root/radiance/ray/src/rt/pmapsrc.c
Fri Apr 9 17:42:34 2021 UTC (4 years, 4 months ago) by rschregle
Changes since 2.19: +8 -4 lines
Diff to previous 2.19 , to selected 2.17
fix(mkpmap): CDF inversion binary search bug in emitPhoton().
Mon Aug 10 19:51:20 2020 UTC (4 years, 11 months ago) by rschregle
Changes since 2.18: +26 -20 lines
Diff to previous 2.18 , to selected 2.17
fix(mkpmap): undefined port in setPhotonPortNormal()
Fri Aug 7 01:21:13 2020 UTC (5 years ago) by rschregle
Changes since 2.17: +271 -180 lines
Diff to previous 2.17
feat(mkpmap): Extended -apo option to reorient photon ports.
Revision 2.17 - (view) (download) (annotate) - [selected]
Thu Nov 8 00:54:07 2018 UTC (6 years, 9 months ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16
Sat Apr 7 20:25:10 2018 UTC (7 years, 4 months ago) by rschregle
Changes since 2.15: +5 -3 lines
Diff to previous 2.15 , to selected 2.17
Fixed erroneous bailout in getPhotonPorts() when ports *aren't* used.
Tue Mar 20 19:55:33 2018 UTC (7 years, 4 months ago) by rschregle
Changes since 2.14: +28 -25 lines
Diff to previous 2.14 , to selected 2.17
Added -ae/-ai ambient exclude options to mkpmap, cleaned up opt parsing.
Fri Feb 2 19:47:55 2018 UTC (7 years, 6 months ago) by rschregle
Changes since 2.13: +4 -3 lines
Diff to previous 2.13 , to selected 2.17
Added -lr, -ld options to mkpmap, enabled -api
Tue May 17 17:39:47 2016 UTC (9 years, 2 months ago) by rschregle
Diff to previous 2.12 , to selected 2.17
Thu Oct 29 15:27:08 2015 UTC (9 years, 9 months ago) by rschregle
Diff to previous 2.11 , to selected 2.17
Fixed NULL material SEGFAULTs when checking photon ports
Tue Oct 27 19:06:54 2015 UTC (9 years, 9 months ago) by rschregle
Changes since 2.10: +9 -5 lines
Diff to previous 2.10 , to selected 2.17
Fixed SEGFAULTS when declaring light sources as photon ports!
Tue Sep 29 18:16:34 2015 UTC (9 years, 10 months ago) by rschregle
Changes since 2.9: +5 -4 lines
Diff to previous 2.9 , to selected 2.17
Improved handling of mixtures and photon ports with photon mapping
Tue Sep 22 15:08:31 2015 UTC (9 years, 10 months ago) by rschregle
Changes since 2.8: +5 -2 lines
Diff to previous 2.8 , to selected 2.17
Improved photon port handling -- only actual surfaces are accepted
Tue Sep 1 16:27:53 2015 UTC (9 years, 11 months ago) by greg
Diff to previous 2.7 , to selected 2.17
Tue Aug 18 18:45:55 2015 UTC (9 years, 11 months ago) by greg
Changes since 2.6: +4 -1 lines
Diff to previous 2.6 , to selected 2.17
Thu May 28 12:27:22 2015 UTC (10 years, 2 months ago) by greg
Diff to previous 2.5 , to selected 2.17
Bug fix for uninitialized sources set to -1
Fri May 22 11:38:26 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.4: +9 -3 lines
Diff to previous 2.4 , to selected 2.17
Added test for local glow lights
Thu May 21 13:54:59 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.3: +5 -4 lines
Diff to previous 2.3 , to selected 2.17
Added calls to findmaterial() and simplified photon map shadow check
Fri May 8 13:20:23 2015 UTC (10 years, 3 months ago) by rschregle
Diff to previous 2.2 , to selected 2.17
Tue Apr 21 19:16:51 2015 UTC (10 years, 3 months ago) by greg
Changes since 2.1: +9 -8 lines
Diff to previous 2.1 , to selected 2.17
Fixes for Windows and photon map
Tue Feb 24 19:39:27 2015 UTC (10 years, 5 months ago) by greg
Diff to selected 2.17
