root/radiance/ray/src/rt/pmapsrc.h
Revision: 2.5
Committed: Tue May 17 17:39:47 2016 UTC (8 years, 11 months ago) by rschregle
1 /* RCSid $Id: pmapsrc.h,v 2.3 2015/08/18 18:45:55 greg Exp $ */
2
3 /*
4 ==================================================================
5 Photon map support routines for emission from light sources
6
7 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
8 (c) Fraunhofer Institute for Solar Energy Systems,
9 (c) Lucerne University of Applied Sciences and Arts,
10 supported by the Swiss National Science Foundation (SNSF, #147053)
11 ==================================================================
12
13 $Id: pmapsrc.h,v 2.2 2015/05/08 13:20:23 rschregle Exp $
14 */
15
16
17
18 #ifndef PMAPSRC_H
19 #define PMAPSRC_H
20
21 #include "ray.h"
22 #include "source.h"
23
24
25
26 /* Data structures for photon emission */
27 typedef struct {
28 unsigned theta, phi; /* Direction indices */
29 COLOR pdf; /* Probability of emission in this
30 direction per RGB */
31 float cdf; /* Cumulative probability up to
32 this sample */
33 } EmissionSample;
34
35 typedef struct {
36 unsigned numTheta, numPhi; /* Num divisions in theta & phi */
37 RREAL cosThetaMax; /* cos(source aperture) */
38 FVECT uh, vh, wh; /* Emission aperture axes at origin,
39 w is normal*/
40 FVECT us, vs, ws; /* Source surface axes at origin,
41 w is normal */
42 FVECT photonOrg; /* Current photon origin */
43 EmissionSample *samples; /* PDF samples for photon emission
44 directions */
45 unsigned long numPartitions; /* Number of surface partitions */
46 RREAL partArea; /* Area covered by each partition */
47 SRCREC *src, *port; /* Current source and port */
48 unsigned long partitionCnt, /* Current surface partition */
49 maxPartitions, /* Max allocated partitions */
50 numSamples; /* Number of PDF samples */
51 unsigned char* partitions; /* Source surface partitions */
52 COLOR partFlux; /* Total flux emitted by partition */
53 float cdf; /* Cumulative probability */
54 } EmissionMap;
55
56
57
58 /* Photon port list for emission from geometry en lieu of light sources */
59 extern SRCREC *photonPorts;
60 extern unsigned numPhotonPorts;
61
62 /* Dispatch tables for partitioning light source surfaces and generating
63 an origin for photon emission */
64 extern void (*photonPartition []) (EmissionMap*);
65 extern void (*photonOrigin []) (EmissionMap*);
66
67
68
69 void getPhotonPorts ();
70 /* Find geometry declared as photon ports */
71
72 void initPhotonEmissionFuncs ();
73 /* Init photonPartition[] and photonOrigin[] dispatch tables with source
74 specific emission routines */
75
76 void initPhotonEmission (EmissionMap *emap, float numPdfSamples);
77 /* Initialize photon emission from partitioned light source emap -> src;
78 * this involves integrating the flux emitted from the current photon
79 * origin emap -> photonOrg and setting up a PDF to sample the emission
80 * distribution with numPdfSamples samples */
81
82 void emitPhoton (const EmissionMap*, RAY* ray);
83 /* Emit photon from current source partition based on emission
84 distribution and return new photon ray */
85
86 void multDirectPmap (RAY *r);
87 /* Factor irradiance from direct photons into r -> rcol; interface to
88 * direct() */
89
90 void inscatterVolumePmap (RAY *r, COLOR inscatter);
91 /* Add inscattering from volume photon map; interface to srcscatter() */
92
93 #endif
