--- ray/src/rt/pmapsrc.c 2016/05/17 17:39:47 2.13 +++ ray/src/rt/pmapsrc.c 2018/03/20 19:55:33 2.15 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pmapsrc.c,v 2.13 2016/05/17 17:39:47 rschregle Exp $"; +static const char RCSid[] = "$Id: pmapsrc.c,v 2.15 2018/03/20 19:55:33 rschregle Exp $"; #endif /* ================================================================== @@ -20,16 +20,15 @@ static const char RCSid[] = "$Id: pmapsrc.c,v 2.13 201 #include "pmaprand.h" #include "otypes.h" - - -SRCREC *photonPorts = NULL; /* Photon port list */ +/* List of photon port modifier names */ +char *photonPortList [MAXSET + 1] = {NULL}; +/* Photon port objects (with modifiers in photonPortMods) */ +SRCREC *photonPorts = NULL; unsigned numPhotonPorts = 0; void (*photonPartition [NUMOTYPE]) (EmissionMap*); void (*photonOrigin [NUMOTYPE]) (EmissionMap*); -extern OBJECT ambset []; - static int flatPhotonPartition2 (EmissionMap* emap, unsigned long mp, @@ -521,14 +520,15 @@ static void cylPhotonOrigin (EmissionMap* emap) -void getPhotonPorts () -/* Find geometry declared as photon ports */ +void getPhotonPorts (char **portList) +/* Find geometry declared as photon ports from modifiers in portList */ { OBJECT i; OBJREC *obj, *mat; + char **lp; /* Check for missing port modifiers */ - if (!ambset [0]) + if (!portList [0]) error(USER, "no photon ports"); for (i = 0; i < nobjects; i++) { @@ -537,24 +537,27 @@ void getPhotonPorts () /* Check if object is a surface and NOT a light source (duh) and * resolve its material via any aliases, then check for inclusion in - * port modifier list */ - if (issurface(obj -> otype) && mat && !islight(mat -> otype) && - inset(ambset, objndx(mat))) { - /* Add photon port */ - photonPorts = (SRCREC*)realloc(photonPorts, - (numPhotonPorts + 1) * - sizeof(SRCREC)); - if (!photonPorts) - error(USER, "can't allocate photon ports"); - - photonPorts [numPhotonPorts].so = obj; - photonPorts [numPhotonPorts].sflags = 0; + * modifier list */ + if (issurface(obj -> otype) && mat && !islight(mat -> otype)) { + for (lp = portList; *lp && strcmp(mat -> oname, *lp); lp++); - if (!sfun [obj -> otype].of || !sfun[obj -> otype].of -> setsrc) - objerror(obj, USER, "illegal photon port"); + if (*lp) { + /* Add photon port */ + photonPorts = (SRCREC*)realloc(photonPorts, + (numPhotonPorts + 1) * + sizeof(SRCREC)); + if (!photonPorts) + error(USER, "can't allocate photon ports"); - setsource(photonPorts + numPhotonPorts, obj); - numPhotonPorts++; + photonPorts [numPhotonPorts].so = obj; + photonPorts [numPhotonPorts].sflags = 0; + + if (!sfun [obj -> otype].of || !sfun[obj -> otype].of -> setsrc) + objerror(obj, USER, "illegal photon port"); + + setsource(photonPorts + numPhotonPorts, obj); + numPhotonPorts++; + } } } @@ -757,12 +760,13 @@ void emitPhoton (const EmissionMap* emap, RAY* ray) emitted photon to break up clustering artifacts */ photonOrigin [emap -> src -> so -> otype] ((EmissionMap*)emap); /* If we have a local glow source with a maximum radius, then - restrict our photon to the specified distance (otherwise no limit) */ + restrict our photon to the specified distance, otherwise we set + the limit imposed by photonMaxDist (or no limit if 0) */ if (mod -> otype == MAT_GLOW && !(emap -> src -> sflags & SDISTANT) && mod -> oargs.farg[3] > FTINY) ray -> rmax = mod -> oargs.farg[3]; else - ray -> rmax = 0; + ray -> rmax = photonMaxDist; rayorigin(ray, PRIMARY, NULL, NULL); if (!emap -> numSamples) {
