root/radiance/ray/src/rt/pmapsrc.h
Revision: 2.1
Committed: Tue Feb 24 19:39:27 2015 UTC (10 years, 2 months ago) by greg
1 /*
2 ==================================================================
3 Photon map support routines for emission from light sources
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Fraunhofer Institute for Solar Energy Systems,
7 Lucerne University of Applied Sciences & Arts
8 ==================================================================
9
10 $Id: pmapsrc.h,v 1.5 2014/12/03 15:06:10 taschreg Exp taschreg $
11 */
12
13
14
15 #ifndef PMAPSRC_H
16 #define PMAPSRC_H
17
18 #include "ray.h"
19 #include "source.h"
20
21
22
23 /* Data structures for photon emission */
24 typedef struct {
25 unsigned theta, phi; /* Direction indices */
26 COLOR pdf; /* Probability of emission in this
27 direction per RGB */
28 float cdf; /* Cumulative probability up to
29 this sample */
30 } EmissionSample;
31
32 typedef struct {
33 unsigned numTheta, numPhi; /* Num divisions in theta & phi */
34 RREAL cosThetaMax; /* cos(source aperture) */
35 FVECT uh, vh, wh; /* Emission aperture axes at origin,
36 w is normal*/
37 FVECT us, vs, ws; /* Source surface axes at origin,
38 w is normal */
39 FVECT photonOrg; /* Current photon origin */
40 EmissionSample *samples; /* PDF samples for photon emission
41 directions */
42 unsigned long numPartitions; /* Number of surface partitions */
43 RREAL partArea; /* Area covered by each partition */
44 SRCREC *src, *port; /* Current source and port */
45 unsigned long partitionCnt, /* Current surface partition */
46 maxPartitions, /* Max allocated partitions */
47 numSamples; /* Number of PDF samples */
48 unsigned char* partitions; /* Source surface partitions */
49 COLOR partFlux; /* Total flux emitted by partition */
50 float cdf; /* Cumulative probability */
51 } EmissionMap;
52
53
54
55 /* Photon port list for emission from geometry en lieu of light sources */
56 extern SRCREC *photonPorts;
57 extern unsigned numPhotonPorts;
58
59 /* Dispatch tables for partitioning light source surfaces and generating
60 an origin for photon emission */
61 extern void (*photonPartition []) (EmissionMap*);
62 extern void (*photonOrigin []) (EmissionMap*);
63
64
65
66 void getPhotonPorts ();
67 /* Find geometry declared as photon ports */
68
69 void initPhotonEmissionFuncs ();
70 /* Init photonPartition[] and photonOrigin[] dispatch tables with source
71 specific emission routines */
72
73 void initPhotonEmission (EmissionMap *emap, float numPdfSamples);
74 /* Initialize photon emission from partitioned light source emap -> src;
75 * this involves integrating the flux emitted from the current photon
76 * origin emap -> photonOrg and setting up a PDF to sample the emission
77 * distribution with numPdfSamples samples */
78
79 void emitPhoton (const EmissionMap*, RAY* ray);
80 /* Emit photon from current source partition based on emission
81 distribution and return new photon ray */
82
83 void multDirectPmap (RAY *r);
84 /* Factor irradiance from direct photons into r -> rcol; interface to
85 * direct() */
86
87 void inscatterVolumePmap (RAY *r, COLOR inscatter);
88 /* Add inscattering from volume photon map; interface to srcscatter() */
89
90 #endif
