root/radiance/ray/src/rt/pmapsrc.h
Revision: 2.2
Committed: Fri May 8 13:20:23 2015 UTC (9 years, 11 months ago) by rschregle
1 /*
2 ==================================================================
3 Photon map support routines for emission from light sources
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Fraunhofer Institute for Solar Energy Systems,
7 (c) Lucerne University of Applied Sciences and Arts,
8 supported by the Swiss National Science Foundation (SNSF, #147053)
9 ==================================================================
10
11 $Id: pmapsrc.h,v 2.1 2015/02/24 19:39:27 greg Exp $
12 */
13
14
15
16 #ifndef PMAPSRC_H
17 #define PMAPSRC_H
18
19 #include "ray.h"
20 #include "source.h"
21
22
23
24 /* Data structures for photon emission */
25 typedef struct {
26 unsigned theta, phi; /* Direction indices */
27 COLOR pdf; /* Probability of emission in this
28 direction per RGB */
29 float cdf; /* Cumulative probability up to
30 this sample */
31 } EmissionSample;
32
33 typedef struct {
34 unsigned numTheta, numPhi; /* Num divisions in theta & phi */
35 RREAL cosThetaMax; /* cos(source aperture) */
36 FVECT uh, vh, wh; /* Emission aperture axes at origin,
37 w is normal*/
38 FVECT us, vs, ws; /* Source surface axes at origin,
39 w is normal */
40 FVECT photonOrg; /* Current photon origin */
41 EmissionSample *samples; /* PDF samples for photon emission
42 directions */
43 unsigned long numPartitions; /* Number of surface partitions */
44 RREAL partArea; /* Area covered by each partition */
45 SRCREC *src, *port; /* Current source and port */
46 unsigned long partitionCnt, /* Current surface partition */
47 maxPartitions, /* Max allocated partitions */
48 numSamples; /* Number of PDF samples */
49 unsigned char* partitions; /* Source surface partitions */
50 COLOR partFlux; /* Total flux emitted by partition */
51 float cdf; /* Cumulative probability */
52 } EmissionMap;
53
54
55
56 /* Photon port list for emission from geometry en lieu of light sources */
57 extern SRCREC *photonPorts;
58 extern unsigned numPhotonPorts;
59
60 /* Dispatch tables for partitioning light source surfaces and generating
61 an origin for photon emission */
62 extern void (*photonPartition []) (EmissionMap*);
63 extern void (*photonOrigin []) (EmissionMap*);
64
65
66
67 void getPhotonPorts ();
68 /* Find geometry declared as photon ports */
69
70 void initPhotonEmissionFuncs ();
71 /* Init photonPartition[] and photonOrigin[] dispatch tables with source
72 specific emission routines */
73
74 void initPhotonEmission (EmissionMap *emap, float numPdfSamples);
75 /* Initialize photon emission from partitioned light source emap -> src;
76 * this involves integrating the flux emitted from the current photon
77 * origin emap -> photonOrg and setting up a PDF to sample the emission
78 * distribution with numPdfSamples samples */
79
80 void emitPhoton (const EmissionMap*, RAY* ray);
81 /* Emit photon from current source partition based on emission
82 distribution and return new photon ray */
83
84 void multDirectPmap (RAY *r);
85 /* Factor irradiance from direct photons into r -> rcol; interface to
86 * direct() */
87
88 void inscatterVolumePmap (RAY *r, COLOR inscatter);
89 /* Add inscattering from volume photon map; interface to srcscatter() */
90
91 #endif
