root/radiance/ray/src/rt/pmapsrc.c
Revision: 2.9
Committed: Tue Sep 22 15:08:31 2015 UTC (9 years, 10 months ago) by rschregle
Changes since 2.8: +5 -2 lines
Improved photon port handling -- only actual surfaces are accepted
2 static const char RCSid[] = "$Id: pmapsrc.c,v 4.15 2015/09/22 15:07:06 taschreg Exp taschreg $";
5 ==================================================================
6 Photon map support routines for emission from light sources
7
8 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
9 (c) Fraunhofer Institute for Solar Energy Systems,
10 (c) Lucerne University of Applied Sciences and Arts,
11 supported by the Swiss National Science Foundation (SNSF, #147053)
12 ==================================================================
13
14 */
15
16
17
18 #include "pmapsrc.h"
19 #include "pmap.h"
20 #include "pmaprand.h"
21 #include "otypes.h"
22
23
24
25 SRCREC *photonPorts = NULL; /* Photon port list */
26 unsigned numPhotonPorts = 0;
27
28 void (*photonPartition [NUMOTYPE]) (EmissionMap*);
29 void (*photonOrigin [NUMOTYPE]) (EmissionMap*);
30
31 extern OBJECT ambset [];
32
33
34
35 static int flatPhotonPartition2 (EmissionMap* emap, unsigned long mp,
36 FVECT cent, FVECT u, FVECT v,
37 double du2, double dv2)
38 /* Recursive part of flatPhotonPartition(..) */
39 {
40 FVECT newct, newax;
41 unsigned long npl, npu;
42
43 if (mp > emap -> maxPartitions) {
44 /* Enlarge partition array */
45 emap -> maxPartitions <<= 1;
46 emap -> partitions = (unsigned char*)realloc(emap -> partitions,
47 emap -> maxPartitions >> 1);
48
49 if (!emap -> partitions)
50 error(USER, "can't allocate source partitions");
51
52 memset(emap -> partitions + (emap -> maxPartitions >> 2), 0,
53 emap -> maxPartitions >> 2);
54 }
55
56 if (du2 * dv2 <= 1) { /* hit limit? */
57 setpart(emap -> partitions, emap -> partitionCnt, S0);
58 emap -> partitionCnt++;
59 return 1;
60 }
61
62 if (du2 > dv2) { /* subdivide in U */
63 setpart(emap -> partitions, emap -> partitionCnt, SU);
64 emap -> partitionCnt++;
65 newax [0] = 0.5 * u [0];
66 newax [1] = 0.5 * u [1];
67 newax [2] = 0.5 * u [2];
68 u = newax;
69 du2 *= 0.25;
70 }
71
72 else { /* subdivide in V */
73 setpart(emap -> partitions, emap -> partitionCnt, SV);
74 emap -> partitionCnt++;
75 newax [0] = 0.5 * v [0];
76 newax [1] = 0.5 * v [1];
77 newax [2] = 0.5 * v [2];
78 v = newax;
79 dv2 *= 0.25;
80 }
81
82 /* lower half */
83 newct [0] = cent [0] - newax [0];
84 newct [1] = cent [1] - newax [1];
85 newct [2] = cent [2] - newax [2];
86 npl = flatPhotonPartition2(emap, mp << 1, newct, u, v, du2, dv2);
87
88 /* upper half */
89 newct [0] = cent [0] + newax [0];
90 newct [1] = cent [1] + newax [1];
91 newct [2] = cent [2] + newax [2];
92 npu = flatPhotonPartition2(emap, mp << 1, newct, u, v, du2, dv2);
93
94 /* return total */
95 return npl + npu;
96 }
97
98
99
100 static void flatPhotonPartition (EmissionMap* emap)
101 /* Partition flat source for photon emission */
102 {
103 RREAL *vp;
104 double du2, dv2;
105
106 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
107 emap -> partArea = srcsizerat * thescene.cusize;
108 emap -> partArea *= emap -> partArea;
109 vp = emap -> src -> ss [SU];
110 du2 = DOT(vp, vp) / emap -> partArea;
111 vp = emap -> src -> ss [SV];
112 dv2 = DOT(vp, vp) / emap -> partArea;
113 emap -> partitionCnt = 0;
114 emap -> numPartitions = flatPhotonPartition2(emap, 1, emap -> src -> sloc,
115 emap -> src -> ss [SU],
116 emap -> src -> ss [SV],
117 du2, dv2);
118 emap -> partitionCnt = 0;
119 emap -> partArea = emap -> src -> ss2 / emap -> numPartitions;
120 }
121
122
123
124 static void sourcePhotonPartition (EmissionMap* emap)
125 /* Partition scene cube faces or photon port for photon emission from
126 distant source */
127 {
128 if (emap -> port) {
129 /* Partition photon port */
130 SRCREC *src = emap -> src;
131 emap -> src = emap -> port;
132 photonPartition [emap -> src -> so -> otype] (emap);
133 emap -> src = src;
134 }
135
136 else {
137 /* No photon ports defined, so partition scene cube faces */
138 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
139 setpart(emap -> partitions, 0, S0);
140 emap -> partitionCnt = 0;
141 emap -> numPartitions = 1 / srcsizerat;
142 emap -> numPartitions *= emap -> numPartitions;
143 emap -> partArea = sqr(thescene.cusize) / emap -> numPartitions;
144 emap -> numPartitions *= 6;
145 }
146 }
147
148
149
150 static void spherePhotonPartition (EmissionMap* emap)
151 /* Partition spherical source into equal solid angles using uniform
152 mapping for photon emission */
153 {
154 unsigned numTheta, numPhi;
155
156 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
157 setpart(emap -> partitions, 0, S0);
158 emap -> partArea = 4 * PI * sqr(emap -> src -> srad);
159 emap -> numPartitions = emap -> partArea /
160 sqr(srcsizerat * thescene.cusize);
161
162 numTheta = max(sqrt(2 * emap -> numPartitions / PI) + 0.5, 1);
163 numPhi = 0.5 * PI * numTheta + 0.5;
164
165 emap -> numPartitions = (unsigned long)numTheta * numPhi;
166 emap -> partitionCnt = 0;
167 emap -> partArea /= emap -> numPartitions;
168 }
169
170
171
172 static int cylPhotonPartition2 (EmissionMap* emap, unsigned long mp,
173 FVECT cent, FVECT axis, double d2)
174 /* Recursive part of cyPhotonPartition(..) */
175 {
176 FVECT newct, newax;
177 unsigned long npl, npu;
178
179 if (mp > emap -> maxPartitions) {
180 /* Enlarge partition array */
181 emap -> maxPartitions <<= 1;
182 emap -> partitions = (unsigned char*)realloc(emap -> partitions,
183 emap -> maxPartitions >> 1);
184 if (!emap -> partitions)
185 error(USER, "can't allocate source partitions");
186
187 memset(emap -> partitions + (emap -> maxPartitions >> 2), 0,
188 emap -> maxPartitions >> 2);
189 }
190
191 if (d2 <= 1) {
192 /* hit limit? */
193 setpart(emap -> partitions, emap -> partitionCnt, S0);
194 emap -> partitionCnt++;
195 return 1;
196 }
197
198 /* subdivide */
199 setpart(emap -> partitions, emap -> partitionCnt, SU);
200 emap -> partitionCnt++;
201 newax [0] = 0.5 * axis [0];
202 newax [1] = 0.5 * axis [1];
203 newax [2] = 0.5 * axis [2];
204 d2 *= 0.25;
205
206 /* lower half */
207 newct [0] = cent [0] - newax [0];
208 newct [1] = cent [1] - newax [1];
209 newct [2] = cent [2] - newax [2];
210 npl = cylPhotonPartition2(emap, mp << 1, newct, newax, d2);
211
212 /* upper half */
213 newct [0] = cent [0] + newax [0];
214 newct [1] = cent [1] + newax [1];
215 newct [2] = cent [2] + newax [2];
216 npu = cylPhotonPartition2(emap, mp << 1, newct, newax, d2);
217
218 /* return total */
219 return npl + npu;
220 }
221
222
223
224 static void cylPhotonPartition (EmissionMap* emap)
225 /* Partition cylindrical source for photon emission */
226 {
227 double d2;
228
229 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
230 d2 = srcsizerat * thescene.cusize;
231 d2 = PI * emap -> src -> ss2 / (2 * emap -> src -> srad * sqr(d2));
232 d2 *= d2 * DOT(emap -> src -> ss [SU], emap -> src -> ss [SU]);
233
234 emap -> partitionCnt = 0;
235 emap -> numPartitions = cylPhotonPartition2(emap, 1, emap -> src -> sloc,
236 emap -> src -> ss [SU], d2);
237 emap -> partitionCnt = 0;
238 emap -> partArea = PI * emap -> src -> ss2 / emap -> numPartitions;
239 }
240
241
242
243 static void flatPhotonOrigin (EmissionMap* emap)
244 /* Init emission map with photon origin and associated surface axes on
245 flat light source surface. Also sets source aperture and sampling
246 hemisphere axes at origin */
247 {
248 int i, cent[3], size[3], parr[2];
249 FVECT vpos;
250
251 cent [0] = cent [1] = cent [2] = 0;
252 size [0] = size [1] = size [2] = emap -> maxPartitions;
253 parr [0] = 0;
254 parr [1] = emap -> partitionCnt;
255
256 if (!skipparts(cent, size, parr, emap -> partitions))
257 error(CONSISTENCY, "bad source partition in flatPhotonOrigin");
258
259 vpos [0] = (1 - 2 * pmapRandom(partState)) * size [0] /
260 emap -> maxPartitions;
261 vpos [1] = (1 - 2 * pmapRandom(partState)) * size [1] /
262 emap -> maxPartitions;
263 vpos [2] = 0;
264
265 for (i = 0; i < 3; i++)
266 vpos [i] += (double)cent [i] / emap -> maxPartitions;
267
268 /* Get origin */
269 for (i = 0; i < 3; i++)
270 emap -> photonOrg [i] = emap -> src -> sloc [i] +
271 vpos [SU] * emap -> src -> ss [SU][i] +
272 vpos [SV] * emap -> src -> ss [SV][i] +
273 vpos [SW] * emap -> src -> ss [SW][i];
274
275 /* Get surface axes */
276 VCOPY(emap -> us, emap -> src -> ss [SU]);
277 normalize(emap -> us);
278 VCOPY(emap -> ws, emap -> src -> ss [SW]);
279
280 if (emap -> port)
281 /* Acts as a photon port; reverse normal as it points INSIDE per
282 * mkillum convention */
283 for (i = 0; i < 3; i++)
284 emap -> ws [i] = -emap -> ws [i];
285
286 fcross(emap -> vs, emap -> ws, emap -> us);
287
288 /* Get hemisphere axes & aperture */
289 if (emap -> src -> sflags & SSPOT) {
290 VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
291 i = 0;
292
293 do {
294 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
295 emap -> vh [i++] = 1;
296 fcross(emap -> uh, emap -> vh, emap -> wh);
297 } while (normalize(emap -> uh) < FTINY);
298
299 fcross(emap -> vh, emap -> wh, emap -> uh);
300 emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
301 }
302
303 else {
304 VCOPY(emap -> uh, emap -> us);
305 VCOPY(emap -> vh, emap -> vs);
306 VCOPY(emap -> wh, emap -> ws);
307 emap -> cosThetaMax = 0;
308 }
309 }
310
311
312
313 static void spherePhotonOrigin (EmissionMap* emap)
314 /* Init emission map with photon origin and associated surface axes on
315 spherical light source. Also sets source aperture and sampling
316 hemisphere axes at origin */
317 {
318 int i = 0;
319 unsigned numTheta, numPhi, t, p;
320 RREAL cosTheta, sinTheta, phi;
321
322 /* Get current partition */
323 numTheta = max(sqrt(2 * emap -> numPartitions / PI) + 0.5, 1);
324 numPhi = 0.5 * PI * numTheta + 0.5;
325
326 t = emap -> partitionCnt / numPhi;
327 p = emap -> partitionCnt - t * numPhi;
328
329 emap -> ws [2] = cosTheta = 1 - 2 * (t + pmapRandom(partState)) / numTheta;
330 sinTheta = sqrt(1 - sqr(cosTheta));
331 phi = 2 * PI * (p + pmapRandom(partState)) / numPhi;
332 emap -> ws [0] = cos(phi) * sinTheta;
333 emap -> ws [1] = sin(phi) * sinTheta;
334
335 if (emap -> port)
336 /* Acts as a photon port; reverse normal as it points INSIDE per
337 * mkillum convention */
338 for (i = 0; i < 3; i++)
339 emap -> ws [i] = -emap -> ws [i];
340
341 /* Get surface axes us & vs perpendicular to ws */
342 do {
343 emap -> vs [0] = emap -> vs [1] = emap -> vs [2] = 0;
344 emap -> vs [i++] = 1;
345 fcross(emap -> us, emap -> vs, emap -> ws);
346 } while (normalize(emap -> us) < FTINY);
347
348 fcross(emap -> vs, emap -> ws, emap -> us);
349
350 /* Get origin */
351 for (i = 0; i < 3; i++)
352 emap -> photonOrg [i] = emap -> src -> sloc [i] +
353 emap -> src -> srad * emap -> ws [i];
354
355 /* Get hemisphere axes & aperture */
356 if (emap -> src -> sflags & SSPOT) {
357 VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
358 i = 0;
359
360 do {
361 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
362 emap -> vh [i++] = 1;
363 fcross(emap -> uh, emap -> vh, emap -> wh);
364 } while (normalize(emap -> uh) < FTINY);
365
366 fcross(emap -> vh, emap -> wh, emap -> uh);
367 emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
368 }
369
370 else {
371 VCOPY(emap -> uh, emap -> us);
372 VCOPY(emap -> vh, emap -> vs);
373 VCOPY(emap -> wh, emap -> ws);
374 emap -> cosThetaMax = 0;
375 }
376 }
377
378
379
380 static void sourcePhotonOrigin (EmissionMap* emap)
381 /* Init emission map with photon origin and associated surface axes
382 on scene cube face for distant light source. Also sets source
383 aperture (solid angle) and sampling hemisphere axes at origin */
384 {
385 unsigned long i, partsPerDim, partsPerFace;
386 unsigned face;
387 RREAL du, dv;
388
389 if (emap -> port) {
390 /* Get origin on photon port */
391 SRCREC *src = emap -> src;
392 emap -> src = emap -> port;
393 photonOrigin [emap -> src -> so -> otype] (emap);
394 emap -> src = src;
395 }
396
397 else {
398 /* No ports defined, so get origin on scene cube face and SUFFA! */
399 /* Get current face from partition number */
400 partsPerDim = 1 / srcsizerat;
401 partsPerFace = sqr(partsPerDim);
402 face = emap -> partitionCnt / partsPerFace;
403
404 if (!(emap -> partitionCnt % partsPerFace)) {
405 /* Skipped to a new face; get its normal */
406 emap -> ws [0] = emap -> ws [1] = emap -> ws [2] = 0;
407 emap -> ws [face >> 1] = face & 1 ? 1 : -1;
408
409 /* Get surface axes us & vs perpendicular to ws */
410 face >>= 1;
411 emap -> vs [0] = emap -> vs [1] = emap -> vs [2] = 0;
412 emap -> vs [(face + (emap -> ws [face] > 0 ? 2 : 1)) % 3] = 1;
413 fcross(emap -> us, emap -> vs, emap -> ws);
414 }
415
416 /* Get jittered offsets within face from partition number
417 (in range [-0.5, 0.5]) */
418 i = emap -> partitionCnt % partsPerFace;
419 du = (i / partsPerDim + pmapRandom(partState)) / partsPerDim - 0.5;
420 dv = (i % partsPerDim + pmapRandom(partState)) / partsPerDim - 0.5;
421
422 /* Jittered destination point within partition */
423 for (i = 0; i < 3; i++)
424 emap -> photonOrg [i] = thescene.cuorg [i] +
425 thescene.cusize * (0.5 + du * emap -> us [i] +
426 dv * emap -> vs [i] +
427 0.5 * emap -> ws [i]);
428 }
429
430 /* Get hemisphere axes & aperture */
431 VCOPY(emap -> wh, emap -> src -> sloc);
432 i = 0;
433
434 do {
435 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
436 emap -> vh [i++] = 1;
437 fcross(emap -> uh, emap -> vh, emap -> wh);
438 } while (normalize(emap -> uh) < FTINY);
439
440 fcross(emap -> vh, emap -> wh, emap -> uh);
441
442 /* Get aperture */
443 emap -> cosThetaMax = 1 - emap -> src -> ss2 / (2 * PI);
444 emap -> cosThetaMax = min(1, max(-1, emap -> cosThetaMax));
445 }
446
447
448
449 static void cylPhotonOrigin (EmissionMap* emap)
450 /* Init emission map with photon origin and associated surface axes
451 on cylindrical light source surface. Also sets source aperture
452 and sampling hemisphere axes at origin */
453 {
454 int i, cent[3], size[3], parr[2];
455 FVECT v;
456
457 cent [0] = cent [1] = cent [2] = 0;
458 size [0] = size [1] = size [2] = emap -> maxPartitions;
459 parr [0] = 0;
460 parr [1] = emap -> partitionCnt;
461
462 if (!skipparts(cent, size, parr, emap -> partitions))
463 error(CONSISTENCY, "bad source partition in cylPhotonOrigin");
464
465 v [SU] = 0;
466 v [SV] = (1 - 2 * pmapRandom(partState)) * (double)size [1] /
467 emap -> maxPartitions;
468 v [SW] = (1 - 2 * pmapRandom(partState)) * (double)size [2] /
469 emap -> maxPartitions;
470 normalize(v);
471 v [SU] = (1 - 2 * pmapRandom(partState)) * (double)size [1] /
472 emap -> maxPartitions;
473
474 for (i = 0; i < 3; i++)
475 v [i] += (double)cent [i] / emap -> maxPartitions;
476
477 /* Get surface axes */
478 for (i = 0; i < 3; i++)
479 emap -> photonOrg [i] = emap -> ws [i] =
480 (v [SV] * emap -> src -> ss [SV][i] +
481 v [SW] * emap -> src -> ss [SW][i]) / 0.8559;
482
483 if (emap -> port)
484 /* Acts as a photon port; reverse normal as it points INSIDE per
485 * mkillum convention */
486 for (i = 0; i < 3; i++)
487 emap -> ws [i] = -emap -> ws [i];
488
489 normalize(emap -> ws);
490 VCOPY(emap -> us, emap -> src -> ss [SU]);
491 normalize(emap -> us);
492 fcross(emap -> vs, emap -> ws, emap -> us);
493
494 /* Get origin */
495 for (i = 0; i < 3; i++)
496 emap -> photonOrg [i] += v [SU] * emap -> src -> ss [SU][i] +
497 emap -> src -> sloc [i];
498
499 /* Get hemisphere axes & aperture */
500 if (emap -> src -> sflags & SSPOT) {
501 VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
502 i = 0;
503
504 do {
505 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
506 emap -> vh [i++] = 1;
507 fcross(emap -> uh, emap -> vh, emap -> wh);
508 } while (normalize(emap -> uh) < FTINY);
509
510 fcross(emap -> vh, emap -> wh, emap -> uh);
511 emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
512 }
513
514 else {
515 VCOPY(emap -> uh, emap -> us);
516 VCOPY(emap -> vh, emap -> vs);
517 VCOPY(emap -> wh, emap -> ws);
518 emap -> cosThetaMax = 0;
519 }
520 }
521
522
523
524 void getPhotonPorts ()
525 /* Find geometry declared as photon ports */
526 {
527 OBJECT i;
528 OBJREC* obj;
529
530 /* Check for missing port modifiers */
531 if (!ambset [0])
532 error(USER, "no photon ports found");
533
534 for (i = 0; i < nobjects; i++) {
535 obj = objptr(i);
536
537 /* Check if object is a surface and resolve its material via any
538 * aliases, then check for inclusion in port modifier list */
539 if (issurface(obj -> otype) &&
540 inset(ambset, objndx(findmaterial(obj)))) {
541 /* Add photon port */
542 photonPorts = (SRCREC*)realloc(photonPorts,
543 (numPhotonPorts + 1) *
544 sizeof(SRCREC));
545 if (!photonPorts)
546 error(USER, "can't allocate photon ports");
547
548 photonPorts [numPhotonPorts].so = obj;
549 photonPorts [numPhotonPorts].sflags = 0;
550
551 if (!sfun [obj -> otype].of || !sfun[obj -> otype].of -> setsrc)
552 objerror(obj, USER, "illegal photon port");
553
554 setsource(photonPorts + numPhotonPorts, obj);
555 numPhotonPorts++;
556 }
557 }
558 }
559
560
561
562 static void defaultEmissionFunc (EmissionMap* emap)
563 /* Default behaviour when no emission funcs defined for this source type */
564 {
565 objerror(emap -> src -> so, INTERNAL,
566 "undefined photon emission function");
567 }
568
569
570
571 void initPhotonEmissionFuncs ()
572 /* Init photonPartition[] and photonOrigin[] dispatch tables */
573 {
574 int i;
575
576 for (i = 0; i < NUMOTYPE; i++)
577 photonPartition [i] = photonOrigin [i] = defaultEmissionFunc;
578
579 photonPartition [OBJ_FACE] = photonPartition [OBJ_RING] = flatPhotonPartition;
580 photonPartition [OBJ_SOURCE] = sourcePhotonPartition;
581 photonPartition [OBJ_SPHERE] = spherePhotonPartition;
582 photonPartition [OBJ_CYLINDER] = cylPhotonPartition;
583 photonOrigin [OBJ_FACE] = photonOrigin [OBJ_RING] = flatPhotonOrigin;
584 photonOrigin [OBJ_SOURCE] = sourcePhotonOrigin;
585 photonOrigin [OBJ_SPHERE] = spherePhotonOrigin;
586 photonOrigin [OBJ_CYLINDER] = cylPhotonOrigin;
587 }
588
589
590
591 void initPhotonEmission (EmissionMap *emap, float numPdfSamples)
592 /* Initialize photon emission from partitioned light source emap -> src;
593 * this involves integrating the flux emitted from the current photon
594 * origin emap -> photonOrg and setting up a PDF to sample the emission
595 * distribution with numPdfSamples samples */
596 {
597 unsigned i, t, p;
598 double phi, cosTheta, sinTheta, du, dv, dOmega, thetaScale;
599 EmissionSample* sample;
600 const OBJREC* mod = findmaterial(emap -> src -> so);
601 static RAY r;
602 #if 0
603 static double lastCosNorm = FHUGE;
604 static SRCREC *lastSrc = NULL, *lastPort = NULL;
605 #endif
606
607 setcolor(emap -> partFlux, 0, 0, 0);
608
609 photonOrigin [emap -> src -> so -> otype] (emap);
610 cosTheta = DOT(emap -> ws, emap -> wh);
611
612 #if 0
613 if (emap -> src == lastSrc && emap -> port == lastPort &&
614 (emap -> src -> sflags & SDISTANT || mod -> omod == OVOID) &&
615 cosTheta == lastCosNorm)
616 /* Same source, port, and aperture-normal angle, and source is
617 either distant (and thus translationally invariant) or has
618 no modifier --> flux unchanged */
619 /* BUG: this optimisation ignores partial occlusion of ports and
620 can lead to erroneous "zero emission" bailouts.
621 It can also lead to bias with modifiers exhibiting high variance!
622 Disabled for now -- RS 12/13 */
623 return;
624
625 lastSrc = emap -> src;
626 lastPort = emap -> port;
627 lastCosNorm = cosTheta;
628 #endif
629
630 /* Need to recompute flux & PDF */
631 emap -> cdf = 0;
632 emap -> numSamples = 0;
633
634 if (cosTheta <= 0 &&
635 sqrt(1 - sqr(cosTheta)) <= emap -> cosThetaMax + FTINY)
636 /* Aperture below surface; no emission from current origin */
637 return;
638
639 if (mod -> omod == OVOID && !emap -> port &&
640 (cosTheta >= 1 - FTINY || (emap -> src -> sflags & SDISTANT &&
641 acos(cosTheta) + acos(emap -> cosThetaMax) <= 0.5 * PI))) {
642 /* Source is unmodified and has no port (which requires testing for
643 occlusion), and is either local with normal aligned aperture or
644 distant with aperture above surface; analytical flux & PDF */
645 setcolor(emap -> partFlux, mod -> oargs.farg [0],
646 mod -> oargs.farg [1], mod -> oargs.farg [2]);
647
648 /* Multiply radiance by Omega * dA to get flux */
649 scalecolor(emap -> partFlux,
650 PI * cosTheta * (1 - sqr(max(emap -> cosThetaMax, 0))) *
651 emap -> partArea);
652 }
653
654 else {
655 /* Source is either modified, has a port, is local with off-normal
656 aperture, or distant with aperture partly below surface; get flux
657 via numerical integration */
658 thetaScale = (1 - emap -> cosThetaMax);
659
660 /* Figga out numba of aperture samples for integration;
661 numTheta / numPhi ratio is 1 / PI */
662 du = sqrt(pdfSamples * 2 * thetaScale);
663 emap -> numTheta = max(du + 0.5, 1);
664 emap -> numPhi = max(PI * du + 0.5, 1);
665
666 dOmega = 2 * PI * thetaScale / (emap -> numTheta * emap -> numPhi);
667 thetaScale /= emap -> numTheta;
668
669 /* Allocate PDF, baby */
670 sample = emap -> samples = (EmissionSample*)
671 realloc(emap -> samples,
672 sizeof(EmissionSample) *
673 emap -> numTheta * emap -> numPhi);
674 if (!emap -> samples)
675 error(USER, "can't allocate emission PDF");
676
677 VCOPY(r.rorg, emap -> photonOrg);
678 VCOPY(r.rop, emap -> photonOrg);
679 r.rmax = 0;
680
681 for (t = 0; t < emap -> numTheta; t++) {
682 for (p = 0; p < emap -> numPhi; p++) {
683 /* This uniform mapping handles 0 <= thetaMax <= PI */
684 cosTheta = 1 - (t + pmapRandom(emitState)) * thetaScale;
685 sinTheta = sqrt(1 - sqr(cosTheta));
686 phi = 2 * PI * (p + pmapRandom(emitState)) / emap -> numPhi;
687 du = cos(phi) * sinTheta;
688 dv = sin(phi) * sinTheta;
689 rayorigin(&r, PRIMARY, NULL, NULL);
690
691 for (i = 0; i < 3; i++)
692 r.rdir [i] = du * emap -> uh [i] + dv * emap -> vh [i] +
693 cosTheta * emap -> wh [i];
694
695 /* Sample behind surface? */
696 VCOPY(r.ron, emap -> ws);
697 if ((r.rod = DOT(r.rdir, r.ron)) <= 0)
698 continue;
699
700 /* Get radiance emitted in this direction; to get flux we
701 multiply by cos(theta_surface), dOmega, and dA. Ray
702 is directed towards light source for raytexture(). */
703 if (!(emap -> src -> sflags & SDISTANT))
704 for (i = 0; i < 3; i++)
705 r.rdir [i] = -r.rdir [i];
706
707 /* Port occluded in this direction? */
708 if (emap -> port && localhit(&r, &thescene))
709 continue;
710
711 raytexture(&r, mod -> omod);
712 setcolor(r.rcol, mod -> oargs.farg [0], mod -> oargs.farg [1],
713 mod -> oargs.farg [2]);
714 multcolor(r.rcol, r.pcol);
715
716 /* Multiply by cos(theta_surface) */
717 scalecolor(r.rcol, r.rod);
718
719 /* Add PDF sample if nonzero; importance info for photon emission
720 * could go here... */
721 if (colorAvg(r.rcol)) {
722 copycolor(sample -> pdf, r.rcol);
723 sample -> cdf = emap -> cdf += colorAvg(sample -> pdf);
724 sample -> theta = t;
725 sample++ -> phi = p;
726 emap -> numSamples++;
727 addcolor(emap -> partFlux, r.rcol);
728 }
729 }
730 }
731
732 /* Multiply by dOmega * dA */
733 scalecolor(emap -> partFlux, dOmega * emap -> partArea);
734 }
735 }
736
737
738
739 #define vomitPhoton emitPhoton
740 #define bluarrrghPhoton vomitPhoton
741
742 void emitPhoton (const EmissionMap* emap, RAY* ray)
743 /* Emit photon from current partition emap -> partitionCnt based on
744 emission distribution. Returns new photon ray. */
745 {
746 unsigned long i, lo, hi;
747 const EmissionSample* sample = emap -> samples;
748 RREAL du, dv, cosTheta, cosThetaSqr, sinTheta, phi;
749 const OBJREC* mod = findmaterial(emap -> src -> so);
750
751 /* Choose a new origin within current partition for every
752 emitted photon to break up clustering artifacts */
753 photonOrigin [emap -> src -> so -> otype] ((EmissionMap*)emap);
754 /* If we have a local glow source with a maximum radius, then
755 restrict our photon to the specified distance (otherwise no limit) */
756 if (mod -> otype == MAT_GLOW && !(emap -> src -> sflags & SDISTANT)
757 && mod -> oargs.farg[3] > FTINY)
758 ray -> rmax = mod -> oargs.farg[3];
759 else
760 ray -> rmax = 0;
761 rayorigin(ray, PRIMARY, NULL, NULL);
762
763 if (!emap -> numSamples) {
764 /* Source is unmodified and has no port, and either local with
765 normal aligned aperture, or distant with aperture above surface;
766 use cosine weighted distribution */
767 cosThetaSqr = 1 - pmapRandom(emitState) *
768 (1 - sqr(max(emap -> cosThetaMax, 0)));
769 cosTheta = sqrt(cosThetaSqr);
770 sinTheta = sqrt(1 - cosThetaSqr);
771 phi = 2 * PI * pmapRandom(emitState);
772 setcolor(ray -> rcol, mod -> oargs.farg [0], mod -> oargs.farg [1],
773 mod -> oargs.farg [2]);
774 }
775
776 else {
777 /* Source is either modified, has a port, is local with off-normal
778 aperture, or distant with aperture partly below surface; choose
779 direction from constructed cumulative distribution function with
780 Monte Carlo inversion using binary search. */
781 du = pmapRandom(emitState) * emap -> cdf;
782 lo = 1;
783 hi = emap -> numSamples;
784
785 while (hi > lo) {
786 i = (lo + hi) >> 1;
787 sample = emap -> samples + i - 1;
788
789 if (sample -> cdf >= du)
790 hi = i;
791 if (sample -> cdf < du)
792 lo = i + 1;
793 }
794
795 /* This is a uniform mapping, mon */
796 cosTheta = 1 - (sample -> theta + pmapRandom(emitState)) *
797 (1 - emap -> cosThetaMax) / emap -> numTheta;
798 sinTheta = sqrt(1 - sqr(cosTheta));
799 phi = 2 * PI * (sample -> phi + pmapRandom(emitState)) / emap -> numPhi;
800 copycolor(ray -> rcol, sample -> pdf);
801 }
802
803 /* Normalize photon flux so that average over RGB is 1 */
804 colorNorm(ray -> rcol);
805
806 VCOPY(ray -> rorg, emap -> photonOrg);
807 du = cos(phi) * sinTheta;
808 dv = sin(phi) * sinTheta;
809
810 for (i = 0; i < 3; i++)
811 ray -> rdir [i] = du * emap -> uh [i] + dv * emap -> vh [i] +
812 cosTheta * emap -> wh [i];
813
814 if (emap -> src -> sflags & SDISTANT)
815 /* Distant source; reverse ray direction to point into the scene. */
816 for (i = 0; i < 3; i++)
817 ray -> rdir [i] = -ray -> rdir [i];
818
819 if (emap -> port)
820 /* Photon emitted from port; move origin just behind port so it
821 will be scattered */
822 for (i = 0; i < 3; i++)
823 ray -> rorg [i] -= 2 * FTINY * ray -> rdir [i];
824
825 /* Assign emitting light source index */
826 ray -> rsrc = emap -> src - source;
827 }
828
829
830
831 void multDirectPmap (RAY *r)
832 /* Factor irradiance from direct photons into r -> rcol; interface to
833 * direct() */
834 {
835 COLOR photonIrrad;
836
837 /* Lookup direct photon irradiance */
838 (directPmap -> lookup)(directPmap, r, photonIrrad);
839
840 /* Multiply with coefficient in ray */
841 multcolor(r -> rcol, photonIrrad);
842
843 return;
844 }
845
846
847
848 void inscatterVolumePmap (RAY *r, COLOR inscatter)
849 /* Add inscattering from volume photon map; interface to srcscatter() */
850 {
851 /* Add ambient in-scattering via lookup callback */
852 (volumePmap -> lookup)(volumePmap, r, inscatter);
853 }
