -> so, &srcRay))) |
214 |
continue; /* XXX shouldn't happen! */ |
215 |
216 |
worldfunc(RCCONTEXT, &srcRay); |
217 |
set_eparams((char *)srcContrib -> params); |
218 |
219 |
220 |
if ((srcBinReal = evalue(srcContrib -> binv)) < -.5) |
221 |
continue; /* silently ignore negative bins */ |
222 |
223 |
if ((srcBin = srcBinReal + .5) >= srcContrib -> nbins) { |
224 |
error(WARNING, "bad bin number (ignored)"); |
225 |
continue; |
226 |
227 |
228 |
if (!contrib) { |
229 |
/* Ray coefficient mode; normalise by light source radiance |
230 |
* after applying distrib pattern */ |
231 |
int j; |
232 |
233 |
raytexture(ray, srcMod -> omod); |
234 |
setcolor(ray -> rcol, srcMod -> oargs.farg [0], |
235 |
srcMod -> oargs.farg [1], srcMod -> oargs.farg [2]); |
236 |
multcolor(ray -> rcol, ray -> pcol); |
237 |
for (j = 0; j < 3; j++) |
238 |
flux [j] = ray -> rcol [j] ? flux [j] / ray -> rcol [j] : 0; |
239 |
240 |
241 |
multcolor(flux, rayCoeff); |
242 |
addcolor(srcContrib -> cbin [srcBin], flux); |
243 |
244 |
245 |
246 |
return; |
247 |
