root/radiance/ray/src/rt/pmapsrc.h
Revision: 2.7
Committed: Fri Aug 7 01:21:13 2020 UTC (4 years, 9 months ago) by rschregle
CVS Tags: rad5R4, rad5R3
Changes since 2.6: +16 -5 lines
feat(mkpmap): Extended -apo option to reorient photon ports.
1 /* RCSid $Id: pmapsrc.h,v 2.6 2018/03/20 19:55:33 rschregle Exp $ */
2
3 /*
4 ======================================================================
5 Photon map support routines for emission from light sources
6
7 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
8 (c) Fraunhofer Institute for Solar Energy Systems,
9 supported by the German Research Foundation (DFG)
10 under the FARESYS project.
11 (c) Lucerne University of Applied Sciences and Arts,
12 supported by the Swiss National Science Foundation (SNSF #147053).
13 (c) Tokyo University of Science,
14 supported by the JSPS KAKENHI Grant Number JP19KK0115.
15 ======================================================================
16
17 $Id: pmapsrc.h,v 2.6 2018/03/20 19:55:33 rschregle Exp $
18 */
19
20
21
22 #ifndef PMAPSRC_H
23 #define PMAPSRC_H
24
25 #include "ray.h"
26 #include "source.h"
27
28
29
30 /* Data structures for photon emission */
31 typedef struct {
32 unsigned theta, phi; /* Direction indices */
33 COLOR pdf; /* Probability of emission in this
34 direction per RGB */
35 float cdf; /* Cumulative probability up to
36 this sample */
37 } EmissionSample;
38
39 typedef struct {
40 unsigned numTheta, numPhi; /* Num divisions in theta & phi */
41 RREAL cosThetaMax; /* cos(source aperture) */
42 FVECT uh, vh, wh; /* Emission aperture axes at origin,
43 w is normal*/
44 FVECT us, vs, ws; /* Source surface axes at origin,
45 w is normal */
46 FVECT photonOrg; /* Current photon origin */
47 EmissionSample *samples; /* PDF samples for photon emission
48 directions */
49 unsigned long numPartitions; /* Number of surface partitions */
50 RREAL partArea; /* Area covered by each partition */
51 SRCREC *src, *port; /* Current source and port */
52 unsigned long partitionCnt, /* Current surface partition */
53 maxPartitions, /* Max allocated partitions */
54 numSamples; /* Number of PDF samples */
55 unsigned char* partitions; /* Source surface partitions */
56 COLOR partFlux; /* Total flux emitted by partition */
57 float cdf; /* Cumulative probability */
58 } EmissionMap;
59
60
61
62 /* Photon port flags (orientation relative to surface normal):
63 * Forward, backward, both (bidirectional). */
64 #define PMAP_PORTFWD 1
65 #define PMAP_PORTBWD 2
66 #define PMAP_PORTBI (PMAP_PORTFWD | PMAP_PORTBWD)
67
68
69 /* Photon ports for emission from geometry en lieu of light sources */
70 extern char *photonPortList [MAXSET + 1];
71 extern SRCREC *photonPorts;
72 extern unsigned numPhotonPorts;
73
74 /* Dispatch tables for partitioning light source surfaces and generating
75 an origin for photon emission */
76 extern void (*photonPartition []) (EmissionMap*);
77 extern void (*photonOrigin []) (EmissionMap*);
78
79
80
81 void getPhotonPorts (char **portList);
82 /* Find geometry declared as photon ports from modifiers in portList */
83
84 void initPhotonEmissionFuncs ();
85 /* Init photonPartition[] and photonOrigin[] dispatch tables with source
86 specific emission routines */
87
88 void initPhotonEmission (EmissionMap *emap, float numPdfSamples);
89 /* Initialize photon emission from partitioned light source emap -> src;
90 * this involves integrating the flux emitted from the current photon
91 * origin emap -> photonOrg and setting up a PDF to sample the emission
92 * distribution with numPdfSamples samples */
93
94 void emitPhoton (const EmissionMap*, RAY* ray);
95 /* Emit photon from current source partition based on emission
96 distribution and return new photon ray */
97
98 void multDirectPmap (RAY *r);
99 /* Factor irradiance from direct photons into r -> rcol; interface to
100 * direct() */
101
102 void inscatterVolumePmap (RAY *r, COLOR inscatter);
103 /* Add inscattering from volume photon map; interface to srcscatter() */
104
105 #endif
