root/radiance/ray/src/rt/pmapsrc.c
Revision: 2.3
Committed: Fri May 8 13:20:23 2015 UTC (10 years ago) by rschregle
1 /*
2 ==================================================================
3 Photon map support routines for emission from light sources
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Fraunhofer Institute for Solar Energy Systems,
7 (c) Lucerne University of Applied Sciences and Arts,
8 supported by the Swiss National Science Foundation (SNSF, #147053)
9 ==================================================================
10
11 $Id: pmapsrc.c,v 2.2 2015/04/21 19:16:51 greg Exp $
12 */
13
14
15
16 #include "pmapsrc.h"
17 #include "pmap.h"
18 #include "pmaprand.h"
19 #include "otypes.h"
20
21
22
23 SRCREC *photonPorts = NULL; /* Photon port list */
24 unsigned numPhotonPorts = 0;
25
26 void (*photonPartition [NUMOTYPE]) (EmissionMap*);
27 void (*photonOrigin [NUMOTYPE]) (EmissionMap*);
28
29 extern OBJECT ambset [];
30
31
32
33 static int flatPhotonPartition2 (EmissionMap* emap, unsigned long mp,
34 FVECT cent, FVECT u, FVECT v,
35 double du2, double dv2)
36 /* Recursive part of flatPhotonPartition(..) */
37 {
38 FVECT newct, newax;
39 unsigned long npl, npu;
40
41 if (mp > emap -> maxPartitions) {
42 /* Enlarge partition array */
43 emap -> maxPartitions <<= 1;
44 emap -> partitions = (unsigned char*)realloc(emap -> partitions,
45 emap -> maxPartitions >> 1);
46
47 if (!emap -> partitions)
48 error(USER, "can't allocate source partitions");
49
50 memset(emap -> partitions + (emap -> maxPartitions >> 2), 0,
51 emap -> maxPartitions >> 2);
52 }
53
54 if (du2 * dv2 <= 1) { /* hit limit? */
55 setpart(emap -> partitions, emap -> partitionCnt, S0);
56 emap -> partitionCnt++;
57 return 1;
58 }
59
60 if (du2 > dv2) { /* subdivide in U */
61 setpart(emap -> partitions, emap -> partitionCnt, SU);
62 emap -> partitionCnt++;
63 newax [0] = 0.5 * u [0];
64 newax [1] = 0.5 * u [1];
65 newax [2] = 0.5 * u [2];
66 u = newax;
67 du2 *= 0.25;
68 }
69
70 else { /* subdivide in V */
71 setpart(emap -> partitions, emap -> partitionCnt, SV);
72 emap -> partitionCnt++;
73 newax [0] = 0.5 * v [0];
74 newax [1] = 0.5 * v [1];
75 newax [2] = 0.5 * v [2];
76 v = newax;
77 dv2 *= 0.25;
78 }
79
80 /* lower half */
81 newct [0] = cent [0] - newax [0];
82 newct [1] = cent [1] - newax [1];
83 newct [2] = cent [2] - newax [2];
84 npl = flatPhotonPartition2(emap, mp << 1, newct, u, v, du2, dv2);
85
86 /* upper half */
87 newct [0] = cent [0] + newax [0];
88 newct [1] = cent [1] + newax [1];
89 newct [2] = cent [2] + newax [2];
90 npu = flatPhotonPartition2(emap, mp << 1, newct, u, v, du2, dv2);
91
92 /* return total */
93 return npl + npu;
94 }
95
96
97
98 static void flatPhotonPartition (EmissionMap* emap)
99 /* Partition flat source for photon emission */
100 {
101 RREAL *vp;
102 double du2, dv2;
103
104 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
105 emap -> partArea = srcsizerat * thescene.cusize;
106 emap -> partArea *= emap -> partArea;
107 vp = emap -> src -> ss [SU];
108 du2 = DOT(vp, vp) / emap -> partArea;
109 vp = emap -> src -> ss [SV];
110 dv2 = DOT(vp, vp) / emap -> partArea;
111 emap -> partitionCnt = 0;
112 emap -> numPartitions = flatPhotonPartition2(emap, 1, emap -> src -> sloc,
113 emap -> src -> ss [SU],
114 emap -> src -> ss [SV],
115 du2, dv2);
116 emap -> partitionCnt = 0;
117 emap -> partArea = emap -> src -> ss2 / emap -> numPartitions;
118 }
119
120
121
122 static void sourcePhotonPartition (EmissionMap* emap)
123 /* Partition scene cube faces or photon port for photon emission from
124 distant source */
125 {
126 if (emap -> port) {
127 /* Partition photon port */
128 SRCREC *src = emap -> src;
129 emap -> src = emap -> port;
130 photonPartition [emap -> src -> so -> otype] (emap);
131 emap -> src = src;
132 }
133
134 else {
135 /* No photon ports defined, so partition scene cube faces */
136 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
137 setpart(emap -> partitions, 0, S0);
138 emap -> partitionCnt = 0;
139 emap -> numPartitions = 1 / srcsizerat;
140 emap -> numPartitions *= emap -> numPartitions;
141 emap -> partArea = sqr(thescene.cusize) / emap -> numPartitions;
142 emap -> numPartitions *= 6;
143 }
144 }
145
146
147
148 static void spherePhotonPartition (EmissionMap* emap)
149 /* Partition spherical source into equal solid angles using uniform
150 mapping for photon emission */
151 {
152 unsigned numTheta, numPhi;
153
154 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
155 setpart(emap -> partitions, 0, S0);
156 emap -> partArea = 4 * PI * sqr(emap -> src -> srad);
157 emap -> numPartitions = emap -> partArea /
158 sqr(srcsizerat * thescene.cusize);
159
160 numTheta = max(sqrt(2 * emap -> numPartitions / PI) + 0.5, 1);
161 numPhi = 0.5 * PI * numTheta + 0.5;
162
163 emap -> numPartitions = (unsigned long)numTheta * numPhi;
164 emap -> partitionCnt = 0;
165 emap -> partArea /= emap -> numPartitions;
166 }
167
168
169
170 static int cylPhotonPartition2 (EmissionMap* emap, unsigned long mp,
171 FVECT cent, FVECT axis, double d2)
172 /* Recursive part of cyPhotonPartition(..) */
173 {
174 FVECT newct, newax;
175 unsigned long npl, npu;
176
177 if (mp > emap -> maxPartitions) {
178 /* Enlarge partition array */
179 emap -> maxPartitions <<= 1;
180 emap -> partitions = (unsigned char*)realloc(emap -> partitions,
181 emap -> maxPartitions >> 1);
182 if (!emap -> partitions)
183 error(USER, "can't allocate source partitions");
184
185 memset(emap -> partitions + (emap -> maxPartitions >> 2), 0,
186 emap -> maxPartitions >> 2);
187 }
188
189 if (d2 <= 1) {
190 /* hit limit? */
191 setpart(emap -> partitions, emap -> partitionCnt, S0);
192 emap -> partitionCnt++;
193 return 1;
194 }
195
196 /* subdivide */
197 setpart(emap -> partitions, emap -> partitionCnt, SU);
198 emap -> partitionCnt++;
199 newax [0] = 0.5 * axis [0];
200 newax [1] = 0.5 * axis [1];
201 newax [2] = 0.5 * axis [2];
202 d2 *= 0.25;
203
204 /* lower half */
205 newct [0] = cent [0] - newax [0];
206 newct [1] = cent [1] - newax [1];
207 newct [2] = cent [2] - newax [2];
208 npl = cylPhotonPartition2(emap, mp << 1, newct, newax, d2);
209
210 /* upper half */
211 newct [0] = cent [0] + newax [0];
212 newct [1] = cent [1] + newax [1];
213 newct [2] = cent [2] + newax [2];
214 npu = cylPhotonPartition2(emap, mp << 1, newct, newax, d2);
215
216 /* return total */
217 return npl + npu;
218 }
219
220
221
222 static void cylPhotonPartition (EmissionMap* emap)
223 /* Partition cylindrical source for photon emission */
224 {
225 double d2;
226
227 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
228 d2 = srcsizerat * thescene.cusize;
229 d2 = PI * emap -> src -> ss2 / (2 * emap -> src -> srad * sqr(d2));
230 d2 *= d2 * DOT(emap -> src -> ss [SU], emap -> src -> ss [SU]);
231
232 emap -> partitionCnt = 0;
233 emap -> numPartitions = cylPhotonPartition2(emap, 1, emap -> src -> sloc,
234 emap -> src -> ss [SU], d2);
235 emap -> partitionCnt = 0;
236 emap -> partArea = PI * emap -> src -> ss2 / emap -> numPartitions;
237 }
238
239
240
241 static void flatPhotonOrigin (EmissionMap* emap)
242 /* Init emission map with photon origin and associated surface axes on
243 flat light source surface. Also sets source aperture and sampling
244 hemisphere axes at origin */
245 {
246 int i, cent[3], size[3], parr[2];
247 FVECT vpos;
248
249 cent [0] = cent [1] = cent [2] = 0;
250 size [0] = size [1] = size [2] = emap -> maxPartitions;
251 parr [0] = 0;
252 parr [1] = emap -> partitionCnt;
253
254 if (!skipparts(cent, size, parr, emap -> partitions))
255 error(CONSISTENCY, "bad source partition in flatPhotonOrigin");
256
257 vpos [0] = (1 - 2 * pmapRandom(partState)) * size [0] /
258 emap -> maxPartitions;
259 vpos [1] = (1 - 2 * pmapRandom(partState)) * size [1] /
260 emap -> maxPartitions;
261 vpos [2] = 0;
262
263 for (i = 0; i < 3; i++)
264 vpos [i] += (double)cent [i] / emap -> maxPartitions;
265
266 /* Get origin */
267 for (i = 0; i < 3; i++)
268 emap -> photonOrg [i] = emap -> src -> sloc [i] +
269 vpos [SU] * emap -> src -> ss [SU][i] +
270 vpos [SV] * emap -> src -> ss [SV][i] +
271 vpos [SW] * emap -> src -> ss [SW][i];
272
273 /* Get surface axes */
274 VCOPY(emap -> us, emap -> src -> ss [SU]);
275 normalize(emap -> us);
276 VCOPY(emap -> ws, emap -> src -> ss [SW]);
277
278 if (emap -> port)
279 /* Acts as a photon port; reverse normal as it points INSIDE per
280 * mkillum convention */
281 for (i = 0; i < 3; i++)
282 emap -> ws [i] = -emap -> ws [i];
283
284 fcross(emap -> vs, emap -> ws, emap -> us);
285
286 /* Get hemisphere axes & aperture */
287 if (emap -> src -> sflags & SSPOT) {
288 VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
289 i = 0;
290
291 do {
292 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
293 emap -> vh [i++] = 1;
294 fcross(emap -> uh, emap -> vh, emap -> wh);
295 } while (normalize(emap -> uh) < FTINY);
296
297 fcross(emap -> vh, emap -> wh, emap -> uh);
298 emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
299 }
300
301 else {
302 VCOPY(emap -> uh, emap -> us);
303 VCOPY(emap -> vh, emap -> vs);
304 VCOPY(emap -> wh, emap -> ws);
305 emap -> cosThetaMax = 0;
306 }
307 }
308
309
310
311 static void spherePhotonOrigin (EmissionMap* emap)
312 /* Init emission map with photon origin and associated surface axes on
313 spherical light source. Also sets source aperture and sampling
314 hemisphere axes at origin */
315 {
316 int i = 0;
317 unsigned numTheta, numPhi, t, p;
318 RREAL cosTheta, sinTheta, phi;
319
320 /* Get current partition */
321 numTheta = max(sqrt(2 * emap -> numPartitions / PI) + 0.5, 1);
322 numPhi = 0.5 * PI * numTheta + 0.5;
323
324 t = emap -> partitionCnt / numPhi;
325 p = emap -> partitionCnt - t * numPhi;
326
327 emap -> ws [2] = cosTheta = 1 - 2 * (t + pmapRandom(partState)) / numTheta;
328 sinTheta = sqrt(1 - sqr(cosTheta));
329 phi = 2 * PI * (p + pmapRandom(partState)) / numPhi;
330 emap -> ws [0] = cos(phi) * sinTheta;
331 emap -> ws [1] = sin(phi) * sinTheta;
332
333 if (emap -> port)
334 /* Acts as a photon port; reverse normal as it points INSIDE per
335 * mkillum convention */
336 for (i = 0; i < 3; i++)
337 emap -> ws [i] = -emap -> ws [i];
338
339 /* Get surface axes us & vs perpendicular to ws */
340 do {
341 emap -> vs [0] = emap -> vs [1] = emap -> vs [2] = 0;
342 emap -> vs [i++] = 1;
343 fcross(emap -> us, emap -> vs, emap -> ws);
344 } while (normalize(emap -> us) < FTINY);
345
346 fcross(emap -> vs, emap -> ws, emap -> us);
347
348 /* Get origin */
349 for (i = 0; i < 3; i++)
350 emap -> photonOrg [i] = emap -> src -> sloc [i] +
351 emap -> src -> srad * emap -> ws [i];
352
353 /* Get hemisphere axes & aperture */
354 if (emap -> src -> sflags & SSPOT) {
355 VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
356 i = 0;
357
358 do {
359 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
360 emap -> vh [i++] = 1;
361 fcross(emap -> uh, emap -> vh, emap -> wh);
362 } while (normalize(emap -> uh) < FTINY);
363
364 fcross(emap -> vh, emap -> wh, emap -> uh);
365 emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
366 }
367
368 else {
369 VCOPY(emap -> uh, emap -> us);
370 VCOPY(emap -> vh, emap -> vs);
371 VCOPY(emap -> wh, emap -> ws);
372 emap -> cosThetaMax = 0;
373 }
374 }
375
376
377
378 static void sourcePhotonOrigin (EmissionMap* emap)
379 /* Init emission map with photon origin and associated surface axes
380 on scene cube face for distant light source. Also sets source
381 aperture (solid angle) and sampling hemisphere axes at origin */
382 {
383 unsigned long i, partsPerDim, partsPerFace;
384 unsigned face;
385 RREAL du, dv;
386
387 if (emap -> port) {
388 /* Get origin on photon port */
389 SRCREC *src = emap -> src;
390 emap -> src = emap -> port;
391 photonOrigin [emap -> src -> so -> otype] (emap);
392 emap -> src = src;
393 }
394
395 else {
396 /* No ports defined, so get origin on scene cube face and SUFFA! */
397 /* Get current face from partition number */
398 partsPerDim = 1 / srcsizerat;
399 partsPerFace = sqr(partsPerDim);
400 face = emap -> partitionCnt / partsPerFace;
401
402 if (!(emap -> partitionCnt % partsPerFace)) {
403 /* Skipped to a new face; get its normal */
404 emap -> ws [0] = emap -> ws [1] = emap -> ws [2] = 0;
405 emap -> ws [face >> 1] = face & 1 ? 1 : -1;
406
407 /* Get surface axes us & vs perpendicular to ws */
408 face >>= 1;
409 emap -> vs [0] = emap -> vs [1] = emap -> vs [2] = 0;
410 emap -> vs [(face + (emap -> ws [face] > 0 ? 2 : 1)) % 3] = 1;
411 fcross(emap -> us, emap -> vs, emap -> ws);
412 }
413
414 /* Get jittered offsets within face from partition number
415 (in range [-0.5, 0.5]) */
416 i = emap -> partitionCnt % partsPerFace;
417 du = (i / partsPerDim + pmapRandom(partState)) / partsPerDim - 0.5;
418 dv = (i % partsPerDim + pmapRandom(partState)) / partsPerDim - 0.5;
419
420 /* Jittered destination point within partition */
421 for (i = 0; i < 3; i++)
422 emap -> photonOrg [i] = thescene.cuorg [i] +
423 thescene.cusize * (0.5 + du * emap -> us [i] +
424 dv * emap -> vs [i] +
425 0.5 * emap -> ws [i]);
426 }
427
428 /* Get hemisphere axes & aperture */
429 VCOPY(emap -> wh, emap -> src -> sloc);
430 i = 0;
431
432 do {
433 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
434 emap -> vh [i++] = 1;
435 fcross(emap -> uh, emap -> vh, emap -> wh);
436 } while (normalize(emap -> uh) < FTINY);
437
438 fcross(emap -> vh, emap -> wh, emap -> uh);
439
440 /* Get aperture */
441 emap -> cosThetaMax = 1 - emap -> src -> ss2 / (2 * PI);
442 emap -> cosThetaMax = min(1, max(-1, emap -> cosThetaMax));
443 }
444
445
446
447 static void cylPhotonOrigin (EmissionMap* emap)
448 /* Init emission map with photon origin and associated surface axes
449 on cylindrical light source surface. Also sets source aperture
450 and sampling hemisphere axes at origin */
451 {
452 int i, cent[3], size[3], parr[2];
453 FVECT v;
454
455 cent [0] = cent [1] = cent [2] = 0;
456 size [0] = size [1] = size [2] = emap -> maxPartitions;
457 parr [0] = 0;
458 parr [1] = emap -> partitionCnt;
459
460 if (!skipparts(cent, size, parr, emap -> partitions))
461 error(CONSISTENCY, "bad source partition in cylPhotonOrigin");
462
463 v [SU] = 0;
464 v [SV] = (1 - 2 * pmapRandom(partState)) * (double)size [1] /
465 emap -> maxPartitions;
466 v [SW] = (1 - 2 * pmapRandom(partState)) * (double)size [2] /
467 emap -> maxPartitions;
468 normalize(v);
469 v [SU] = (1 - 2 * pmapRandom(partState)) * (double)size [1] /
470 emap -> maxPartitions;
471
472 for (i = 0; i < 3; i++)
473 v [i] += (double)cent [i] / emap -> maxPartitions;
474
475 /* Get surface axes */
476 for (i = 0; i < 3; i++)
477 emap -> photonOrg [i] = emap -> ws [i] =
478 (v [SV] * emap -> src -> ss [SV][i] +
479 v [SW] * emap -> src -> ss [SW][i]) / 0.8559;
480
481 if (emap -> port)
482 /* Acts as a photon port; reverse normal as it points INSIDE per
483 * mkillum convention */
484 for (i = 0; i < 3; i++)
485 emap -> ws [i] = -emap -> ws [i];
486
487 normalize(emap -> ws);
488 VCOPY(emap -> us, emap -> src -> ss [SU]);
489 normalize(emap -> us);
490 fcross(emap -> vs, emap -> ws, emap -> us);
491
492 /* Get origin */
493 for (i = 0; i < 3; i++)
494 emap -> photonOrg [i] += v [SU] * emap -> src -> ss [SU][i] +
495 emap -> src -> sloc [i];
496
497 /* Get hemisphere axes & aperture */
498 if (emap -> src -> sflags & SSPOT) {
499 VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
500 i = 0;
501
502 do {
503 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
504 emap -> vh [i++] = 1;
505 fcross(emap -> uh, emap -> vh, emap -> wh);
506 } while (normalize(emap -> uh) < FTINY);
507
508 fcross(emap -> vh, emap -> wh, emap -> uh);
509 emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
510 }
511
512 else {
513 VCOPY(emap -> uh, emap -> us);
514 VCOPY(emap -> vh, emap -> vs);
515 VCOPY(emap -> wh, emap -> ws);
516 emap -> cosThetaMax = 0;
517 }
518 }
519
520
521
522 void getPhotonPorts ()
523 /* Find geometry declared as photon ports */
524 {
525 OBJECT i;
526 OBJREC* obj;
527
528 /* Check for missing port modifiers */
529 if (!ambset [0])
530 error(USER, "no photon ports found");
531
532 for (i = 0; i < nobjects; i++) {
533 obj = objptr(i);
534
535 if (inset(ambset, obj -> omod)) {
536 /* Add photon port */
537 photonPorts = (SRCREC*)realloc(photonPorts,
538 (numPhotonPorts + 1) *
539 sizeof(SRCREC));
540 if (!photonPorts)
541 error(USER, "can't allocate photon ports");
542
543 photonPorts [numPhotonPorts].so = obj;
544 photonPorts [numPhotonPorts].sflags = 0;
545
546 if (!sfun [obj -> otype].of || !sfun[obj -> otype].of -> setsrc)
547 objerror(obj, USER, "illegal photon port");
548
549 setsource(photonPorts + numPhotonPorts, obj);
550 numPhotonPorts++;
551 }
552 }
553 }
554
555
556
557 static void defaultEmissionFunc (EmissionMap* emap)
558 /* Default behaviour when no emission funcs defined for this source type */
559 {
560 objerror(emap -> src -> so, INTERNAL,
561 "undefined photon emission function");
562 }
563
564
565
566 void initPhotonEmissionFuncs ()
567 /* Init photonPartition[] and photonOrigin[] dispatch tables */
568 {
569 int i;
570
571 for (i = 0; i < NUMOTYPE; i++)
572 photonPartition [i] = photonOrigin [i] = defaultEmissionFunc;
573
574 photonPartition [OBJ_FACE] = photonPartition [OBJ_RING] = flatPhotonPartition;
575 photonPartition [OBJ_SOURCE] = sourcePhotonPartition;
576 photonPartition [OBJ_SPHERE] = spherePhotonPartition;
577 photonPartition [OBJ_CYLINDER] = cylPhotonPartition;
578 photonOrigin [OBJ_FACE] = photonOrigin [OBJ_RING] = flatPhotonOrigin;
579 photonOrigin [OBJ_SOURCE] = sourcePhotonOrigin;
580 photonOrigin [OBJ_SPHERE] = spherePhotonOrigin;
581 photonOrigin [OBJ_CYLINDER] = cylPhotonOrigin;
582 }
583
584
585
586 void initPhotonEmission (EmissionMap *emap, float numPdfSamples)
587 /* Initialize photon emission from partitioned light source emap -> src;
588 * this involves integrating the flux emitted from the current photon
589 * origin emap -> photonOrg and setting up a PDF to sample the emission
590 * distribution with numPdfSamples samples */
591 {
592 unsigned i, t, p;
593 double phi, cosTheta, sinTheta, du, dv, dOmega, thetaScale;
594 EmissionSample* sample;
595 const OBJREC* mod = objptr(emap -> src -> so -> omod);
596 static RAY r;
597 #if 0
598 static double lastCosNorm = FHUGE;
599 static SRCREC *lastSrc = NULL, *lastPort = NULL;
600 #endif
601
602 photonOrigin [emap -> src -> so -> otype] (emap);
603 cosTheta = DOT(emap -> ws, emap -> wh);
604
605 #if 0
606 if (emap -> src == lastSrc && emap -> port == lastPort &&
607 (emap -> src -> sflags & SDISTANT || mod -> omod == OVOID) &&
608 cosTheta == lastCosNorm)
609 /* Same source, port, and aperture-normal angle, and source is
610 either distant (and thus translationally invariant) or has
611 no modifier --> flux unchanged */
612 /* BUG: this optimisation ignores partial occlusion of ports and
613 can lead to erroneous "zero emission" bailouts.
614 It can also lead to bias with modifiers exhibiting high variance!
615 Disabled for now -- RS 12/13 */
616 return;
617
618 lastSrc = emap -> src;
619 lastPort = emap -> port;
620 lastCosNorm = cosTheta;
621 #endif
622
623 /* Need to recompute flux & PDF */
624 setcolor(emap -> partFlux, 0, 0, 0);
625 emap -> cdf = 0;
626 emap -> numSamples = 0;
627
628 if (cosTheta <= 0 &&
629 sqrt(1 - sqr(cosTheta)) <= emap -> cosThetaMax + FTINY)
630 /* Aperture below surface; no emission from current origin */
631 return;
632
633 if (mod -> omod == OVOID && !emap -> port &&
634 (cosTheta >= 1 - FTINY || (emap -> src -> sflags & SDISTANT &&
635 acos(cosTheta) + acos(emap -> cosThetaMax) <= 0.5 * PI))) {
636 /* Source is unmodified and has no port (which requires testing for
637 occlusion), and is either local with normal aligned aperture or
638 distant with aperture above surface; analytical flux & PDF */
639 setcolor(emap -> partFlux, mod -> oargs.farg [0],
640 mod -> oargs.farg [1], mod -> oargs.farg [2]);
641
642 /* Multiply radiance by Omega * dA to get flux */
643 scalecolor(emap -> partFlux,
644 PI * cosTheta * (1 - sqr(max(emap -> cosThetaMax, 0))) *
645 emap -> partArea);
646 }
647
648 else {
649 /* Source is either modified, has a port, is local with off-normal
650 aperture, or distant with aperture partly below surface; get flux
651 via numerical integration */
652 thetaScale = (1 - emap -> cosThetaMax);
653
654 /* Figga out numba of aperture samples for integration;
655 numTheta / numPhi ratio is 1 / PI */
656 du = sqrt(pdfSamples * 2 * thetaScale);
657 emap -> numTheta = max(du + 0.5, 1);
658 emap -> numPhi = max(PI * du + 0.5, 1);
659
660 dOmega = 2 * PI * thetaScale / (emap -> numTheta * emap -> numPhi);
661 thetaScale /= emap -> numTheta;
662
663 /* Allocate PDF, baby */
664 sample = emap -> samples = (EmissionSample*)
665 realloc(emap -> samples,
666 sizeof(EmissionSample) *
667 emap -> numTheta * emap -> numPhi);
668 if (!emap -> samples)
669 error(USER, "can't allocate emission PDF");
670
671 VCOPY(r.rorg, emap -> photonOrg);
672 VCOPY(r.rop, emap -> photonOrg);
673 r.rmax = FHUGE;
674
675 for (t = 0; t < emap -> numTheta; t++) {
676 for (p = 0; p < emap -> numPhi; p++) {
677 /* This uniform mapping handles 0 <= thetaMax <= PI */
678 cosTheta = 1 - (t + pmapRandom(emitState)) * thetaScale;
679 sinTheta = sqrt(1 - sqr(cosTheta));
680 phi = 2 * PI * (p + pmapRandom(emitState)) / emap -> numPhi;
681 du = cos(phi) * sinTheta;
682 dv = sin(phi) * sinTheta;
683 rayorigin(&r, PRIMARY, NULL, NULL);
684
685 for (i = 0; i < 3; i++)
686 r.rdir [i] = du * emap -> uh [i] + dv * emap -> vh [i] +
687 cosTheta * emap -> wh [i];
688
689 /* Sample behind surface? */
690 VCOPY(r.ron, emap -> ws);
691 if ((r.rod = DOT(r.rdir, r.ron)) <= 0)
692 continue;
693
694 /* Get radiance emitted in this direction; to get flux we
695 multiply by cos(theta_surface), dOmega, and dA. Ray
696 is directed towards light source for raytexture(). */
697 if (!(emap -> src -> sflags & SDISTANT))
698 for (i = 0; i < 3; i++)
699 r.rdir [i] = -r.rdir [i];
700
701 /* Port occluded in this direction? */
702 if (emap -> port && localhit(&r, &thescene))
703 continue;
704
705 raytexture(&r, mod -> omod);
706 setcolor(r.rcol, mod -> oargs.farg [0], mod -> oargs.farg [1],
707 mod -> oargs.farg [2]);
708 multcolor(r.rcol, r.pcol);
709
710 /* Multiply by cos(theta_surface) */
711 scalecolor(r.rcol, r.rod);
712
713 /* Add PDF sample if nonzero; importance info for photon emission
714 * could go here... */
715 if (colorAvg(r.rcol)) {
716 copycolor(sample -> pdf, r.rcol);
717 sample -> cdf = emap -> cdf += colorAvg(sample -> pdf);
718 sample -> theta = t;
719 sample++ -> phi = p;
720 emap -> numSamples++;
721 addcolor(emap -> partFlux, r.rcol);
722 }
723 }
724 }
725
726 /* Multiply by dOmega * dA */
727 scalecolor(emap -> partFlux, dOmega * emap -> partArea);
728 }
729 }
730
731
732
733 #define vomitPhoton emitPhoton
734 #define bluarrrghPhoton vomitPhoton
735
736 void emitPhoton (const EmissionMap* emap, RAY* ray)
737 /* Emit photon from current partition emap -> partitionCnt based on
738 emission distribution. Returns new photon ray. */
739 {
740 unsigned long i, lo, hi;
741 const EmissionSample* sample = emap -> samples;
742 RREAL du, dv, cosTheta, cosThetaSqr, sinTheta, phi;
743 const OBJREC* mod = objptr(emap -> src -> so -> omod);
744
745 /* Choose a new origin within current partition for every
746 emitted photon to break up clustering artifacts */
747 photonOrigin [emap -> src -> so -> otype] ((EmissionMap*)emap);
748 rayorigin(ray, PRIMARY, NULL, NULL);
749 ray -> rmax = FHUGE;
750
751 if (!emap -> numSamples) {
752 /* Source is unmodified and has no port, and either local with
753 normal aligned aperture, or distant with aperture above surface;
754 use cosine weighted distribution */
755 cosThetaSqr = 1 - pmapRandom(emitState) *
756 (1 - sqr(max(emap -> cosThetaMax, 0)));
757 cosTheta = sqrt(cosThetaSqr);
758 sinTheta = sqrt(1 - cosThetaSqr);
759 phi = 2 * PI * pmapRandom(emitState);
760 setcolor(ray -> rcol, mod -> oargs.farg [0], mod -> oargs.farg [1],
761 mod -> oargs.farg [2]);
762 }
763
764 else {
765 /* Source is either modified, has a port, is local with off-normal
766 aperture, or distant with aperture partly below surface; choose
767 direction from constructed cumulative distribution function with
768 Monte Carlo inversion using binary search. */
769 du = pmapRandom(emitState) * emap -> cdf;
770 lo = 1;
771 hi = emap -> numSamples;
772
773 while (hi > lo) {
774 i = (lo + hi) >> 1;
775 sample = emap -> samples + i - 1;
776
777 if (sample -> cdf >= du)
778 hi = i;
779 if (sample -> cdf < du)
780 lo = i + 1;
781 }
782
783 /* This is a uniform mapping, mon */
784 cosTheta = 1 - (sample -> theta + pmapRandom(emitState)) *
785 (1 - emap -> cosThetaMax) / emap -> numTheta;
786 sinTheta = sqrt(1 - sqr(cosTheta));
787 phi = 2 * PI * (sample -> phi + pmapRandom(emitState)) / emap -> numPhi;
788 copycolor(ray -> rcol, sample -> pdf);
789 }
790
791 /* Normalize photon flux so that average over RGB is 1 */
792 colorNorm(ray -> rcol);
793
794 VCOPY(ray -> rorg, emap -> photonOrg);
795 du = cos(phi) * sinTheta;
796 dv = sin(phi) * sinTheta;
797
798 for (i = 0; i < 3; i++)
799 ray -> rdir [i] = du * emap -> uh [i] + dv * emap -> vh [i] +
800 cosTheta * emap -> wh [i];
801
802 if (emap -> src -> sflags & SDISTANT)
803 /* Distant source; reverse ray direction to point into the scene. */
804 for (i = 0; i < 3; i++)
805 ray -> rdir [i] = -ray -> rdir [i];
806
807 if (emap -> port)
808 /* Photon emitted from port; move origin just behind port so it
809 will be scattered */
810 for (i = 0; i < 3; i++)
811 ray -> rorg [i] -= 2 * FTINY * ray -> rdir [i];
812
813 /* Assign emitting light source index */
814 ray -> rsrc = emap -> src - source;
815 }
816
817
818
819 void multDirectPmap (RAY *r)
820 /* Factor irradiance from direct photons into r -> rcol; interface to
821 * direct() */
822 {
823 COLOR photonIrrad;
824
825 /* Lookup direct photon irradiance */
826 (directPmap -> lookup)(directPmap, r, photonIrrad);
827
828 /* Multiply with coefficient in ray */
829 multcolor(r -> rcol, photonIrrad);
830
831 return;
832 }
833
834
835
836 void inscatterVolumePmap (RAY *r, COLOR inscatter)
837 /* Add inscattering from volume photon map; interface to srcscatter() */
838 {
839 /* Add ambient in-scattering via lookup callback */
840 (volumePmap -> lookup)(volumePmap, r, inscatter);
841 }
