root/radiance/ray/src/rt/pmapsrc.h
Fri Aug 7 01:21:13 2020 UTC (4 years, 8 months ago) by rschregle
CVS Tags: rad5R3, rad5R4
Changes since 2.6: +16 -5 lines
feat(mkpmap): Extended -apo option to reorient photon ports.
Tue Mar 20 19:55:33 2018 UTC (7 years, 1 month ago) by rschregle
Added -ae/-ai ambient exclude options to mkpmap, cleaned up opt parsing.
Tue May 17 17:39:47 2016 UTC (8 years, 11 months ago) by rschregle
Tue Sep 1 16:27:53 2015 UTC (9 years, 8 months ago) by greg
Changes since 2.3: +1 -2 lines
Tue Aug 18 18:45:55 2015 UTC (9 years, 8 months ago) by greg
Fri May 8 13:20:23 2015 UTC (9 years, 11 months ago) by rschregle
Tue Feb 24 19:39:27 2015 UTC (10 years, 2 months ago) by greg
Diff to selected 2.3
