root/Development/ray/src/rt/pmapsrc.h
Revision: 2.8
Committed: Tue Sep 17 16:36:05 2024 UTC (13 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.7: +9 -2 lines
chore: Added extern "C" to headers to avoid C++ name mangling
1 /* RCSid $Id: pmapsrc.h,v 2.7 2020/08/07 01:21:13 rschregle Exp $ */
2
3 /*
4 ======================================================================
5 Photon map support routines for emission from light sources
6
7 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
8 (c) Fraunhofer Institute for Solar Energy Systems,
9 supported by the German Research Foundation (DFG)
10 under the FARESYS project.
11 (c) Lucerne University of Applied Sciences and Arts,
12 supported by the Swiss National Science Foundation (SNSF #147053).
13 (c) Tokyo University of Science,
14 supported by the JSPS KAKENHI Grant Number JP19KK0115.
15 ======================================================================
16
17 $Id: pmapsrc.h,v 2.7 2020/08/07 01:21:13 rschregle Exp $
18 */
19
20
21
22 #ifndef PMAPSRC_H
23 #define PMAPSRC_H
24
25 #include "ray.h"
26 #include "source.h"
27
28 #ifdef __cplusplus
29 extern "C" {
30 #endif
31
32
33 /* Data structures for photon emission */
34 typedef struct {
35 unsigned theta, phi; /* Direction indices */
36 COLOR pdf; /* Probability of emission in this
37 direction per RGB */
38 float cdf; /* Cumulative probability up to
39 this sample */
40 } EmissionSample;
41
42 typedef struct {
43 unsigned numTheta, numPhi; /* Num divisions in theta & phi */
44 RREAL cosThetaMax; /* cos(source aperture) */
45 FVECT uh, vh, wh; /* Emission aperture axes at origin,
46 w is normal*/
47 FVECT us, vs, ws; /* Source surface axes at origin,
48 w is normal */
49 FVECT photonOrg; /* Current photon origin */
50 EmissionSample *samples; /* PDF samples for photon emission
51 directions */
52 unsigned long numPartitions; /* Number of surface partitions */
53 RREAL partArea; /* Area covered by each partition */
54 SRCREC *src, *port; /* Current source and port */
55 unsigned long partitionCnt, /* Current surface partition */
56 maxPartitions, /* Max allocated partitions */
57 numSamples; /* Number of PDF samples */
58 unsigned char* partitions; /* Source surface partitions */
59 COLOR partFlux; /* Total flux emitted by partition */
60 float cdf; /* Cumulative probability */
61 } EmissionMap;
62
63
64
65 /* Photon port flags (orientation relative to surface normal):
66 * Forward, backward, both (bidirectional). */
67 #define PMAP_PORTFWD 1
68 #define PMAP_PORTBWD 2
69 #define PMAP_PORTBI (PMAP_PORTFWD | PMAP_PORTBWD)
70
71
72 /* Photon ports for emission from geometry en lieu of light sources */
73 extern char *photonPortList [MAXSET + 1];
74 extern SRCREC *photonPorts;
75 extern unsigned numPhotonPorts;
76
77 /* Dispatch tables for partitioning light source surfaces and generating
78 an origin for photon emission */
79 extern void (*photonPartition []) (EmissionMap*);
80 extern void (*photonOrigin []) (EmissionMap*);
81
82
83
84 void getPhotonPorts (char **portList);
85 /* Find geometry declared as photon ports from modifiers in portList */
86
87 void initPhotonEmissionFuncs ();
88 /* Init photonPartition[] and photonOrigin[] dispatch tables with source
89 specific emission routines */
90
91 void initPhotonEmission (EmissionMap *emap, float numPdfSamples);
92 /* Initialize photon emission from partitioned light source emap -> src;
93 * this involves integrating the flux emitted from the current photon
94 * origin emap -> photonOrg and setting up a PDF to sample the emission
95 * distribution with numPdfSamples samples */
96
97 void emitPhoton (const EmissionMap*, RAY* ray);
98 /* Emit photon from current source partition based on emission
99 distribution and return new photon ray */
100
101 void multDirectPmap (RAY *r);
102 /* Factor irradiance from direct photons into r -> rcol; interface to
103 * direct() */
104
105 void inscatterVolumePmap (RAY *r, COLOR inscatter);
106 /* Add inscattering from volume photon map; interface to srcscatter() */
107
108 #ifdef __cplusplus
109 }
110 #endif
111
112 #endif
