root/radiance/ray/src/rt/pmapsrc.c
Revision: 2.10
Committed: Tue Sep 29 18:16:34 2015 UTC (9 years, 8 months ago) by rschregle
Changes since 2.9: +5 -4 lines
Improved handling of mixtures and photon ports with photon mapping
2 static const char RCSid[] = "$Id: pmapsrc.c,v 4.16 2015/09/28 17:33:13 taschreg Exp taschreg $";
5 ==================================================================
6 Photon map support routines for emission from light sources
7
8 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
9 (c) Fraunhofer Institute for Solar Energy Systems,
10 (c) Lucerne University of Applied Sciences and Arts,
11 supported by the Swiss National Science Foundation (SNSF, #147053)
12 ==================================================================
13
14 */
15
16
17
18 #include "pmapsrc.h"
19 #include "pmap.h"
20 #include "pmaprand.h"
21 #include "otypes.h"
22
23
24
25 SRCREC *photonPorts = NULL; /* Photon port list */
26 unsigned numPhotonPorts = 0;
27
28 void (*photonPartition [NUMOTYPE]) (EmissionMap*);
29 void (*photonOrigin [NUMOTYPE]) (EmissionMap*);
30
31 extern OBJECT ambset [];
32
33
34
35 static int flatPhotonPartition2 (EmissionMap* emap, unsigned long mp,
36 FVECT cent, FVECT u, FVECT v,
37 double du2, double dv2)
38 /* Recursive part of flatPhotonPartition(..) */
39 {
40 FVECT newct, newax;
41 unsigned long npl, npu;
42
43 if (mp > emap -> maxPartitions) {
44 /* Enlarge partition array */
45 emap -> maxPartitions <<= 1;
46 emap -> partitions = (unsigned char*)realloc(emap -> partitions,
47 emap -> maxPartitions >> 1);
48
49 if (!emap -> partitions)
50 error(USER, "can't allocate source partitions");
51
52 memset(emap -> partitions + (emap -> maxPartitions >> 2), 0,
53 emap -> maxPartitions >> 2);
54 }
55
56 if (du2 * dv2 <= 1) { /* hit limit? */
57 setpart(emap -> partitions, emap -> partitionCnt, S0);
58 emap -> partitionCnt++;
59 return 1;
60 }
61
62 if (du2 > dv2) { /* subdivide in U */
63 setpart(emap -> partitions, emap -> partitionCnt, SU);
64 emap -> partitionCnt++;
65 newax [0] = 0.5 * u [0];
66 newax [1] = 0.5 * u [1];
67 newax [2] = 0.5 * u [2];
68 u = newax;
69 du2 *= 0.25;
70 }
71
72 else { /* subdivide in V */
73 setpart(emap -> partitions, emap -> partitionCnt, SV);
74 emap -> partitionCnt++;
75 newax [0] = 0.5 * v [0];
76 newax [1] = 0.5 * v [1];
77 newax [2] = 0.5 * v [2];
78 v = newax;
79 dv2 *= 0.25;
80 }
81
82 /* lower half */
83 newct [0] = cent [0] - newax [0];
84 newct [1] = cent [1] - newax [1];
85 newct [2] = cent [2] - newax [2];
86 npl = flatPhotonPartition2(emap, mp << 1, newct, u, v, du2, dv2);
87
88 /* upper half */
89 newct [0] = cent [0] + newax [0];
90 newct [1] = cent [1] + newax [1];
91 newct [2] = cent [2] + newax [2];
92 npu = flatPhotonPartition2(emap, mp << 1, newct, u, v, du2, dv2);
93
94 /* return total */
95 return npl + npu;
96 }
97
98
99
100 static void flatPhotonPartition (EmissionMap* emap)
101 /* Partition flat source for photon emission */
102 {
103 RREAL *vp;
104 double du2, dv2;
105
106 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
107 emap -> partArea = srcsizerat * thescene.cusize;
108 emap -> partArea *= emap -> partArea;
109 vp = emap -> src -> ss [SU];
110 du2 = DOT(vp, vp) / emap -> partArea;
111 vp = emap -> src -> ss [SV];
112 dv2 = DOT(vp, vp) / emap -> partArea;
113 emap -> partitionCnt = 0;
114 emap -> numPartitions = flatPhotonPartition2(emap, 1, emap -> src -> sloc,
115 emap -> src -> ss [SU],
116 emap -> src -> ss [SV],
117 du2, dv2);
118 emap -> partitionCnt = 0;
119 emap -> partArea = emap -> src -> ss2 / emap -> numPartitions;
120 }
121
122
123
124 static void sourcePhotonPartition (EmissionMap* emap)
125 /* Partition scene cube faces or photon port for photon emission from
126 distant source */
127 {
128 if (emap -> port) {
129 /* Partition photon port */
130 SRCREC *src = emap -> src;
131 emap -> src = emap -> port;
132 photonPartition [emap -> src -> so -> otype] (emap);
133 emap -> src = src;
134 }
135
136 else {
137 /* No photon ports defined, so partition scene cube faces */
138 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
139 setpart(emap -> partitions, 0, S0);
140 emap -> partitionCnt = 0;
141 emap -> numPartitions = 1 / srcsizerat;
142 emap -> numPartitions *= emap -> numPartitions;
143 emap -> partArea = sqr(thescene.cusize) / emap -> numPartitions;
144 emap -> numPartitions *= 6;
145 }
146 }
147
148
149
150 static void spherePhotonPartition (EmissionMap* emap)
151 /* Partition spherical source into equal solid angles using uniform
152 mapping for photon emission */
153 {
154 unsigned numTheta, numPhi;
155
156 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
157 setpart(emap -> partitions, 0, S0);
158 emap -> partArea = 4 * PI * sqr(emap -> src -> srad);
159 emap -> numPartitions = emap -> partArea /
160 sqr(srcsizerat * thescene.cusize);
161
162 numTheta = max(sqrt(2 * emap -> numPartitions / PI) + 0.5, 1);
163 numPhi = 0.5 * PI * numTheta + 0.5;
164
165 emap -> numPartitions = (unsigned long)numTheta * numPhi;
166 emap -> partitionCnt = 0;
167 emap -> partArea /= emap -> numPartitions;
168 }
169
170
171
172 static int cylPhotonPartition2 (EmissionMap* emap, unsigned long mp,
173 FVECT cent, FVECT axis, double d2)
174 /* Recursive part of cyPhotonPartition(..) */
175 {
176 FVECT newct, newax;
177 unsigned long npl, npu;
178
179 if (mp > emap -> maxPartitions) {
180 /* Enlarge partition array */
181 emap -> maxPartitions <<= 1;
182 emap -> partitions = (unsigned char*)realloc(emap -> partitions,
183 emap -> maxPartitions >> 1);
184 if (!emap -> partitions)
185 error(USER, "can't allocate source partitions");
186
187 memset(emap -> partitions + (emap -> maxPartitions >> 2), 0,
188 emap -> maxPartitions >> 2);
189 }
190
191 if (d2 <= 1) {
192 /* hit limit? */
193 setpart(emap -> partitions, emap -> partitionCnt, S0);
194 emap -> partitionCnt++;
195 return 1;
196 }
197
198 /* subdivide */
199 setpart(emap -> partitions, emap -> partitionCnt, SU);
200 emap -> partitionCnt++;
201 newax [0] = 0.5 * axis [0];
202 newax [1] = 0.5 * axis [1];
203 newax [2] = 0.5 * axis [2];
204 d2 *= 0.25;
205
206 /* lower half */
207 newct [0] = cent [0] - newax [0];
208 newct [1] = cent [1] - newax [1];
209 newct [2] = cent [2] - newax [2];
210 npl = cylPhotonPartition2(emap, mp << 1, newct, newax, d2);
211
212 /* upper half */
213 newct [0] = cent [0] + newax [0];
214 newct [1] = cent [1] + newax [1];
215 newct [2] = cent [2] + newax [2];
216 npu = cylPhotonPartition2(emap, mp << 1, newct, newax, d2);
217
218 /* return total */
219 return npl + npu;
220 }
221
222
223
224 static void cylPhotonPartition (EmissionMap* emap)
225 /* Partition cylindrical source for photon emission */
226 {
227 double d2;
228
229 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
230 d2 = srcsizerat * thescene.cusize;
231 d2 = PI * emap -> src -> ss2 / (2 * emap -> src -> srad * sqr(d2));
232 d2 *= d2 * DOT(emap -> src -> ss [SU], emap -> src -> ss [SU]);
233
234 emap -> partitionCnt = 0;
235 emap -> numPartitions = cylPhotonPartition2(emap, 1, emap -> src -> sloc,
236 emap -> src -> ss [SU], d2);
237 emap -> partitionCnt = 0;
238 emap -> partArea = PI * emap -> src -> ss2 / emap -> numPartitions;
239 }
240
241
242
243 static void flatPhotonOrigin (EmissionMap* emap)
244 /* Init emission map with photon origin and associated surface axes on
245 flat light source surface. Also sets source aperture and sampling
246 hemisphere axes at origin */
247 {
248 int i, cent[3], size[3], parr[2];
249 FVECT vpos;
250
251 cent [0] = cent [1] = cent [2] = 0;
252 size [0] = size [1] = size [2] = emap -> maxPartitions;
253 parr [0] = 0;
254 parr [1] = emap -> partitionCnt;
255
256 if (!skipparts(cent, size, parr, emap -> partitions))
257 error(CONSISTENCY, "bad source partition in flatPhotonOrigin");
258
259 vpos [0] = (1 - 2 * pmapRandom(partState)) * size [0] /
260 emap -> maxPartitions;
261 vpos [1] = (1 - 2 * pmapRandom(partState)) * size [1] /
262 emap -> maxPartitions;
263 vpos [2] = 0;
264
265 for (i = 0; i < 3; i++)
266 vpos [i] += (double)cent [i] / emap -> maxPartitions;
267
268 /* Get origin */
269 for (i = 0; i < 3; i++)
270 emap -> photonOrg [i] = emap -> src -> sloc [i] +
271 vpos [SU] * emap -> src -> ss [SU][i] +
272 vpos [SV] * emap -> src -> ss [SV][i] +
273 vpos [SW] * emap -> src -> ss [SW][i];
274
275 /* Get surface axes */
276 VCOPY(emap -> us, emap -> src -> ss [SU]);
277 normalize(emap -> us);
278 VCOPY(emap -> ws, emap -> src -> ss [SW]);
279
280 if (emap -> port)
281 /* Acts as a photon port; reverse normal as it points INSIDE per
282 * mkillum convention */
283 for (i = 0; i < 3; i++)
284 emap -> ws [i] = -emap -> ws [i];
285
286 fcross(emap -> vs, emap -> ws, emap -> us);
287
288 /* Get hemisphere axes & aperture */
289 if (emap -> src -> sflags & SSPOT) {
290 VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
291 i = 0;
292
293 do {
294 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
295 emap -> vh [i++] = 1;
296 fcross(emap -> uh, emap -> vh, emap -> wh);
297 } while (normalize(emap -> uh) < FTINY);
298
299 fcross(emap -> vh, emap -> wh, emap -> uh);
300 emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
301 }
302
303 else {
304 VCOPY(emap -> uh, emap -> us);
305 VCOPY(emap -> vh, emap -> vs);
306 VCOPY(emap -> wh, emap -> ws);
307 emap -> cosThetaMax = 0;
308 }
309 }
310
311
312
313 static void spherePhotonOrigin (EmissionMap* emap)
314 /* Init emission map with photon origin and associated surface axes on
315 spherical light source. Also sets source aperture and sampling
316 hemisphere axes at origin */
317 {
318 int i = 0;
319 unsigned numTheta, numPhi, t, p;
320 RREAL cosTheta, sinTheta, phi;
321
322 /* Get current partition */
323 numTheta = max(sqrt(2 * emap -> numPartitions / PI) + 0.5, 1);
324 numPhi = 0.5 * PI * numTheta + 0.5;
325
326 t = emap -> partitionCnt / numPhi;
327 p = emap -> partitionCnt - t * numPhi;
328
329 emap -> ws [2] = cosTheta = 1 - 2 * (t + pmapRandom(partState)) / numTheta;
330 sinTheta = sqrt(1 - sqr(cosTheta));
331 phi = 2 * PI * (p + pmapRandom(partState)) / numPhi;
332 emap -> ws [0] = cos(phi) * sinTheta;
333 emap -> ws [1] = sin(phi) * sinTheta;
334
335 if (emap -> port)
336 /* Acts as a photon port; reverse normal as it points INSIDE per
337 * mkillum convention */
338 for (i = 0; i < 3; i++)
339 emap -> ws [i] = -emap -> ws [i];
340
341 /* Get surface axes us & vs perpendicular to ws */
342 do {
343 emap -> vs [0] = emap -> vs [1] = emap -> vs [2] = 0;
344 emap -> vs [i++] = 1;
345 fcross(emap -> us, emap -> vs, emap -> ws);
346 } while (normalize(emap -> us) < FTINY);
347
348 fcross(emap -> vs, emap -> ws, emap -> us);
349
350 /* Get origin */
351 for (i = 0; i < 3; i++)
352 emap -> photonOrg [i] = emap -> src -> sloc [i] +
353 emap -> src -> srad * emap -> ws [i];
354
355 /* Get hemisphere axes & aperture */
356 if (emap -> src -> sflags & SSPOT) {
357 VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
358 i = 0;
359
360 do {
361 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
362 emap -> vh [i++] = 1;
363 fcross(emap -> uh, emap -> vh, emap -> wh);
364 } while (normalize(emap -> uh) < FTINY);
365
366 fcross(emap -> vh, emap -> wh, emap -> uh);
367 emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
368 }
369
370 else {
371 VCOPY(emap -> uh, emap -> us);
372 VCOPY(emap -> vh, emap -> vs);
373 VCOPY(emap -> wh, emap -> ws);
374 emap -> cosThetaMax = 0;
375 }
376 }
377
378
379
380 static void sourcePhotonOrigin (EmissionMap* emap)
381 /* Init emission map with photon origin and associated surface axes
382 on scene cube face for distant light source. Also sets source
383 aperture (solid angle) and sampling hemisphere axes at origin */
384 {
385 unsigned long i, partsPerDim, partsPerFace;
386 unsigned face;
387 RREAL du, dv;
388
389 if (emap -> port) {
390 /* Get origin on photon port */
391 SRCREC *src = emap -> src;
392 emap -> src = emap -> port;
393 photonOrigin [emap -> src -> so -> otype] (emap);
394 emap -> src = src;
395 }
396
397 else {
398 /* No ports defined, so get origin on scene cube face and SUFFA! */
399 /* Get current face from partition number */
400 partsPerDim = 1 / srcsizerat;
401 partsPerFace = sqr(partsPerDim);
402 face = emap -> partitionCnt / partsPerFace;
403
404 if (!(emap -> partitionCnt % partsPerFace)) {
405 /* Skipped to a new face; get its normal */
406 emap -> ws [0] = emap -> ws [1] = emap -> ws [2] = 0;
407 emap -> ws [face >> 1] = face & 1 ? 1 : -1;
408
409 /* Get surface axes us & vs perpendicular to ws */
410 face >>= 1;
411 emap -> vs [0] = emap -> vs [1] = emap -> vs [2] = 0;
412 emap -> vs [(face + (emap -> ws [face] > 0 ? 2 : 1)) % 3] = 1;
413 fcross(emap -> us, emap -> vs, emap -> ws);
414 }
415
416 /* Get jittered offsets within face from partition number
417 (in range [-0.5, 0.5]) */
418 i = emap -> partitionCnt % partsPerFace;
419 du = (i / partsPerDim + pmapRandom(partState)) / partsPerDim - 0.5;
420 dv = (i % partsPerDim + pmapRandom(partState)) / partsPerDim - 0.5;
421
422 /* Jittered destination point within partition */
423 for (i = 0; i < 3; i++)
424 emap -> photonOrg [i] = thescene.cuorg [i] +
425 thescene.cusize * (0.5 + du * emap -> us [i] +
426 dv * emap -> vs [i] +
427 0.5 * emap -> ws [i]);
428 }
429
430 /* Get hemisphere axes & aperture */
431 VCOPY(emap -> wh, emap -> src -> sloc);
432 i = 0;
433
434 do {
435 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
436 emap -> vh [i++] = 1;
437 fcross(emap -> uh, emap -> vh, emap -> wh);
438 } while (normalize(emap -> uh) < FTINY);
439
440 fcross(emap -> vh, emap -> wh, emap -> uh);
441
442 /* Get aperture */
443 emap -> cosThetaMax = 1 - emap -> src -> ss2 / (2 * PI);
444 emap -> cosThetaMax = min(1, max(-1, emap -> cosThetaMax));
445 }
446
447
448
449 static void cylPhotonOrigin (EmissionMap* emap)
450 /* Init emission map with photon origin and associated surface axes
451 on cylindrical light source surface. Also sets source aperture
452 and sampling hemisphere axes at origin */
453 {
454 int i, cent[3], size[3], parr[2];
455 FVECT v;
456
457 cent [0] = cent [1] = cent [2] = 0;
458 size [0] = size [1] = size [2] = emap -> maxPartitions;
459 parr [0] = 0;
460 parr [1] = emap -> partitionCnt;
461
462 if (!skipparts(cent, size, parr, emap -> partitions))
463 error(CONSISTENCY, "bad source partition in cylPhotonOrigin");
464
465 v [SU] = 0;
466 v [SV] = (1 - 2 * pmapRandom(partState)) * (double)size [1] /
467 emap -> maxPartitions;
468 v [SW] = (1 - 2 * pmapRandom(partState)) * (double)size [2] /
469 emap -> maxPartitions;
470 normalize(v);
471 v [SU] = (1 - 2 * pmapRandom(partState)) * (double)size [1] /
472 emap -> maxPartitions;
473
474 for (i = 0; i < 3; i++)
475 v [i] += (double)cent [i] / emap -> maxPartitions;
476
477 /* Get surface axes */
478 for (i = 0; i < 3; i++)
479 emap -> photonOrg [i] = emap -> ws [i] =
480 (v [SV] * emap -> src -> ss [SV][i] +
481 v [SW] * emap -> src -> ss [SW][i]) / 0.8559;
482
483 if (emap -> port)
484 /* Acts as a photon port; reverse normal as it points INSIDE per
485 * mkillum convention */
486 for (i = 0; i < 3; i++)
487 emap -> ws [i] = -emap -> ws [i];
488
489 normalize(emap -> ws);
490 VCOPY(emap -> us, emap -> src -> ss [SU]);
491 normalize(emap -> us);
492 fcross(emap -> vs, emap -> ws, emap -> us);
493
494 /* Get origin */
495 for (i = 0; i < 3; i++)
496 emap -> photonOrg [i] += v [SU] * emap -> src -> ss [SU][i] +
497 emap -> src -> sloc [i];
498
499 /* Get hemisphere axes & aperture */
500 if (emap -> src -> sflags & SSPOT) {
501 VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
502 i = 0;
503
504 do {
505 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
506 emap -> vh [i++] = 1;
507 fcross(emap -> uh, emap -> vh, emap -> wh);
508 } while (normalize(emap -> uh) < FTINY);
509
510 fcross(emap -> vh, emap -> wh, emap -> uh);
511 emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
512 }
513
514 else {
515 VCOPY(emap -> uh, emap -> us);
516 VCOPY(emap -> vh, emap -> vs);
517 VCOPY(emap -> wh, emap -> ws);
518 emap -> cosThetaMax = 0;
519 }
520 }
521
522
523
524 void getPhotonPorts ()
525 /* Find geometry declared as photon ports */
526 {
527 OBJECT i;
528 OBJREC* obj;
529
530 /* Check for missing port modifiers */
531 if (!ambset [0])
532 error(USER, "no photon ports found");
533
534 for (i = 0; i < nobjects; i++) {
535 obj = objptr(i);
536
537 /* Check if object is a surface and NOT a light source (duh) and
538 * resolve its material via any aliases, then check for inclusion in
539 * port modifier list */
540 if (issurface(obj -> otype) && !islight(obj -> otype) &&
541 inset(ambset, objndx(findmaterial(obj)))) {
542 /* Add photon port */
543 photonPorts = (SRCREC*)realloc(photonPorts,
544 (numPhotonPorts + 1) *
545 sizeof(SRCREC));
546 if (!photonPorts)
547 error(USER, "can't allocate photon ports");
548
549 photonPorts [numPhotonPorts].so = obj;
550 photonPorts [numPhotonPorts].sflags = 0;
551
552 if (!sfun [obj -> otype].of || !sfun[obj -> otype].of -> setsrc)
553 objerror(obj, USER, "illegal photon port");
554
555 setsource(photonPorts + numPhotonPorts, obj);
556 numPhotonPorts++;
557 }
558 }
559 }
560
561
562
563 static void defaultEmissionFunc (EmissionMap* emap)
564 /* Default behaviour when no emission funcs defined for this source type */
565 {
566 objerror(emap -> src -> so, INTERNAL,
567 "undefined photon emission function");
568 }
569
570
571
572 void initPhotonEmissionFuncs ()
573 /* Init photonPartition[] and photonOrigin[] dispatch tables */
574 {
575 int i;
576
577 for (i = 0; i < NUMOTYPE; i++)
578 photonPartition [i] = photonOrigin [i] = defaultEmissionFunc;
579
580 photonPartition [OBJ_FACE] = photonPartition [OBJ_RING] = flatPhotonPartition;
581 photonPartition [OBJ_SOURCE] = sourcePhotonPartition;
582 photonPartition [OBJ_SPHERE] = spherePhotonPartition;
583 photonPartition [OBJ_CYLINDER] = cylPhotonPartition;
584 photonOrigin [OBJ_FACE] = photonOrigin [OBJ_RING] = flatPhotonOrigin;
585 photonOrigin [OBJ_SOURCE] = sourcePhotonOrigin;
586 photonOrigin [OBJ_SPHERE] = spherePhotonOrigin;
587 photonOrigin [OBJ_CYLINDER] = cylPhotonOrigin;
588 }
589
590
591
592 void initPhotonEmission (EmissionMap *emap, float numPdfSamples)
593 /* Initialize photon emission from partitioned light source emap -> src;
594 * this involves integrating the flux emitted from the current photon
595 * origin emap -> photonOrg and setting up a PDF to sample the emission
596 * distribution with numPdfSamples samples */
597 {
598 unsigned i, t, p;
599 double phi, cosTheta, sinTheta, du, dv, dOmega, thetaScale;
600 EmissionSample* sample;
601 const OBJREC* mod = findmaterial(emap -> src -> so);
602 static RAY r;
603 #if 0
604 static double lastCosNorm = FHUGE;
605 static SRCREC *lastSrc = NULL, *lastPort = NULL;
606 #endif
607
608 setcolor(emap -> partFlux, 0, 0, 0);
609
610 photonOrigin [emap -> src -> so -> otype] (emap);
611 cosTheta = DOT(emap -> ws, emap -> wh);
612
613 #if 0
614 if (emap -> src == lastSrc && emap -> port == lastPort &&
615 (emap -> src -> sflags & SDISTANT || mod -> omod == OVOID) &&
616 cosTheta == lastCosNorm)
617 /* Same source, port, and aperture-normal angle, and source is
618 either distant (and thus translationally invariant) or has
619 no modifier --> flux unchanged */
620 /* BUG: this optimisation ignores partial occlusion of ports and
621 can lead to erroneous "zero emission" bailouts.
622 It can also lead to bias with modifiers exhibiting high variance!
623 Disabled for now -- RS 12/13 */
624 return;
625
626 lastSrc = emap -> src;
627 lastPort = emap -> port;
628 lastCosNorm = cosTheta;
629 #endif
630
631 /* Need to recompute flux & PDF */
632 emap -> cdf = 0;
633 emap -> numSamples = 0;
634
635 if (cosTheta <= 0 &&
636 sqrt(1 - sqr(cosTheta)) <= emap -> cosThetaMax + FTINY)
637 /* Aperture below surface; no emission from current origin */
638 return;
639
640 if (mod -> omod == OVOID && !emap -> port &&
641 (cosTheta >= 1 - FTINY || (emap -> src -> sflags & SDISTANT &&
642 acos(cosTheta) + acos(emap -> cosThetaMax) <= 0.5 * PI))) {
643 /* Source is unmodified and has no port (which requires testing for
644 occlusion), and is either local with normal aligned aperture or
645 distant with aperture above surface; analytical flux & PDF */
646 setcolor(emap -> partFlux, mod -> oargs.farg [0],
647 mod -> oargs.farg [1], mod -> oargs.farg [2]);
648
649 /* Multiply radiance by Omega * dA to get flux */
650 scalecolor(emap -> partFlux,
651 PI * cosTheta * (1 - sqr(max(emap -> cosThetaMax, 0))) *
652 emap -> partArea);
653 }
654
655 else {
656 /* Source is either modified, has a port, is local with off-normal
657 aperture, or distant with aperture partly below surface; get flux
658 via numerical integration */
659 thetaScale = (1 - emap -> cosThetaMax);
660
661 /* Figga out numba of aperture samples for integration;
662 numTheta / numPhi ratio is 1 / PI */
663 du = sqrt(pdfSamples * 2 * thetaScale);
664 emap -> numTheta = max(du + 0.5, 1);
665 emap -> numPhi = max(PI * du + 0.5, 1);
666
667 dOmega = 2 * PI * thetaScale / (emap -> numTheta * emap -> numPhi);
668 thetaScale /= emap -> numTheta;
669
670 /* Allocate PDF, baby */
671 sample = emap -> samples = (EmissionSample*)
672 realloc(emap -> samples,
673 sizeof(EmissionSample) *
674 emap -> numTheta * emap -> numPhi);
675 if (!emap -> samples)
676 error(USER, "can't allocate emission PDF");
677
678 VCOPY(r.rorg, emap -> photonOrg);
679 VCOPY(r.rop, emap -> photonOrg);
680 r.rmax = 0;
681
682 for (t = 0; t < emap -> numTheta; t++) {
683 for (p = 0; p < emap -> numPhi; p++) {
684 /* This uniform mapping handles 0 <= thetaMax <= PI */
685 cosTheta = 1 - (t + pmapRandom(emitState)) * thetaScale;
686 sinTheta = sqrt(1 - sqr(cosTheta));
687 phi = 2 * PI * (p + pmapRandom(emitState)) / emap -> numPhi;
688 du = cos(phi) * sinTheta;
689 dv = sin(phi) * sinTheta;
690 rayorigin(&r, PRIMARY, NULL, NULL);
691
692 for (i = 0; i < 3; i++)
693 r.rdir [i] = du * emap -> uh [i] + dv * emap -> vh [i] +
694 cosTheta * emap -> wh [i];
695
696 /* Sample behind surface? */
697 VCOPY(r.ron, emap -> ws);
698 if ((r.rod = DOT(r.rdir, r.ron)) <= 0)
699 continue;
700
701 /* Get radiance emitted in this direction; to get flux we
702 multiply by cos(theta_surface), dOmega, and dA. Ray
703 is directed towards light source for raytexture(). */
704 if (!(emap -> src -> sflags & SDISTANT))
705 for (i = 0; i < 3; i++)
706 r.rdir [i] = -r.rdir [i];
707
708 /* Port occluded in this direction? */
709 if (emap -> port && localhit(&r, &thescene))
710 continue;
711
712 raytexture(&r, mod -> omod);
713 setcolor(r.rcol, mod -> oargs.farg [0], mod -> oargs.farg [1],
714 mod -> oargs.farg [2]);
715 multcolor(r.rcol, r.pcol);
716
717 /* Multiply by cos(theta_surface) */
718 scalecolor(r.rcol, r.rod);
719
720 /* Add PDF sample if nonzero; importance info for photon emission
721 * could go here... */
722 if (colorAvg(r.rcol)) {
723 copycolor(sample -> pdf, r.rcol);
724 sample -> cdf = emap -> cdf += colorAvg(sample -> pdf);
725 sample -> theta = t;
726 sample++ -> phi = p;
727 emap -> numSamples++;
728 addcolor(emap -> partFlux, r.rcol);
729 }
730 }
731 }
732
733 /* Multiply by dOmega * dA */
734 scalecolor(emap -> partFlux, dOmega * emap -> partArea);
735 }
736 }
737
738
739
740 #define vomitPhoton emitPhoton
741 #define bluarrrghPhoton vomitPhoton
742
743 void emitPhoton (const EmissionMap* emap, RAY* ray)
744 /* Emit photon from current partition emap -> partitionCnt based on
745 emission distribution. Returns new photon ray. */
746 {
747 unsigned long i, lo, hi;
748 const EmissionSample* sample = emap -> samples;
749 RREAL du, dv, cosTheta, cosThetaSqr, sinTheta, phi;
750 const OBJREC* mod = findmaterial(emap -> src -> so);
751
752 /* Choose a new origin within current partition for every
753 emitted photon to break up clustering artifacts */
754 photonOrigin [emap -> src -> so -> otype] ((EmissionMap*)emap);
755 /* If we have a local glow source with a maximum radius, then
756 restrict our photon to the specified distance (otherwise no limit) */
757 if (mod -> otype == MAT_GLOW && !(emap -> src -> sflags & SDISTANT)
758 && mod -> oargs.farg[3] > FTINY)
759 ray -> rmax = mod -> oargs.farg[3];
760 else
761 ray -> rmax = 0;
762 rayorigin(ray, PRIMARY, NULL, NULL);
763
764 if (!emap -> numSamples) {
765 /* Source is unmodified and has no port, and either local with
766 normal aligned aperture, or distant with aperture above surface;
767 use cosine weighted distribution */
768 cosThetaSqr = 1 - pmapRandom(emitState) *
769 (1 - sqr(max(emap -> cosThetaMax, 0)));
770 cosTheta = sqrt(cosThetaSqr);
771 sinTheta = sqrt(1 - cosThetaSqr);
772 phi = 2 * PI * pmapRandom(emitState);
773 setcolor(ray -> rcol, mod -> oargs.farg [0], mod -> oargs.farg [1],
774 mod -> oargs.farg [2]);
775 }
776
777 else {
778 /* Source is either modified, has a port, is local with off-normal
779 aperture, or distant with aperture partly below surface; choose
780 direction from constructed cumulative distribution function with
781 Monte Carlo inversion using binary search. */
782 du = pmapRandom(emitState) * emap -> cdf;
783 lo = 1;
784 hi = emap -> numSamples;
785
786 while (hi > lo) {
787 i = (lo + hi) >> 1;
788 sample = emap -> samples + i - 1;
789
790 if (sample -> cdf >= du)
791 hi = i;
792 if (sample -> cdf < du)
793 lo = i + 1;
794 }
795
796 /* This is a uniform mapping, mon */
797 cosTheta = 1 - (sample -> theta + pmapRandom(emitState)) *
798 (1 - emap -> cosThetaMax) / emap -> numTheta;
799 sinTheta = sqrt(1 - sqr(cosTheta));
800 phi = 2 * PI * (sample -> phi + pmapRandom(emitState)) / emap -> numPhi;
801 copycolor(ray -> rcol, sample -> pdf);
802 }
803
804 /* Normalize photon flux so that average over RGB is 1 */
805 colorNorm(ray -> rcol);
806
807 VCOPY(ray -> rorg, emap -> photonOrg);
808 du = cos(phi) * sinTheta;
809 dv = sin(phi) * sinTheta;
810
811 for (i = 0; i < 3; i++)
812 ray -> rdir [i] = du * emap -> uh [i] + dv * emap -> vh [i] +
813 cosTheta * emap -> wh [i];
814
815 if (emap -> src -> sflags & SDISTANT)
816 /* Distant source; reverse ray direction to point into the scene. */
817 for (i = 0; i < 3; i++)
818 ray -> rdir [i] = -ray -> rdir [i];
819
820 if (emap -> port)
821 /* Photon emitted from port; move origin just behind port so it
822 will be scattered */
823 for (i = 0; i < 3; i++)
824 ray -> rorg [i] -= 2 * FTINY * ray -> rdir [i];
825
826 /* Assign emitting light source index */
827 ray -> rsrc = emap -> src - source;
828 }
829
830
831
832 void multDirectPmap (RAY *r)
833 /* Factor irradiance from direct photons into r -> rcol; interface to
834 * direct() */
835 {
836 COLOR photonIrrad;
837
838 /* Lookup direct photon irradiance */
839 (directPmap -> lookup)(directPmap, r, photonIrrad);
840
841 /* Multiply with coefficient in ray */
842 multcolor(r -> rcol, photonIrrad);
843
844 return;
845 }
846
847
848
849 void inscatterVolumePmap (RAY *r, COLOR inscatter)
850 /* Add inscattering from volume photon map; interface to srcscatter() */
851 {
852 /* Add ambient in-scattering via lookup callback */
853 (volumePmap -> lookup)(volumePmap, r, inscatter);
854 }
