root/Development/ray/src/rt/pmapsrc.h
Tue Sep 17 16:36:05 2024 UTC (13 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.7: +9 -2 lines
chore: Added extern "C" to headers to avoid C++ name mangling
Fri Aug 7 01:21:13 2020 UTC (5 years, 3 months ago) by rschregle
CVS Tags: rad5R3, rad5R4
Changes since 2.6: +16 -5 lines
feat(mkpmap): Extended -apo option to reorient photon ports.
Tue Mar 20 19:55:33 2018 UTC (7 years, 7 months ago) by rschregle
Added -ae/-ai ambient exclude options to mkpmap, cleaned up opt parsing.
Tue May 17 17:39:47 2016 UTC (9 years, 5 months ago) by rschregle
Tue Sep 1 16:27:53 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.3: +1 -2 lines
Tue Aug 18 18:45:55 2015 UTC (10 years, 2 months ago) by greg
Fri May 8 13:20:23 2015 UTC (10 years, 6 months ago) by rschregle
Diff to previous 2.1
Tue Feb 24 19:39:27 2015 UTC (10 years, 8 months ago) by greg
