--- ray/src/rt/pmapsrc.c 2020/08/07 01:21:13 2.18 +++ ray/src/rt/pmapsrc.c 2020/08/10 19:51:20 2.19 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pmapsrc.c,v 2.18 2020/08/07 01:21:13 rschregle Exp $"; +static const char RCSid[] = "$Id: pmapsrc.c,v 2.19 2020/08/10 19:51:20 rschregle Exp $"; #endif /* ====================================================================== @@ -15,7 +15,7 @@ static const char RCSid[] = "$Id: pmapsrc.c,v 2.18 202 supported by the JSPS KAKENHI Grant Number JP19KK0115. ====================================================================== - $Id: pmapsrc.c,v 2.18 2020/08/07 01:21:13 rschregle Exp $" + $Id: pmapsrc.c,v 2.19 2020/08/10 19:51:20 rschregle Exp $" */ @@ -137,26 +137,32 @@ void getPhotonPorts (char **portList) static void setPhotonPortNormal (EmissionMap* emap) -/* Set normal for current photon port partition based on its orientation */ +/* Set normal for current photon port partition (if defined) based on its + * orientation */ { - /* Extract photon port orientation flags, set surface normal as follows: - -- Port oriented forwards --> flip surface normal to point - outwards, since normal points inwards per mkillum convention) - -- Port oriented backwards --> surface normal is NOT flipped, - since it already points inwards. - -- Port is bidirectionally/bilaterally oriented --> flip normal based - on the parity of the current partition emap -> partitionCnt. - In this case, photon emission alternates between port front/back - faces for consecutive partitions. - */ - int i, portFlags = PMAP_GETPORTFLAGS(emap -> port -> sflags); - if ( - portFlags == PMAP_PORTFWD || - portFlags == PMAP_PORTBI && !(emap -> partitionCnt & 1) - ) - for (i = 0; i < 3; i++) - emap -> ws [i] = -emap -> ws [i]; + int i, portFlags; + + if (emap -> port) { + /* Extract photon port orientation flags, set surface normal as follows: + -- Port oriented forwards --> flip surface normal to point outwards, + since normal points inwards per mkillum convention) + -- Port oriented backwards --> surface normal is NOT flipped, since + it already points inwards. + -- Port is bidirectionally/bilaterally oriented --> flip normal based + on the parity of the current partition emap -> partitionCnt. In + this case, photon emission alternates between port front/back + faces for consecutive partitions. + */ + portFlags = PMAP_GETPORTFLAGS(emap -> port -> sflags); + + if ( + portFlags == PMAP_PORTFWD || + portFlags == PMAP_PORTBI && !(emap -> partitionCnt & 1) + ) + for (i = 0; i < 3; i++) + emap -> ws [i] = -emap -> ws [i]; + } }
